path: root/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig
2016-11-23powerpc: BSC9132QDS: Remove CONFIG_BSC9132QDS macroYork Sun
Use CONFIG_TARGET_BSC9132QDS from Kconfig option, remove CONFIG_BSC9132QDS macro. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-15spl: move FDT_FIXUP_PARTITIONS to KconfigHeiko Schocher
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
