path: root/configs/A13-OLinuXinoM_defconfig
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-31sunxi: Add CONFIG_MMC0_CD_PIN to various boardsHans de Goede
Add CONFIG_MMC0_CD_PIN to various boards, this stops the SPL from still trying to access the sdcard when there is none (e.g. when booting from nand). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-31sunxi: Drop LCD_MODE from A13-OLinuxIno defconfigsHans de Goede
With the unified / cleaned up default display output selection changes, which were done as part of adding composite video out support, our example LCD_MODE line in the A13-OLinuxIno defconfigs causes the display code to setup a LCD console by default, rather then a VGA console. Given that the LCD console is only useful for people who have hooked up the exact lcd-panel from the config, while most people will not have any lcd panel connected to these boards, this is not a good default. Dropping the LCD_MODE line which was intended as an example fixes this, instead add a link to the LCD_MODE help text pointing to http://linux-sunxi.org/LCD which contains the removed and other example modes. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: video: Force h/vsync active high when using ext. vga dac on some boardsHans de Goede
On both my A13-OLinuxIno and my A13-OLinuxIno-Micro, the vga output gives an unstable image when active low v or hsync is used. The problem seems to be specific to the OLinuxIno A13 (normal & micro) boards. I've just looked up the schematics and they use an opendrain driver for the vga sync lines, and with sync pulses it is the logical high->low edge of the pulse which counts for the timing, which with an active low sync is being driven by the pull-up, and that simply seems to not drive it hard enough to get a stable image. So force v and hsync active high on these boards. independent of what the modeline says. This fixes the unstable image. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Remove CONFIG_TARGET_FOO for sun5i and sun7i boardsHans de Goede
CONFIG_TARGET_FOO was only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), all sun5i and sun7i boards have been moved over to using a single dram_sun5i_autoconfig file, and the tx clk delay handling for the Banana boards now has its own Kconfig. IOW nothing is using CONFIG_TARGET_FOO anymore, so remove it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Convert sun5i boards to use auto dram configurationHans de Goede
Currently we've separate detailed dram settings for all sun5i boards, this moves them over to using auto dram configuration so that we can get rid of all the per board dram_foo.c files. This has been tested on a A10s-Olinuxino, A13-Olinuxino, A13-OlinuxinoM, mk802-a10s and r7-tv-dongle board. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: A13-OLinuXino defconfigs: Enable VGA output, add lcd-mode for 7" LCDHans de Goede
Enable VGA output on the A13-OLinuXino and A13-OLinuXinoM now that we've support for it. Also add LCD timing and gpio info for the Olimex 7" LCD module. We can safely put this in the default config on this boards, since by default we will always use VGA, and the LCD timing info will only get used if the user explicitly sets monitor=lcd in the video-mode env. variable. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-25sunxi: Add usb keyboard Kconfig optionHans de Goede
For use together with the hdmi console. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ian.campbell@citrix.com>
2014-11-25sunxi: video: Add cfb console driver for sunxiLuc Verhaegen
This adds a fixed mode hdmi driver for the sunxi platform. The fixed mode is a relatively safe 1024x768, more complete EDID handling is currently not provided. Only HDMI is supported today. This code is enabled when HPD detects an attached monitor. Current config is such that 8MB is shaved off at the top of the RAM. This avoids several memory handling issues, most significant is the fact that on linux on ARM you are not allowed to remap known RAM as IO. A clued in display driver will be able to recycle this reserved RAM in future though. cfbconsole was chosen as it provides the most important functionality: a working u-boot console, allowing for the debugging of certain issues without the need for a UART. Signed-off-by: Luc Verhaegen <libv@skynet.be> [hdegoede@redhat.com: Major cleanups and some small bugfixes] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sunxi: ehci: Add proper Kconfig options to select the usb Vbus gpio-sHans de Goede
Add proper Kconfig options to select the usb Vbus gpio-s, besides moving to Kconfig being the right thing to do, an added advantage of this is that it allows for boards without Vbus gpio-s. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05sunxi: kconfig: Introduce CONFIG_TARGET_<BOARD>Ian Campbell
This was done automatically with the following bits of scripting. The Kconfig choice content was generated with this script snippet: for i in $(git grep -l CONFIG_ARCH_SUNXI configs/*) ; do TARGET=$(sed -n -e 's/CONFIG_SYS_EXTRA_OPTIONS="\([^,"]\+\).*/\1/p' $i); MACH=$(sed -n -e 's/.*CONFIG_\(MACH_SUN.I\)=./\1/p' $i) echo "config TARGET_$TARGET" echo " bool \"$TARGET\"" echo " depends on $MACH" echo done defconfigs were updated with a sed script (t): # Extract board from first entry of CONFIG_SYS_EXTRA_OPTIONS, /^CONFIG_SYS_EXTRA_OPTIONS/ { s/^\(CONFIG_SYS_EXTRA_OPTIONS="\)\([^,"]\+\),\?\(.*\)/\1\3\nCONFIG_TARGET_\2=y/; # Print and delete first line (CONFIG_SYS_EXTRA_OPTIONS), leaving # CONFIG_TARGET_<BOARD> in pattern space P;D; }; # Move CONFIG_TARGET_<BOARD> to hold space /^CONFIG_TARGET/{h;n} # Print CONFIG_TARGET_<BOARD> after CONFIG_MACH_<SOC> in either SPL or # normal mode. /^CONFIG_MACH/{p;g;p;n}; /^\+S:CONFIG_MACH/{p;g;s/^CONFIG_TARGET/+S:&/;p;n}; # Print any remaining lines normally p; Run as: sed -i -n -f t $(git grep -l CONFIG_ARCH_SUNXI configs/*) and then manually removing the one instance of CONFIG_SYS_EXTRA_OPTIONS="" from Colombus_defconfig board/sunxi/Makefile was updated with: sed -e 's/^\(obj-\$(CONFIG_\)\(.*\)\().*+= dram_.*\)/\1TARGET_\2\3/g' board/sunxi/Makefile and manually retabbing a few lines to line up again. The board descriptions could certainly be improved. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Rename TARGET_SUN[45678]I to MACH_SUN[45678]I.Ian Campbell
Now we have CONFIG_ARCH_SUNXI as the toplevel, CONFIG_MACH_SUN[45678]I as the per-SoC option and leave CONFIG_TARGET_BLAH free for individual boards in the future. Done automatically with: sed -i -e 's/TARGET_\(SUN[45678]I\)/MACH_\1/g' $(git grep -l TARGET_SUN[45678]I) Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Add top-level ARCH_SUNXIIan Campbell
And make TARGET_SUN[45678]I a choice variable under this. configs updated with: sed -i -e 's/^\(\+S:\)\?CONFIG_TARGET_SUN.I=y/\1CONFIG_ARCH_SUNXI=y\n&/g' configs/* Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-09-05sunxi: Correct typo CONFIG_FTDFILE => CONFIG_FDTFILEIan Campbell
Patch is the result of: sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig Reported-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> [ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
2014-09-05kconfig: remove redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONSMasahiro Yamada
CONFIG_SPL is defined as a primary option in Kconfig. It should not be added to CONFIG_SYS_EXTRA_OPTIONS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-08-12sunxi: Add environment settings to make extlinux.conf booting workHans de Goede
Automatic booting using an extlinux.conf file requires various environment variables to be set. Also modify CONFIG_SYS_LOAD_ADDR and CONFIG_STANDALONE_LOAD_ADDR to match the value chosen for kernel_addr_r, see the added comment for why the new value is chosen. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-07-31sunxi: Enable EHCI on various sunxi boardsHans de Goede
Most sunxi boards have the EHCI controller hooked up, enable it on all relevant boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
