path: root/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig
2018-05-30usb: fastboot: Convert USB f_fastboot to shared fastbootAlex Kiernan
Convert USB fastboot code to use shared fastboot protocol. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-03-13sunxi: Add A20-SOM204-EVB-eMMC boardStefan Mavrodiev
A20-SOM204 board has option with onboard 16GB eMMC. The chip is wired to MMC2 slot. This patch adds defconfig and dts files for this board. The dts is same with mainline kernel. Signed-off-by: Stefan Mavrodiev <stefan@olimex.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
