path: root/configs/A10-OLinuXino-Lime_defconfig
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-18sunxi: usb: Switch to Generic host controllersJagan Teki
Onc of key blocker for using USB Generic host controller drivers in Allwinner are CLK and RESET drivers, now these available for USB usage. So switch sunxi USB use EHCI and OHCI Generic controllers. Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD where it already have USB_EHCI_HCD Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-03-14sunxi: move CONFIG_SYS_TEXT_BASE out of defconfigsAndre Przywara
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence of moving the common definition shared by almost every sunxi board into 123 individual defconfig files. But the U-Boot start address for Allwinner boards is a platform decision which has been around for ages, so defining it in each *board* config file seems a bit over the top. Define the standard values (160MB into DRAM for most SoCs, with two SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from the individual defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-04-20sunxi: Convert CONFIG_SATAPWR to KconfigMylène Josserand
Convert the CONFIG_SATAPWR into kconfig. Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some defconfigs. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Convert SUNXI_EMAC to KconfigMylène Josserand
Convert the SUNXI_EMAC config to Kconfig. Remove it from SYS_EXTRA_OPTIONS from many sunxi defconfig and renamed it into SUN4I_EMAC to not confuse it with SUN8I_EMAC. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-03-26net: sunxi: Enable eeprom on OLinuXino Lime boardsoliver@schinagl.nl
This patch enables the I2C EEPROM to be probed for a MAC address on the OLinuXino Lime1 and Lime2 boards. Other boards surely qualify as well but were not tested yet. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
2016-11-28sunxi: Use the available Kconfig option for AHCIJelle van der Waa
Use the already available Kconfig option for AHCI. Tested on the BananaPi. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-31sunxi: Enable LDO3 and LDO4 at 2.8V on OLinuxIno Lime boardsHans de Goede
LDO3 and LDO4 are used to power port E resp. port G, which are exposed on gpio headers, so enable them at 2.8V as specified in the schematic. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-31sunxi: Add CONFIG_MMC0_CD_PIN to various boardsHans de Goede
Add CONFIG_MMC0_CD_PIN to various boards, this stops the SPL from still trying to access the sdcard when there is none (e.g. when booting from nand). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
