path: root/config.mk
2006-10-09Coding style cleanupWolfgang Denk
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-06-10Merge with /home/hs/U-Boot/u-boot-devWolfgang Denk
2006-05-17Fix gcc 3.4.x AFLAGS setting for m68k platform.Marian Balakowicz
2006-05-09Fixes for gcc 3.4 based m68k toolchain,Marian Balakowicz
based on patch by Jate Sujjavanich.
2006-04-20Add MCF5282 support (without preloader)Heiko Schocher
relocate ichache_State to ram u-boot can run from internal flash Add EB+MCF-EV123 board support. Add m68k Boards to MAKEALL Patch from Jens Scharsig, 08 Aug 2005
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2006-03-07Cleanup (get rid of debug code that sneaked in)Wolfgang Denk
2006-02-28Added GPIO initialization of DF signal. Still not working.Markus Klotzbücher
2006-02-07This is the first commit for the u-boot zylonite port. The following has beMarkus Klotzbücher
done so far: * created zylonite board dir (based on lubbock) * extended some - but not all pxa sources and headers for Intel Monahans support (CONFIG_CPU_MONAHANS) * created Makefile zylonite target + MAKEALL entry * added some debug nonsense, remove later, grep for mk@tbd Status: compiles (eldk-4.0), and can be started with BDI, but runs forever and doesn't halt at breakpoints. Hmmm...
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-10-04Make sure only supported compiler options are usedWolfgang Denk
Import "cc-option" shell function from kernel and use it to get the correct ARM GCC options for individual CPUs Patch by Peter Pearse, 30 Jun 2005
2005-07-28* Patch by Eran LibertyEran Liberty
Add support for the Freescale MPC8349ADS board.
2004-10-09Patch by Steven Scholz, 16 Aug 2004:wdenk
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)" - creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0 - moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/ - moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/ into cpu/arm920t/$(SOC)/
2004-05-19Patch by Scott McNutt, 25 Apr 2004:LABEL_2004_05_19_2335wdenk
Add Nios GDB/JTAG Console support: - Add stubs to support gdb via JTAG. - Add support for console over JTAG. - Minor cleanup.
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2003-09-16* Modify XLB arbiter priorities on MPC5200 so all devices use samewdenk
priority; configure critical interrupts to be handled like external interrupts
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-06-21Patch by Murray Jensen, 20 Jun 2003:wdenk
- hymod update - cleanup (especially for gcc-3.x compilers)
2003-06-19Patches by Murray Jensen, 17 Jun 2003:wdenk
- Hymod board database mods: add "who" field and new xilinx chip types - provide new "init_cmd_timeout()" function so code external to "common/main.c" can use the "reset_cmd_timeout()" function before entering the main loop - add DTT support for adm1021 (new file dtt/adm1021.c; config slightly different. see include/configs/hymod.h for an example (requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and CFG_DTT_ADM1021 defined) - add new "eeprom_probe()" function which has similar args and behaves in a similar way to "eeprom_read()" etc. - add 8260 FCC ethernet loopback code (new "eth_loopback_test()" function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST) - gdbtools copyright update - ensure that set_msr() executes the "sync" and "isync" instructions after the "mtmsr" instruction in cpu/mpc8260/interrupts.c - 8260 I/O ports fix: Open Drain should be set last when configuring - add SIU IRQ defines for 8260 - allow LDSCRIPT override and OBJCFLAGS initialization: change to config.mk to allow board configurations to override the GNU linker script, selected via the LDSCRIPT, make variable, and to give an initial value to the OBJCFLAGS make variable - 8260 i2c enhancement: o correctly extends the timeout depending on the size of all queued messages for both transmit and receive o will not continue with receive if transmit times out o ensures that the error callback is done for all queued tx and rx messages o correctly detects both tx and rx timeouts, only delivers one to the callback, and does not overwrite an earlier error o logic in i2c_probe now correct - add "vprintf()" function so that "panic()" function can be technically correct - many Hymod board changes
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
2002-11-10* Vince Husovsky, 7 Nov 2002:LABEL_2002_11_10_2310wdenk
Add "-n" to linker options to get rid of "Not enough room for program headers" problem * Patch by David Müller, 05 Nov 2002 Rename CONFIG_PLL_INPUT_FREQ to CONFIG_SYS_CLK_FREQ so we can use an already existing name * Patch by Pierre Aubert, 05 Nov 2002 Hardware related improvements in FDC boot code * Patch by Holger Schurig, 5 Nov 2002: Make the PXA really change it's frequency * Patch by Pierre Aubert, 05 Nov 2002 Add support for slave serial Spartan 2 FPGAs * Fix uninitialized memory (MAC address) in 8xx SCC/FEC ethernet drivers
