path: root/configs/Bananapro_defconfig
2016-01-26sunxi: Bananapro: Set LDO4 to 2.5VHans de Goede
According to the Bananapro schematic VDD25-SATA either comes from a dedicated WL2003E25-5 LTO, or it is connected to LDO4 via a 0 Ohm resistor. In practice it seems that LDO4 is used, so enable it and set it to 2.5V. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-09-29sunxi: add NetConsole by default for Banana Pi/ProBernhard Nortmann
Simon Glass and Joe Hershberger suggested adding at least one test case for the CONFIG_DM_ETH plus CONFIG_NETCONSOLE options. This patch enables NetConsole as a default for the "Banana Pi/Pro" sunxi boards. (By the nature of this patch it could probably be extended later to include all sunxi boards using CONFIG_SUNXI_[EG]MAC.) Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-08-14sunxi: display: Enable composite video support on more boardsHans de Goede
Enable composite video support on all boards which have a composite video out connector (either cinch or jack). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Move all boards to the driver-modelHans de Goede
Now that we've everything prepared for it remove the DM settings from the defconfig(s) and simply always set them for sunxi. This makes all sunxi boards allways use the driver model for gpios and ethernet, and allows us to move over more bits to the driver-model without the need to introduce #ifdef-ery for boards which are not yet using DM. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-02-02sunxi: Remove CONFIG_TARGET_FOO for sun5i and sun7i boardsHans de Goede
CONFIG_TARGET_FOO was only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), all sun5i and sun7i boards have been moved over to using a single dram_sun5i_autoconfig file, and the tx clk delay handling for the Banana boards now has its own Kconfig. IOW nothing is using CONFIG_TARGET_FOO anymore, so remove it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Add a GMAC Transmit Clock Delay Chain Kconfig optionHans de Goede
And use this to set the GMAC Transmit Clock Delay Chain value on Banana boards, rather then keying of CONFIG_TARGET_FOO. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-23sunxi: Convert sun7i boards to use auto dram configurationHans de Goede
Currently we've separate detailed dram settings for all sun7i boards, this moves them over to using auto dram configuration so that we can get rid of all the per board dram_foo.c files. This has been tested on a A20-Olinuxino-Lime, A20-Olinuxino_MICRO, Bananapi, Bananapro, Cubieboard2, Cubietruck, Mele_M3 and a Linksprite_pcDuino3. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun7i: Add new Bananapro board / defconfigHans de Goede
Add support for the new Bananapro A20 development board from lemaker.org. This board features 1G RAM, 2 USB A receptacles, 1 micro USB receptacle for OTG, 1 micro USB receptacle for power, HDMI, sata, Gbit ethernet, ir receiver, 3.5 mm jack for a/v out, on board microphone, 40 gpio pins and sdio wifi. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
