path: root/configs/C29XPCIE_defconfig
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: C29XPCIE: Remove macro CONFIG_C29XPCIEYork Sun
Use CONFIG_TARGET_C29XPCIE instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
