path: root/configs/3c120_defconfig
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD -> CONFIG_DM_MTDMiquel Raynal
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Add Kconfig files] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-10configs: Resync with savedefconfigTom Rini
2017-05-01fdt: Move fdt_fixup_ethernet to a common placeTom Rini
With 3f66149d9fb4 we no longer have a common call fdt_fixup_ethernet. This was fine to do on PowerPC as they largely had calls already in ft_cpu_fixup. On ARM however we largely relied on this call. Rather than introduce a large number of changes to ft_cpu_fixup / ft_board_fixup we recognize that this is a common enough call that we should be doing it in a central location. Do it early enough that we can do any further updates in ft_cpu_fixup / ft_board_fixup. Cc: Gerd Hoffmann <kraxel@redhat.com> Cc: Chen-Yu Tsai <wens@csie.org> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Thomas Chou <thomas@wytron.com.tw> (maintainer:NIOS) Cc: York Sun <york.sun@nxp.com> (maintainer:POWERPC MPC85XX) Cc: Stefan Roese <sr@denx.de> (maintainer:POWERPC PPC4XX) Cc: Simon Glass <sjg@chromium.org> Cc: Joakim Tjernlund <Joakim.Tjernlund@infinera.com> Fixes: 3f66149d9fb4 ("Remove extra fdt_fixup_ethernet() call") Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-20autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.cMasahiro Yamada
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards. Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile: # This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature. This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it. I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-19nios2: Enable support for fitImageMarek Vasut
The uImage format is legacy for years now, enable support for the fitImage format, which allows combining multiple files (kernel and dtb) into a single file, offers better protection of the payload and so on. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-11-12nios2: rename board nios2-generic to 3c120_devboardThomas Chou
Rename board nios2-generic to 3c120_devboard. Since nios2 is converted to driver model and device tree control of u-boot, the nios2-generic board directory is removed. We can rename the board back to a real board name. Now the boards maintained in u-boot mainline are the same as Linux kernel, namely 3c120 and 10m50. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
