path: root/configs/Cubieboard4_defconfig
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-30sunxi: Add support for Cubieboard4Chen-Yu Tsai
The Cubieboard4 is an A80 SoC based development board from Cubietech. This board has a UART port, 4 USB host ports, a USB 3.0 OTG connector, HDMI and VGA outputs, a micro SD slot, 8G eMMC flash, 2G DRAM, a WiFi/BT combo chip, headphone and microphone jacks, IR receiver, and GPIO headers. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
