path: root/configs/B4420QDS_defconfig
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: B4420: Remove macro CONFIG_PPC_B4420York Sun
Replace CONFIG_PPC_B4420 with ARCH_B4420 in Kconfig and clean up existing macros.
2016-11-23powerpc: B4420QDS: Split from B4860QDS in KconfigYork Sun
Use TARGET_B4420QDS to simplify Kconfig options. Signed-off-by: York Sun <york.sun@nxp.com>
