path: root/configs/Bananapi_M2_Ultra_defconfig
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-05-02sunxi: enable SATA on Banana Pi M2 UltraIcenowy Zheng
Banana Pi M2 Ultra has a SATA port connected to the internal SATA controller of R40 SoC. The controller's 1.2v VDD is connected to ELDO3 and the 2.5v VDD is connected to DLDO4. Enable these regulators as well as the SATA support of Banana Pi M2 Ultra, by adding needed config lines into its defconfig. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Add support for Bananapi M2 UltraChen-Yu Tsai
The Bananapi M2 Ultra is the first publicly available development board featuring the R40 SoC. This patch add barebone dtsi/dts files for the R40 and Bananapi M2 Ultra, as well as a defconfig for it. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
