path: root/configs/10m50_defconfig
2016-06-20autoboot: add CONFIG_AUTOBOOT to allow to not compile autoboot.cMasahiro Yamada
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards. Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to not compile common/autoboot.c, as described in common/Makefile: # This option is not just y/n - it can have a numeric value ifdef CONFIG_BOOTDELAY obj-y += autoboot.o endif It was a bit odd to enable/disable code with an integer type option, but it was how this option worked before that commit, and several boards actually unset it to opt out of the autoboot feature. This commit adds a new bool option, CONFIG_AUTOBOOT, and makes CONFIG_BOOTDELAY depend on it. I chose "default y" for this option because most boards use the autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that had not set CONFIG_BOOTDELAY prior to the bad commit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-19nios2: Enable support for fitImageMarek Vasut
The uImage format is legacy for years now, enable support for the fitImage format, which allows combining multiple files (kernel and dtb) into a single file, offers better protection of the payload and so on. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-11-21nios2: 10m50: change to ns16550 uartThomas Chou
Change to ns16550 uart for 10m50 devboard based on a new Altera release. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-12nios2: add 10m50 devboard supportThomas Chou
Add 10m50 devboard support. It is based on the Golden Hardware Reference Design (GHRD), available at, http://rocketboards.org/foswiki/view/Documentation/ AlteraMAX1010M50RevCDevelopmentKitLinuxSetup Though we supported only one nios2-generic board in the past. Now, with the removal of the nios2-generic board dir, adding new nios2 boards to u-boot is easier than before. It should be helpful to add those boards supported in Linux mainline. There are only two such nios2 boards, the 3c120 devboard and 10m50 devboard. The nios2-generic is actually 3c120, and should restore the name. The 10m50 is this one. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Marek Vasut <marex@denx.de>
