path: root/configs/A20-OLinuXino-Lime_defconfig
2016-11-28sunxi: Use the available Kconfig option for AHCIJelle van der Waa
Use the already available Kconfig option for AHCI. Tested on the BananaPi. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-10-10sunxi: OLinuXino Lime A20 boards: Use 384 MHz DRAM clockJosh Marshall
We have a number of OlinuXino Lime2 boards (both NAND and eMMC versions) which were experiencing sporadic hangs. After testing with some heavy benchmarking and help from the Armbian forum, it was pinned down as the DRAM settings for the board. The default is 480MHz, but this is unstable, and even the build instructions from the vendor Olimex themselves say to set the DRAM clock to 384. See line 96 at: https://github.com/OLIMEX/OLINUXINO/blob/master/SOFTWARE/A20/A20-build-3.4.103-release-2/BUILD_DESCRIPTION_A20_Olimex_kernel_3.4.103%2B_Jessie_rel_2.txt Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-31sunxi: Enable LDO3 and LDO4 at 2.8V on OLinuxIno Lime boardsHans de Goede
LDO3 and LDO4 are used to power port E resp. port G, which are exposed on gpio headers, so enable them at 2.8V as specified in the schematic. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-31sunxi: Add CONFIG_MMC0_CD_PIN to various boardsHans de Goede
Add CONFIG_MMC0_CD_PIN to various boards, this stops the SPL from still trying to access the sdcard when there is none (e.g. when booting from nand). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Move all boards to the driver-modelHans de Goede
Now that we've everything prepared for it remove the DM settings from the defconfig(s) and simply always set them for sunxi. This makes all sunxi boards allways use the driver model for gpios and ethernet, and allows us to move over more bits to the driver-model without the need to introduce #ifdef-ery for boards which are not yet using DM. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-02-02sunxi: Remove CONFIG_TARGET_FOO for sun5i and sun7i boardsHans de Goede
CONFIG_TARGET_FOO was only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), all sun5i and sun7i boards have been moved over to using a single dram_sun5i_autoconfig file, and the tx clk delay handling for the Banana boards now has its own Kconfig. IOW nothing is using CONFIG_TARGET_FOO anymore, so remove it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-23sunxi: Convert sun7i boards to use auto dram configurationHans de Goede
Currently we've separate detailed dram settings for all sun7i boards, this moves them over to using auto dram configuration so that we can get rid of all the per board dram_foo.c files. This has been tested on a A20-Olinuxino-Lime, A20-Olinuxino_MICRO, Bananapi, Bananapro, Cubieboard2, Cubietruck, Mele_M3 and a Linksprite_pcDuino3. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05sunxi: kconfig: Introduce CONFIG_TARGET_<BOARD>Ian Campbell
This was done automatically with the following bits of scripting. The Kconfig choice content was generated with this script snippet: for i in $(git grep -l CONFIG_ARCH_SUNXI configs/*) ; do TARGET=$(sed -n -e 's/CONFIG_SYS_EXTRA_OPTIONS="\([^,"]\+\).*/\1/p' $i); MACH=$(sed -n -e 's/.*CONFIG_\(MACH_SUN.I\)=./\1/p' $i) echo "config TARGET_$TARGET" echo " bool \"$TARGET\"" echo " depends on $MACH" echo done defconfigs were updated with a sed script (t): # Extract board from first entry of CONFIG_SYS_EXTRA_OPTIONS, /^CONFIG_SYS_EXTRA_OPTIONS/ { s/^\(CONFIG_SYS_EXTRA_OPTIONS="\)\([^,"]\+\),\?\(.*\)/\1\3\nCONFIG_TARGET_\2=y/; # Print and delete first line (CONFIG_SYS_EXTRA_OPTIONS), leaving # CONFIG_TARGET_<BOARD> in pattern space P;D; }; # Move CONFIG_TARGET_<BOARD> to hold space /^CONFIG_TARGET/{h;n} # Print CONFIG_TARGET_<BOARD> after CONFIG_MACH_<SOC> in either SPL or # normal mode. /^CONFIG_MACH/{p;g;p;n}; /^\+S:CONFIG_MACH/{p;g;s/^CONFIG_TARGET/+S:&/;p;n}; # Print any remaining lines normally p; Run as: sed -i -n -f t $(git grep -l CONFIG_ARCH_SUNXI configs/*) and then manually removing the one instance of CONFIG_SYS_EXTRA_OPTIONS="" from Colombus_defconfig board/sunxi/Makefile was updated with: sed -e 's/^\(obj-\$(CONFIG_\)\(.*\)\().*+= dram_.*\)/\1TARGET_\2\3/g' board/sunxi/Makefile and manually retabbing a few lines to line up again. The board descriptions could certainly be improved. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Rename TARGET_SUN[45678]I to MACH_SUN[45678]I.Ian Campbell
Now we have CONFIG_ARCH_SUNXI as the toplevel, CONFIG_MACH_SUN[45678]I as the per-SoC option and leave CONFIG_TARGET_BLAH free for individual boards in the future. Done automatically with: sed -i -e 's/TARGET_\(SUN[45678]I\)/MACH_\1/g' $(git grep -l TARGET_SUN[45678]I) Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Add top-level ARCH_SUNXIIan Campbell
And make TARGET_SUN[45678]I a choice variable under this. configs updated with: sed -i -e 's/^\(\+S:\)\?CONFIG_TARGET_SUN.I=y/\1CONFIG_ARCH_SUNXI=y\n&/g' configs/* Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-09-05sun7i: Add support for Olimex A20-OLinuXino-LIMEFUKAUMI Naoki
This patch adds support for Olimex A20-OLinuXino-LIME board. Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
