path: root/config.mk
2014-02-19kbuild: move include directives of board configuration filesMasahiro Yamada
This commit changes the location of include directives of board configuration files. The purpose of this change is: - Slim down $(TOPDIR)/config.mk - Prevent $(TOPDIR)/Makefile from including the same configuration file twice - Do not include include/config.mk multiple times because ARCH, CPU, BOARD, VENDOR, SOC are exported Before this commit: - include/autoconf.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/autoconf.mk twice) - include/{spl,tpl}-autoconf.mk was included from $(TOPDIR)/config.mk - include/config.mk was included from $(TOPDIR)/Makefile and $(TOPDIR)/config.mk (This means $(TOPDIR)/Makefile included include/config.mk twice) After this commit: - include/autoconf.mk is included from $(TOPDIR)/Makefile and $(TOPDIR)/scripts/Makefile.build - include/{spl,tpl}-autoconf.mk is included from $(TOPDIR)/spl/Makefile and $(TOPDIR)/scripts/Makefile.build - include/config.mk is included from $(TOPDIR)/config.mk and $(TOPDIR)/spl/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19Makefile: move some flags to examples makefilesMasahiro Yamada
This commit moves some flags which are used under examples/ directory only. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move some flags to spl/MakefileMasahiro Yamada
Some flags are used for SPL (and TPL) build only. This commit moves them from config.mk to spl/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move more stuff to top MakefileMasahiro Yamada
2014-02-19Makefile: refactor include path settingsMasahiro Yamada
This commit merges commonly-used header include paths to UBOOTINCLUDE and NOSTDINC_FLAGS variables, which are placed at the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move more flags to the top MakefileMasahiro Yamada
Before this commit, most of compiler flags were defined in config.mk. But it is redundant because config.mk is included from all recursive make. This commit moves many complier flags to the top Makefile and export them. And we use new vaiarables to store them: KBUILD_CPPFLAGS, KBUILD_CFLAGS, KBUILD_AFLAGS. This will allow us to switch more smoothly to Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: Use Kbuild.includeMasahiro Yamada
This commit adjusts some files to use Kbuild.include. - Use cc-option defined in Kbuild.include (Delete cc-option in config.mk) - Use cc-version defined in (Delete cc-version in config.mk) - Move binutils-version and dtc-version to Kbuild.include by analogy to cc-version This commit also adds srctree (same as SRCTREE) to use Kbuild scripts. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move BFD_ROOT_DIR to tools/gdb/MakefileMasahiro Yamada
BFD_ROOT_DIR is used only in tools/gdb/Makefile Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makefile: move some variable definitions to the top MakefileMasahiro Yamada
This commit moves some variable definitions from config.mk to the top Makefile: - HOSTCC, HOSTCFLAGS, HOSTLDFLAGS - AS, LD, CC, CPP, etc. - SHELL (renamed to CONFIG_SHELL) I'd like to slim down config.mk file because it is included from all recursive make. It is redundant to re-define the variables every time descending into sub directories. We should rather define them at the top Makefile and export them. U-Boot makefiles has been used "SHELL" variable to store shell chosen for the user, whereas Linux Kernel uses "CONFIG_SHELL". We should never use "SHELL" variable because it is a special variable for GNU Make. Changing SHELL may cause unpredictable side effects whose root cause is usually difficult to find. We should use a generic variable name "CONFIG_SHELL". We should not use the syntax as follows either: rm -f $(obj)tools/env/{fw_printenv,fw_setenv} This depends on "bash" although GNU Make generally invokes "sh" to run the each rule. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Makfile: move suffix rules to Makefile.buildMasahiro Yamada
This commit moves suffix rules from config.mk to scripts/Makefile.build, which will allow us to switch smoothly to real Kbuild. Note1: post/lib_powerpc/fpu/Makefile has its own rule to compile C sources. We need to tweak it to keep the same behavior. Note2: There are two file2 with the same name: arch/arm/lib/crt0.S and eamples/api/crt0.S. To keep the same build behavior, examples/api/Makefile also has to be treaked. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19tools: convert makefiles to kbuild styleMasahiro Yamada
Before this commit, makefiles under tools/ directory were implemented with their own way. This commit refactors them by using "hostprogs-y" variable. Several C sources have been added to wrap other C sources to simplify Makefile. For example, tools/crc32.c includes lib/crc32.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-29sandbox: Use system headers first for sandbox's os.c in a different wayMasahiro Yamada
Commit cbe5cdfcd changed config.mk and arch/sandbox/cpu/Makefile to use -idirafter instead of -I and remove -nostdinc. But * Sandbox-specific code dirties config.mk * os.c is compiled without such compiler flags as: -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -fno-stack-protector -fstack-usage -Wno-format-nonliteral This commit use -idirafter and remove the -nostdinc differently and more simply. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-12-13Makefile: Move some scripts imported from LinuxMasahiro Yamada
We have some scripts imported from Linux Kernel: setlocalversion, checkstack.pl, checkpatch.pl, cleanpatch They are located under tools/ directory in U-Boot now. But they were originally located under scripts/ directory in Linux Kernel. This commit moves them to the original location. It is true that binutils-version.sh and dtc-version.sh do not originate in Linux Kernel, but they should be moved by analogy to gcc-version.sh. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-21sandbox: Use system headers first for sandbox's os.cSimon Glass
This file must be compiled with system headers, even if U-Boot has headers of the same name. The existing solution for this is good enough for libfdt, but fails when we have headers like stdint.h in U-Boot. Use -idirafter instead of -I, and remove the -nostdinc and other things that we don't want for this file. The best way to do this is to keep a copy of the original flags, rather than trying to filter them later. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-11-17config.mk: delete unnecessary linesMasahiro Yamada
SPL_BIN is already defined in spl/Makefile and it is used only in spl/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-08Makefile: do not create a symbolic link to arch/${ARCH}/include/asmMasahiro Yamada
In-tree build: - Do not create a symbolic link from include/asm to arch/${ARCH}/include/asm - Add ${SRCTREE}/arch/arm/include into the header search path Out-of-tree build: - Do not create a directory ${OBJTREE}/include2 - Do not create a symbolic link from ${OBJTREE}/include2/asm to ${SRCTREE}/arch/${ARCH}/include/asm - Add ${SRCTREE}/arch/arm/include into the header search path Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-09-06Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-06cam_enc_4xx: Move CONFIG_SPL_PAD_TO to a config headerMasahiro Yamada
For most boards which define CONFIG_SPL_PAD_TO, it is defined in config header files. Currently, there exists only one exception, cam_enc_4xx board. This patch moves CONFIG_SPL_PAD_TO definition from board/ait/cam_enc_4xx/config.mk to include/configs/cam_enc_4xx.h. With this modification, we can delete a glue code in the top level config.mk: ifneq ($(CONFIG_SPL_PAD_TO),) CPPFLAGS += -DCONFIG_SPL_PAD_TO=$(CONFIG_SPL_PAD_TO) endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Heiko Schocher <hs@denx.de>
2013-09-06config.mk: Delete unnecessary codeMasahiro Yamada
Currently no makefiles (board-specific config.mk) set the following variables: CONFIG_SPL_TEXT_BASE CONFIG_UBOOT_PAD_TO CONFIG_RESET_VECTOR_ADDRESS CONFIG_TPL_PAD_TO For all target boards using above macros they are set in header files (include/configs/*.h), so we do not need to set them as CPPFLAGS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-08-31ARM: mxs: tools: Add mkimage support for MXS bootstreamMarek Vasut
Add mkimage support for generating and verifying MXS bootstream. The implementation here is mostly a glue code between MXSSB v0.4 and mkimage, but the long-term goal is to rectify this and merge MXSSB with mkimage more tightly. Once this code is properly in U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage support. Note that the mxsimage generator needs libcrypto from OpenSSL, I therefore enabled the libcrypto/libssl unconditionally. MXSSB: http://git.denx.de/?p=mxssb.git;a=summary The code is based on research presented at: http://www.rockbox.org/wiki/SbFileFormat Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
2013-08-20TPL : introduce the TPL based on the SPLYing Zhang
Due to the nand SPL on some board(e.g. P1022DS)has a size limit, it can not be more than 4K. So, the SPL cannot initialize the DDR with the SPD code. This patch introduces TPL to enable a loader stub that is loaded by the code from the SPL. It initializes the DDR with the SPD or other operations. The TPL's size is sizeable, the maximum size is decided by the memory's size that TPL runs. It initializes the DDR through SPD code, and copys final uboot image to DDR. So there are three stage uboot images: * spl_boot, * tpl_boot, * final uboot image Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-19SPL: Makefile: Build a separate autoconf.mk for SPLJoel Fernandes
SPL defines CONFIG_SPL_BUILD but this does not percolate to the autoconf.mk Makefile. As a result the build breaks when CONFIG_SPL_BUILD is used in the board-specific include header file. With this, there is a possibility of having a CONFIG option defined in the header file but not defined in the Makefile causing all kinds of build failure and problems. It also messes things for up, for example, when one might want to undefine options to keep the SPL small and doesn't want to be stuck with the CONFIG options used for U-boot. Lastly, this also avoids defining special CONFIG_SPL_ variables for cases where some options are required in U-boot but not in SPL. We add a spl-autoconf.mk rule that is generated for SPL with the CONFIG_SPL_BUILD flag and conditionally include it for SPL builds. Signed-off-by: Joel Fernandes <joelf@ti.com> Signed-off-by: Ying Zhang <b40530@freescale.com>
2013-08-02Validate dtc is new enoughStephen Warren
Subsequent patches assume that dtc supports various recent features. These are available in dtc 1.4.0. Validate that dtc is at least that version. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-07-24Licenses: introduce SPDX Unique Lincense IdentifiersWolfgang Denk
Like many other projects, U-Boot has a tradition of including big blocks of License headers in all files. This not only blows up the source code with mostly redundant information, but also makes it very difficult to generate License Clearing Reports. An additional problem is that even the same lincenses are referred to by a number of slightly varying text blocks (full, abbreviated, different indentation, line wrapping and/or white space, with obsolete address information, ...) which makes automatic processing a nightmare. To make this easier, such license headers in the source files will be replaced with a single line reference to Unique Lincense Identifiers as defined by the Linux Foundation's SPDX project [1]. For example, in a source file the full "GPL v2.0 or later" header text will be replaced by a single line: SPDX-License-Identifier: GPL-2.0+ We use the SPDX Unique Lincense Identifiers here; these are available at [2]. Note: From the legal point of view, this patch is supposed to be only a change to the textual representation of the license information, but in no way any change to the actual license terms. With this patch applied, all files will still be licensed under the same terms they were before. Note 2: The apparent difference between the old "COPYING" and the new "Licenses/gpl-2.0.txt" only results from switching to the upstream version of the license which is differently formatted; there are not any actual changes to the content. Note 3: There are some recurring questions about linense issues, such as: - Is a "All Rights Reserved" clause a problem in GPL code? - Are files without any license header a problem? - Do we need license headers at all? The following excerpt from an e-mail by Daniel B. Ravicher should help with these: | Message-ID: <4ADF8CAA.5030808@softwarefreedom.org> | Date: Wed, 21 Oct 2009 18:35:22 -0400 | From: "Daniel B. Ravicher" <ravicher@softwarefreedom.org> | To: Wolfgang Denk <wd@denx.de> | Subject: Re: GPL and license cleanup questions | | Mr. Denk, | | Wolfgang Denk wrote: | > - There are a number of files which do not include any specific | > license information at all. Is it correct to assume that these files | > are automatically covered by the "GPL v2 or later" clause as | > specified by the COPYING file in the top level directory of the | > U-Boot source tree? | | That is a very fact specific analysis and could be different across the | various files. However, if the contributor could reasonably be expected | to have known that the project was licensed GPLv2 or later at the time | she made her contribution, then a reasonably implication is that she | consented to her contributions being distributed under those terms. | | > - Do such files need any clean up, for example should we add GPL | > headers to them, or is this not needed? | | If the project as a whole is licensed under clear terms, you need not | identify those same terms in each file, although there is no harm in | doing so. | | > - There are other files, which include both a GPL license header | > _plus_ some copyright note with an "All Rights Reserved" clause. It | > has been my understanding that this is a conflict, and me must ask | > the copyright holders to remove such "All Rights Reserved" clauses. | > But then, some people claim that "All Rights Reserved" is a no-op | > nowadays. License checking tools (like OSLC) seem to indicate this is | > a problem, but then we see quite a lot of "All rights reserved" in | > BSD-licensed files in gcc and glibc. So what is the correct way to | > deal with such files? | | It is not a conflict to grant a license and also reserve all rights, as | implicit in that language is that you are reserving all "other" rights | not granted in the license. Thus, a file with "Licensed under GPL, All | Rights Reserved" would mean that it is licensed under the GPL, but no | other rights are given to copy, modify or redistribute it. | | Warm regards, | --Dan | | Daniel B. Ravicher, Legal Director | Software Freedom Law Center (SFLC) and Moglen Ravicher LLC | 1995 Broadway, 17th Fl., New York, NY 10023 | (212) 461-1902 direct (212) 580-0800 main (212) 580-0898 fax | ravicher@softwarefreedom.org www.softwarefreedom.org [1] http://spdx.org/ [2] http://spdx.org/licenses/ Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-07-19mkimage: Use board config to get CONFIG_FIT_SIGNATURE valueSimon Glass
The value of this config variable is not available to image.h on the host, since the board config is not actually included. Bring this in so that mkimage will be built with image-signing support for sandbox at least. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-28mkimage: Build signing only if board has CONFIG_FIT_SIGNATURESimon Glass
At present mkimage is set up to always build with image signing support. This means that the SSL libraries (e.g. libssl-dev) are always required. Adjust things so that mkimage can be built with and without image signing, controlled by the presence of CONFIG_FIT_SIGNATURE in the board config file. If CONFIG_FIT_SIGNATURE is not enabled, then mkimage will report a warning that signing is not supported. If the option is enabled, but libraries are not available, then a build error similar to this will be shown: lib/rsa/rsa-sign.c:26:25: fatal error: openssl/rsa.h: No such file or directory Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add RSA support for image signingSimon Glass
RSA provides a public key encryption facility which is ideal for image signing and verification. Images are signed using a private key by mkimage. Then at run-time, the images are verified using a private key. This implementation uses openssl for the host part (mkimage). To avoid bringing large libraries into the U-Boot binary, the RSA public key is encoded using a simple numeric representation in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26Support tracing in config.mk when enabledSimon Glass
Use -finstrument-functions when tracing is enabled (make FTRACE=1). Tracing is not currently supported by SPL even if sufficient memory is available. When tracing is enabled, we #define FTRACE. This can be used by board config files to conditionally enable the tracing options. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-09build: Pull -DBUILD_TAG into separate ifdefMarek Vasut
Currently the base setting for CFLAGS is split in two possibilities, one with -DBUILD_TAG appended at the end and one without, the rest of CFLAGS is the same in both cases. Change this so CFLAGS are always set and the -DBUILD_TAG is appended in separate ifdef. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
2013-05-01Trigger generic board error only when buildingSimon Glass
At present the generic board error can occur when configuring U-Boot, or during distclean, but this is incorrect. The existing autoconf.mk may come from an earlier U-Boot configuration which is about to be overwritten. Make the error conditional so that it will only be triggered when we are actually building U-Boot. This avoids a problem where the system is being reconfigured to remove CONFIG_SYS_GENERIC_BOARD on an architecture that does not support it. Currently this will print an error and require the manual removal of include/autoconf.mk. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-04-22Makefile: Add target for combined u-boot.img & spl/u-boot.binStefan Roese
This new make target "u-boot-img-spl-at-end.bin" consists of the the real, full-blown U-Boot image and the U-Boot SPL binary directly attached to it. The full-blown U-Boot image has the mkimage header included, with its load-address and entry-point. This will be used by the upcoming lwmon5 PPC440EPx derivate board port. Signed-off-by: Stefan Roese <sr@denx.de>
2013-04-12Makefile: Move SHELL setup to config.mkBenoît Thébaudeau
make never uses the SHELL variable from the environment. Instead, it uses /bin/sh, or the value assigned to the SHELL variable by the Makefile. This makes the export of the SHELL variable useless for sub-makes (but still useful for the environment of recipes). However, we want all makes to use the same shell. This patch fixes this issue by moving the SHELL variable setup and export to the top config.mk, so that all Makefile-s including it use the same shell. Since BASH is used by default, this makes it possible to use things like 'echo -e ...' in sub-makes, which would otherwise fail e.g. with /bin/sh symlinked to /bin/dash on Ubuntu. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15__HAVE_ARCH_GENERIC_BOARD controls availabilty of generic boardSimon Glass
We are introducing a new unified board setup. Add a check to make sure that board config files do not define CONFIG_SYS_GENERIC_BOARD unless their architecture defines __HAVE_ARCH_GENERIC_BOARD __HAVE_ARCH_GENERIC_BOARD will currently not be the default setting, but we can switch this later when most architecture support generic board. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Add symbol handling for generic lists into MakefileMarek Vasut
This patch adds essential components for generation of the contents of the linker section that is used by the linker-generated array. All of the contents is held in a separate file, u-boot.lst, which is generated at runtime just before U-Boot is linked. The purpose of this code is to especially generate the appropriate boundary symbols around each subsection in the section carrying the linker-generated arrays. Obviously, the interim linker code for actual placement of the variables into the section is generated too. The generated file, u-boot.lst, is included into u-boot.lds via the linker INCLUDE directive in u-boot.lds . Adjustments are made in the Makefile and spl/Makefile so that the u-boot.lds and u-boot-spl.lds depend on their respective .lst files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Tested-by: Joe Hershberger <joe.hershberger@ni.com>
2012-10-15add check infrastructure, default sparseKim Phillips
Add support for running source code checkers on u-boot source, e.g., using sparse to aid with typechecking. This comes in especially handy as SoC vendors mix and match cores and devices with different endianness, thus here we add CHECK_ENDIAN to the otherwise linux kernel default CHECKFLAGS. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-15serial: Compile drivers/serial/serial.c by defaultMarek Vasut
Compile drivers/serial/serial.c by default both into SPL and into non-SPL builds, since CONFIG_SERIAL_MULTI is now the default state. Also having common/serial.c in by default now, it's pointless to keep -DCONFIG_SERIAL_MULTI in CPPFLAGS any longer, so remove it as well. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-10-15serial: Unconditionally enable CONFIG_SERIAL_MULTIMarek Vasut
Enable CONFIG_SERIAL_MULTI for all builds of U-Boot. That includes both SPL builds and non-SPL builds, everything. To avoid poluting this patch with removal of ifdef-endif constructions containing CONFIG_SERIAL_MULTI, the CONFIG_SERIAL_MULTI is temporarily added into CPPFLAGS in config.mk . This will be again removed in following patch. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-04tools, config.mk: add binutils-versionAllen Martin
Modeled after gcc-version, add function to get binutils version. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Wolfgang Denk <wd@denx.de>
2012-08-10config: Always use GNU ldKhem Raj
This patch makes sure that we always use the GNU ld. U-Boot uses certain construct e.g. OVERLAY which are not implemented in gold therefore it always needs GNU ld for linking. It works well if default linker in toolchain is GNU ld but in some cases we can have gold to be the default linker and also ship GNU ld but not as default in such cases its called $(PREFIX)ld.bfd, with this patch we make sure that if $(PREFIX)ld.bfd exists than we use that for our ld. This way it does not matter what the default ld is. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Signed-off-by: Khem Raj <raj.khem@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-07-07Makefile: Add u-boot.spr build target (SPEAr)Stefan Roese
On x600 (SPEAr600) U-Boot is appended to U-Boot SPL. Both images are created using mkimage (crc etc), so that the ROM bootloader can check its integrity. Padding needs to be done to the SPL image (with mkimage header) and not the binary. Otherwise the resulting image which is loaded/copied by the ROM bootloader to SRAM doesn't fit. The resulting image containing both U-Boot images is called u-boot.spr. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-05-15tools, config.mk: Add gcc-version.sh, cc-version test from LinuxTom Rini
Added from Linux - commit fde7d9049e55ab85a390be7f415d74c9f62dd0f9 Signed-off-by: Tom Rini <trini@ti.com>
2012-03-26config.mk: Check for -fstack-usage supportTom Rini
Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-03-26config.mk: Make cc-option create a file under include/generatedTom Rini
Testing for -fstack-usage requires the creation of an output file, which isn't possible with /dev/null. Signed-off-by: Tom Rini <trini@ti.com>
2011-11-07config.mk: use memoization in cc-option macro to speed up compilationDaniel Schwierzeck
Apply memoization to cc-option macro by caching the results of the gcc calls. This macro is called very often so using cached results leads to faster compilation times. The old behaviour can be restored by defining the config option CONFIG_CC_OPT_CACHE_DISABLE=y. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
