path: root/configs/Cyrus_P5020_defconfig
2016-12-02powerpc: cyrus: Separate P5020/P5040 config optionsYork Sun
Instead of using EXTRA options in defconfig, use two targets in Kconfig to select correct SoC. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5020: Remove macro CONFIG_PPC_P5020York Sun
Replace CONFIG_PPC_P5020 with ARCH_P5020 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-04mpc85xx: Add support for the Varisys Cyrus boardAndy Fleming
This board runs a P5020 or P5040 chip, and utilizes an EEPROM with similar formatting to the Freescale P5020DS. Large amounts of this code were developed by Adrian Cox <adrian at humboldt dot co dot uk> Signed-off-by: Andy Fleming <afleming@gmail.com> Reviewed-by: York Sun <yorksun@freescale.com>
