path: root/configs/C29XPCIE_NOR_SECBOOT_defconfig
2015-01-16powerpc/c29xpcie: Add secure boot supportPo Liu
Add NOR and SPI flash secure boot target for C29XPCIE board. Signed-off-by: Po Liu <Po.Liu@freescale.com> Signed-off-by: Mingkai.Hu <Mingkai.Hu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
