path: root/configs/BSC9131RDB_NAND_defconfig
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: BSC9131RDB: Remove CONFIG_BSC9131RDB macroYork Sun
This macro CONFIG_BSC9131RDB is no longer needed. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-15spl: move FDT_FIXUP_PARTITIONS to KconfigHeiko Schocher
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
