path: root/configs/3c120_defconfig
2016-06-20autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.cMasahiro Yamada
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards. Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile: # This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature. This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it. I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-19nios2: Enable support for fitImageMarek Vasut
The uImage format is legacy for years now, enable support for the fitImage format, which allows combining multiple files (kernel and dtb) into a single file, offers better protection of the payload and so on. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-11-12nios2: rename board nios2-generic to 3c120_devboardThomas Chou
Rename board nios2-generic to 3c120_devboard. Since nios2 is converted to driver model and device tree control of u-boot, the nios2-generic board directory is removed. We can rename the board back to a real board name. Now the boards maintained in u-boot mainline are the same as Linux kernel, namely 3c120 and 10m50. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
