path: root/configs/Cyrus_P5020_defconfig
2017-09-27usb: kbd: Set a default polling mechanism for USB keyboardBin Meng
The choice of "USB keyboard polling" cannot be optional as without one mechanism being set, it just doesn't work. Set the default one to CONFIG_SYS_USB_EVENT_POLL. Fixes: ecad7051 ("configs: Migrate all of the existing USB symbols, except fastboot") Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2016-12-02powerpc: cyrus: Separate P5020/P5040 config optionsYork Sun
Instead of using EXTRA options in defconfig, use two targets in Kconfig to select correct SoC. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5020: Remove macro CONFIG_PPC_P5020York Sun
Replace CONFIG_PPC_P5020 with ARCH_P5020 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-04mpc85xx: Add support for the Varisys Cyrus boardAndy Fleming
This board runs a P5020 or P5040 chip, and utilizes an EEPROM with similar formatting to the Freescale P5020DS. Large amounts of this code were developed by Adrian Cox <adrian at humboldt dot co dot uk> Signed-off-by: Andy Fleming <afleming@gmail.com> Reviewed-by: York Sun <yorksun@freescale.com>
