path: root/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2016-11-23powerpc: BSC9132QDS: Remove CONFIG_BSC9132QDS macroYork Sun
Use CONFIG_TARGET_BSC9132QDS from Kconfig option, remove CONFIG_BSC9132QDS macro. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-15spl: move FDT_FIXUP_PARTITIONS to KconfigHeiko Schocher
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
