Enable VGA output on the A13-OLinuXino and A13-OLinuXinoM now that we've
support for it.
Also add LCD timing and gpio info for the Olimex 7" LCD module. We can safely
put this in the default config on this boards, since by default we will always
use VGA, and the LCD timing info will only get used if the user explicitly
sets monitor=lcd in the video-mode env. variable.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
For use together with the hdmi console.
Acked-by: Ian Campbell <ian.campbell@citrix.com>
This adds a fixed mode hdmi driver for the sunxi platform. The fixed
mode is a relatively safe 1024x768, more complete EDID handling is
currently not provided. Only HDMI is supported today.
This code is enabled when HPD detects an attached monitor.
Current config is such that 8MB is shaved off at the top of the RAM.
This avoids several memory handling issues, most significant is the fact
that on linux on ARM you are not allowed to remap known RAM as IO. A
clued in display driver will be able to recycle this reserved RAM in
future though.
cfbconsole was chosen as it provides the most important functionality: a
working u-boot console, allowing for the debugging of certain issues
without the need for a UART.
Signed-off-by: Luc Verhaegen <libv@skynet.be>
[hdegoede@redhat.com: Major cleanups and some small bugfixes]
Acked-by: Anatolij Gustschin <agust@denx.de>
Add proper Kconfig options to select the usb Vbus gpio-s, besides moving to
Kconfig being the right thing to do, an added advantage of this is that it
allows for boards without Vbus gpio-s.
This was done automatically with the following bits of scripting.
The Kconfig choice content was generated with this script snippet:
for i in $(git grep -l CONFIG_ARCH_SUNXI configs/*) ; do
TARGET=$(sed -n -e 's/CONFIG_SYS_EXTRA_OPTIONS="\([^,"]\+\).*/\1/p' $i);
MACH=$(sed -n -e 's/.*CONFIG_\(MACH_SUN.I\)=./\1/p' $i)
echo "config TARGET_$TARGET"
echo " bool \"$TARGET\""
echo " depends on $MACH"
echo
done
defconfigs were updated with a sed script (t):
# Extract board from first entry of CONFIG_SYS_EXTRA_OPTIONS,
/^CONFIG_SYS_EXTRA_OPTIONS/ {
s/^\(CONFIG_SYS_EXTRA_OPTIONS="\)\([^,"]\+\),\?\(.*\)/\1\3\nCONFIG_TARGET_\2=y/;
# Print and delete first line (CONFIG_SYS_EXTRA_OPTIONS), leaving
# CONFIG_TARGET_<BOARD> in pattern space
P;D;
# Move CONFIG_TARGET_<BOARD> to hold space
/^CONFIG_TARGET/{h;n}
# Print CONFIG_TARGET_<BOARD> after CONFIG_MACH_<SOC> in either SPL or
# normal mode.
/^CONFIG_MACH/{p;g;p;n};
/^\+S:CONFIG_MACH/{p;g;s/^CONFIG_TARGET/+S:&/;p;n};
# Print any remaining lines normally
p;
Run as:
sed -i -n -f t $(git grep -l CONFIG_ARCH_SUNXI configs/*)
and then manually removing the one instance of CONFIG_SYS_EXTRA_OPTIONS="" from
Colombus_defconfig
board/sunxi/Makefile was updated with:
sed -e 's/^\(obj-\$(CONFIG_\)\(.*\)\().*+= dram_.*\)/\1TARGET_\2\3/g' board/sunxi/Makefile
and manually retabbing a few lines to line up again.
The board descriptions could certainly be improved.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Now we have CONFIG_ARCH_SUNXI as the toplevel, CONFIG_MACH_SUN[45678]I as the
per-SoC option and leave CONFIG_TARGET_BLAH free for individual boards in the
future.
Done automatically with:
sed -i -e 's/TARGET_\(SUN[45678]I\)/MACH_\1/g' $(git grep -l TARGET_SUN[45678]I)
And make TARGET_SUN[45678]I a choice variable under this.
configs updated with:
sed -i -e 's/^\(\+S:\)\?CONFIG_TARGET_SUN.I=y/\1CONFIG_ARCH_SUNXI=y\n&/g' configs/*
Patch is the result of:
sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h
sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
[ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove
redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
CONFIG_SPL is defined as a primary option in Kconfig.
It should not be added to CONFIG_SYS_EXTRA_OPTIONS.
Automatic booting using an extlinux.conf file requires various environment
variables to be set.
Also modify CONFIG_SYS_LOAD_ADDR and CONFIG_STANDALONE_LOAD_ADDR to match
the value chosen for kernel_addr_r, see the added comment for why the new
value is chosen.
Add support for boards which I own and which already have a dts file in the
upstream kernel.
Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net>
