path: root/configs/B4860QDS_NAND_defconfig
2016-11-23powerpc: B4860: Remove macro CONFIG_PPC_B4860York Sun
Replace CONFIG_PPC_B4860 with ARCH_B4860 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-20configs: Re-syncTom Rini
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
