path: root/configs/A20-OLinuXino-Lime2-eMMC_defconfig
2019-02-22configs: Resync with savedefconfigTom Rini
2019-02-11arm: sunxi: Enable SPL/SPI boot for Olinuxino Lime2-eMMC boardsPriit Laes
Starting from revision K the Olimex-Lime2-eMMC boards include eMMC 5.x chip. Unfortunately, the internal brom in the A20 cannot reliably initialize those chips resulting in random boot failures on those boards. To overcome this, all the latest Lime2-eMMC boards are populated with 16MB SPI flash and therefore enable support for SPI SPL boot. For now, SPI flash can be managed using sunxi-fel's spiflash tools. Signed-off-by: Priit Laes <priit.laes@paf.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-18sunxi: usb: Switch to Generic host controllersJagan Teki
Onc of key blocker for using USB Generic host controller drivers in Allwinner are CLK and RESET drivers, now these available for USB usage. So switch sunxi USB use EHCI and OHCI Generic controllers. Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD where it already have USB_EHCI_HCD Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-07arm: sunxi: Reduce inrush current on Olimex OLinuXino-A20-Lime2-eMMCPriit Laes
The lime2 features a too large capacitor on the LDO3 output, which causes the PMIC to shutdown when enabling power. To be able to still boot up however, we must gradually enable power on LDO3 for this board. We do this by enabling both the inrush quirk and the maximum slope the AXP209 supports. Signed-off-by: Priit Laes <plaes@plaes.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-05-30usb: fastboot: Convert USB f_fastboot to shared fastbootAlex Kiernan
Convert USB fastboot code to use shared fastboot protocol. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-03-14sunxi: move CONFIG_SYS_TEXT_BASE out of defconfigsAndre Przywara
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence of moving the common definition shared by almost every sunxi board into 123 individual defconfig files. But the U-Boot start address for Allwinner boards is a platform decision which has been around for ages, so defining it in each *board* config file seems a bit over the top. Define the standard values (160MB into DRAM for most SoCs, with two SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from the individual defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-12-19Merge git://git.denx.de/u-boot-sunxiTom Rini
2017-12-19configs: sunxi: Drop FASTBOOT_FLASHJagan Teki
Now FASTBOOT_FLASH is auto select for sunxi platform, so drop explicit addition. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-03sunxi: Remove the MMC index hackMaxime Ripard
The current code, if there's both an eMMC and an MMC slot available on the board, will swap the MMC indices based on whether we booted from the eMMC or the MMC. This way, the MMC we're supposed to boot on will always have the index 0. However, this causes various issues, for example when using other components that base their behaviour on the MMC index, such as fastboot. Let's remove that hack, and take the opposite approach. The MMC will always have the same index, but the bootcmd will pick the same device than the one we booted from. This is done through the introduction of the mmc_bootdev environment variable that will be filled by the board code based on the boot device informations we can get from the SoC. In order to not introduce regressions, we also need to adjust the fastboot MMC device and the environment device in order to set it to the eMMC, over the MMC, like it used to be the case. Tested-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03cmd: fastboot: Rework fastboot dependencyMaxime Ripard
Fastboot need a bunch of options to be operating properly, such as the g_dnl gadget, the fastboot command, and some options that make sense. Since fastboot is now part of Kconfig, make sure we have them right. That will also reduce the boilerplate in the defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03sunxi: imply USB_GADGETMaxime Ripard
A good number of our boards have USB_GADGET enabled. Imply it so that all the boards can benefit from it, and remove some boilerplate from our defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03sunxi: provide default USB gadget setupMaxime Ripard
All the Allwinner boards use the same manufacturer, VID and PID for the gadgets. Make them the defaults to remove some boilerplate from our defconfigs. Reviewed-by: Łukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16Merge git://git.denx.de/u-boot-sunxiTom Rini
Update A20-OLinuXino-Lime2-eMMC_defconfig to include CONFIG_SCSI Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11sun7i: Add support for Olimex A20-OLinuXino-LIME2-eMMCOlliver Schinagl
This patch adds support for the Olimex OLinuXino Lime2 with eMMC flash storage. https://www.olimex.com/Products/OLinuXino/A20/A20-OLinuXino-LIME2-eMMC/ It is a assembly variant of the regular Lime2 but featuring eMMC for storage. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
