path: root/configs/Cubieboard_defconfig
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-04-20sunxi: Convert CONFIG_SATAPWR to KconfigMylène Josserand
Convert the CONFIG_SATAPWR into kconfig. Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some defconfigs. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Convert SUNXI_EMAC to KconfigMylène Josserand
Convert the SUNXI_EMAC config to Kconfig. Remove it from SYS_EXTRA_OPTIONS from many sunxi defconfig and renamed it into SUN4I_EMAC to not confuse it with SUN8I_EMAC. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-11-28sunxi: Use the available Kconfig option for AHCIJelle van der Waa
Use the already available Kconfig option for AHCI. Tested on the BananaPi. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-31sunxi: Add CONFIG_MMC0_CD_PIN to various boardsHans de Goede
Add CONFIG_MMC0_CD_PIN to various boards, this stops the SPL from still trying to access the sdcard when there is none (e.g. when booting from nand). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Remove CONFIG_TARGET_FOO for sun4i, sun6i and sun8i boardsHans de Goede
CONFIG_TARGET_FOO is only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), iow it is not used at all on any sun4i, sun6i and sun8i boards so lets get rid of it there. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Stop differentiating between 512M and 1G variants of the same boardHans de Goede
While working on adding more boards I noticed that we lack a config for the 512M cubieboard, and that some of the new boards which I want to add also have 512M and 1G variants, rather then adding 2 defconfig's for all of these, lets switch the exising boards which have both a 512M and 1024M variant over to the sun4i dram autoconfig code. This also drops the foo_RAMSIZE_defconfig variants of boards where we currently have 2 separate configs already. Note: 1) The newly introduced CONFIG_DRAM_EMR1 kconfig value is not used with a value other then its default for now, but we need this to be configurable to support some new boards with auto dram config. 2) We always set all CONFIG_DRAM_foo values in defconfigs, even if they match the defaults, this is done to make it more clear what values are used for a certain board. This has been tested on a Mele A1000, Mini-X and a Cubieboard, all 1G variants, the dram autoconfig code has also been tested on a 512M mk802 (a defconfig for the mk802 is added in a later patch). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05sunxi: kconfig: Introduce CONFIG_TARGET_<BOARD>Ian Campbell
This was done automatically with the following bits of scripting. The Kconfig choice content was generated with this script snippet: for i in $(git grep -l CONFIG_ARCH_SUNXI configs/*) ; do TARGET=$(sed -n -e 's/CONFIG_SYS_EXTRA_OPTIONS="\([^,"]\+\).*/\1/p' $i); MACH=$(sed -n -e 's/.*CONFIG_\(MACH_SUN.I\)=./\1/p' $i) echo "config TARGET_$TARGET" echo " bool \"$TARGET\"" echo " depends on $MACH" echo done defconfigs were updated with a sed script (t): # Extract board from first entry of CONFIG_SYS_EXTRA_OPTIONS, /^CONFIG_SYS_EXTRA_OPTIONS/ { s/^\(CONFIG_SYS_EXTRA_OPTIONS="\)\([^,"]\+\),\?\(.*\)/\1\3\nCONFIG_TARGET_\2=y/; # Print and delete first line (CONFIG_SYS_EXTRA_OPTIONS), leaving # CONFIG_TARGET_<BOARD> in pattern space P;D; }; # Move CONFIG_TARGET_<BOARD> to hold space /^CONFIG_TARGET/{h;n} # Print CONFIG_TARGET_<BOARD> after CONFIG_MACH_<SOC> in either SPL or # normal mode. /^CONFIG_MACH/{p;g;p;n}; /^\+S:CONFIG_MACH/{p;g;s/^CONFIG_TARGET/+S:&/;p;n}; # Print any remaining lines normally p; Run as: sed -i -n -f t $(git grep -l CONFIG_ARCH_SUNXI configs/*) and then manually removing the one instance of CONFIG_SYS_EXTRA_OPTIONS="" from Colombus_defconfig board/sunxi/Makefile was updated with: sed -e 's/^\(obj-\$(CONFIG_\)\(.*\)\().*+= dram_.*\)/\1TARGET_\2\3/g' board/sunxi/Makefile and manually retabbing a few lines to line up again. The board descriptions could certainly be improved. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Rename TARGET_SUN[45678]I to MACH_SUN[45678]I.Ian Campbell
Now we have CONFIG_ARCH_SUNXI as the toplevel, CONFIG_MACH_SUN[45678]I as the per-SoC option and leave CONFIG_TARGET_BLAH free for individual boards in the future. Done automatically with: sed -i -e 's/TARGET_\(SUN[45678]I\)/MACH_\1/g' $(git grep -l TARGET_SUN[45678]I) Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Add top-level ARCH_SUNXIIan Campbell
And make TARGET_SUN[45678]I a choice variable under this. configs updated with: sed -i -e 's/^\(\+S:\)\?CONFIG_TARGET_SUN.I=y/\1CONFIG_ARCH_SUNXI=y\n&/g' configs/* Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-09-05sunxi: Correct typo CONFIG_FTDFILE => CONFIG_FDTFILEIan Campbell
Patch is the result of: sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig Reported-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> [ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
2014-09-05kconfig: remove redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONSMasahiro Yamada
CONFIG_SPL is defined as a primary option in Kconfig. It should not be added to CONFIG_SYS_EXTRA_OPTIONS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-08-12sunxi: Add environment settings to make extlinux.conf booting workHans de Goede
Automatic booting using an extlinux.conf file requires various environment variables to be set. Also modify CONFIG_SYS_LOAD_ADDR and CONFIG_STANDALONE_LOAD_ADDR to match the value chosen for kernel_addr_r, see the added comment for why the new value is chosen. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-07-31sunxi: Enable EHCI on various sunxi boardsHans de Goede
Most sunxi boards have the EHCI controller hooked up, enable it on all relevant boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-31ahci: provide sunxi SATA driver using AHCI platform frameworkIan Campbell
This enables the necessary clocks, in AHB0 and in PLL6_CFG. This is done for sun7i only since I don't have access to any other sunxi platforms with sata included. The PHY setup is derived from the Alwinner releases and Linux, but is mostly undocumented. The Allwinner AHCI controller also requires some magic (and, again, undocumented) DMA initialisation when starting a port. This is added under a suitable ifdef. This option is enabled for Cubieboard, Cubieboard2 and Cubietruck based on contents of Linux DTS files, including SATA power pin config taken from the DTS. All build tested, but runtime tested on Cubieboard2 and Cubietruck only. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
