path: root/configs/BSC9131RDB_SPIFLASH_defconfig
2016-11-23powerpc: BSC9131RDB: Remove CONFIG_BSC9131RDB macroYork Sun
This macro CONFIG_BSC9131RDB is no longer needed. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-15spl: move FDT_FIXUP_PARTITIONS to KconfigHeiko Schocher
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
