path: root/config.mk
2010-08-09config.mk: avoid -traditional-cpp on OS X 10.5Mike Frysinger
Simply trying to include a basic header file like stdlib.h on OS X 10.5 and then building with -traditional-cpp fails with lots of errors like: In file included from /usr/include/stdlib.h:63, from test.c:3: /usr/include/available.h:85: error: stray '#' in program /usr/include/available.h:85: error: syntax error before numeric constant /usr/include/available.h:86: error: stray '#' in program In the past, I hadn't noticed because the old logic for these flags were restricted to Darwin running on PowerPC systems while I'm running on an Intel system. But after some recent clean ups and changes, the flag was being applied to all Darwin systems and my host tools broke. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-26config.mk: use different host compiler for OS X 10.6Andreas Biessmann
Compiling tools subdirectory on Mac OS X 10.6 (Snow Leopard) complains about wrong syntax in system includes. In file included from /usr/include/stdio.h:444, from ../source/u-boot/include/compiler.h:26, from ../source/u-boot/lib/crc32.c:15: /usr/include/secure/_stdio.h:46: error: syntax error in macro parameter list This can be fixed by reverting the workaround for prior OS X releases in config.mk conditionally for OS X 10.6+. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Change directory-specific CFLAGS to use full pathPeter Tyser
Previously, a specific file or directory could be compiled with custom CFLAGS by adding a Makefile variable such as: CFLAGS_dlmalloc.o = <custom flags for common/dlmalloc.c> or CFLAGS_lib = <custom flags for lib directory> This method breaks down once multiple files or directories share the same path. Eg FLAGS_fileA = <custom flags> would incorrectly result in both dir1/fileA.c and dir2/fileA.c being compiled with <custom flags>. This change allows finer grained control which we need once we move lib_$ARCH to arch/$ARCH/lib/ and lib_generic/ to lib/. Without this change all lib/ directories would share the same custom CFLAGS. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Create CPUDIR variablePeter Tyser
The CPUDIR variable points to the location of a target's CPU directory. Currently, it is set to cpu/$CPU. However, using $CPUDIR will allow for more flexibility in the future. It lays the groundwork for reorganizing U-Boot's directory structure to support a layout such as: arch/$ARCH/cpu/$CPU/* (architecture with multiple CPU types) arch/$ARCH/cpu/* (architecture with one CPU type) Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-12-02makefiles: fixes for building build toolsScott Wood
Currently, some of the tools instead set CC to be HOSTCC in order to re-use some pattern rules -- but this fails when the user overrides CC on the make command line. Also, the HOSTCFLAGS in tools/Makefile are currently not being used because config.mk overwrites them. This patch adds static pattern rules for files that have been requested to be built with the native compiler using $(HOSTSRCS) and $(HOSTOBJS), and converts the tools to use them. It restores easylogo to using the host compiler, which was broken by commit 38d299c2db81bd889c601b5dfc12c4e83ef83333 (if this was an intentional change, please let me know -- but it seems to be a build tool). It restores -pedantic and the special flags for darwin and cygwin that were requested in tools/makefile (but keeps the flags added by config.mk) -- hopefully someone can test this on those platforms. It no longer conditionalizes -pedantic on not being darwin; it wasn't clear that that was intentional, and unless there's a real problem it's just inviting people to contribute non-pedantic patches to those files (I'm not a fan of -pedantic personally, but if it's on for one platform it should be on for all). HOST_LDFLAGS is renamed HOSTLDFLAGS for consistency with the previous HOST_CFLAGS to HOSTCFLAGS rename. A new HOSTCFLAGS_NOPED is made available for those files which currently cannot be built with -pedantic, and replaces the old FIT_CFLAGS. imls now uses the cross compiler properly, rather than by trying to reconstruct CC using the typoed $(CROSS_COMPILER). envcrc.c is now dependency-processed unconditionally -- previously it would be built without being on (HOST)SRCS if CONFIG_ENV_IS_EMBEDDED was not selected. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-09-09ppc/85xx: Introduce RESET_VECTOR_ADDRESS to handle non-standard link addressKumar Gala
Some board ports place TEXT_BASE at a location that would cause the RESET_VECTOR_ADDRESS not to be at 0xfffffffc when we link. By default we assume RESET_VECTOR_ADDRESS will be 0xfffffffc if the board doesn't explicitly set it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2009-08-23start a linker script helper fileMike Frysinger
Start a common header file for common linker script code (such as workarounds for older linkers) rather than doing this in the build system. As fallout, we no longer execute the linker every time config.mk is included by a build file (which can easily be 70+ times), but rather only execute it once. This also fixes a bug in the major version checking by creating a macro to easily compare versions and keep people from making the same common mistake (forgetting to check major and minor together). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-21Fix all linker scripts for older binutils versions (pre-2.16)Wolfgang Denk
Commit f62fb99941c6 fixed handling of all rodata sections by using a wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT() and SORT_BY_NAME(). Unfortunately these functions were only introduced with biunutils version 2.16, so the modification broke building with all tool chains using older binutils. This patch makes it work again. This is done by omitting the use of these functions for such old tool chains. This will result in slightly larger target binaries, as the rodata sections are no longer in optimal order alignment-wise which reauls in unused gaps, but the effect was found to be insignificant - especially compared to the fact that you cannot build U-Boot at all in the current state. As ld seems to have no support for conditionals we run the linker script through the C preprocessor which can be easily used to remove the unwanted function calls. Note that the C preprocessor must be run with the "-ansi" (or a "-std=") option to make sure all the system-specific predefined macros outside the reserved namespace are suppressed. Otherise, cpp might for example substitute "powerpc" to "1", thus corrupting for example "OUTPUT_ARCH(powerpc)" etc. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2009-08-21ARM: compiler options cleanup - improve tool chain supportWolfgang Denk
For some time there have been repeated reports about build problems with some ARM (cross) tool chains. Especially issues about (in)compatibility with the tool chain provided runtime support library libgcc.a caused to add and support a private implementation of such runtime support code in U-Boot. A closer look at the code indicated that some of these issues are actually home-made. This patch attempts to clean up some of the most obvious problems and make building of U-Boot with different tool chains easier: - Even though all ARM systems basicy used the same compiler options to select a specific ABI from the tool chain, the code for this was distributed over all cpu/*/config.mk files. We move this one level up into lib_arm/config.mk instead. - So far, we only checked if "-mapcs-32" was supported by the tool chain; if yes, this was used, if not, "-mabi=apcs-gnu" was selected, no matter if the tool chain actually understood this option. There was no support for EABI conformant tool chains. This patch implements the following logic: 1) If the tool chain supports "-mabi=aapcs-linux -mno-thumb-interwork" we use these options (EABI conformant tool chain). 2) Otherwise, we check first if "-mapcs-32" is supported, and then check for "-mabi=apcs-gnu" If one test succeeds, we use the first found option. 3) In case 2), we also test if "-mno-thumb-interwork", and use this if the test succeeds. [For "-mabi=aapcs-linux" we set "-mno-thumb-interwork" mandatorily.] This way we use a similar logic for the compile options as the Linux kernel does. - Some EABI conformant tool chains cause external references to utility functions like raise(); such functions are provided in the new file lib_arm/eabi_compat.c Note that lib_arm/config.mk gets parsed several times, so we must make sure to add eabi_compat.o only once to the linker list. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Dirk Behme <dirk.behme@googlemail.com> Cc: Magnus Lilja <lilja.magnus@gmail.com> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Sergey Kubushyn <ksi@koi8.net> Tested-by: Magnus Lilja <lilja.magnus@gmail.com> Tested-by: Andrzej Wolski <awolski@poczta.fm> Tested-by: Gaye Abdoulaye Walsimou <walsimou@walsimou.com> Tested-by: Tom Rix <Tom.Rix@windriver.com> Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-21Move architecture specific config.mk files into subdirsPeter Tyser
This cleans up U-Boot's toplevel directory a bit and makes the architecture 'config.mk' file naming and location similar to board and cpu 'config.mk' files Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-19config.mk: Remove unused HPATHShinya Kuribayashi
This variable is not unused anywhere. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2009-07-17config.mk: Remove $(PCI_CLOCK) referenceShinya Kuribayashi
The following commit introduced $(PCI_CLOCK) reference so that we could tweak `PCI_66M' definition via an environment variable. > commit f046ccd15c8bc9613bfd72916b761a127d36e5c6 > Author: Eran Liberty <liberty@freescale.com> > Date: Thu Jul 28 10:08:46 2005 -0500 > > * Patch by Eran Liberty > Add support for the Freescale MPC8349ADS board. But I suggest a removal of it for the following reasons: * In 2006, MPC8349ADS was merged into MPC8349EMDS port, and it seems that MPC8349EMDS port is PCI_66M free. * OTOH, PCI_66M is used by MPC832XEMDS an MPC8360EMDS ports, but they don't need $(PCI_CLOCK) environment variable at all. PCI_66M is automatically configured via $(BOARD)_config names with the help of $(findstring _66_,$@). * Unfortunately $(PCI_CLOCK) has been undocumented anywhere, so only a few people know the existence of it these days. * Keep config.mk independent from $(BOARD) as much as possible. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-14add %.c->%.i and %.c->%.s rulesMike Frysinger
The Linux kernel has some helper rules which allow you to quickly produce some of the intermediary files from C source. Specifically, you can create .i files which is the preprocessed output and you can create .s files which is the assembler output. This is useful when you are trying to track down header/macro expansion errors or inline assembly errors. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-14allow boards to customize compiler options on a per-file/dir basisMike Frysinger
With our Blackfin boards, we like to build the compression routines with -O2 as our tests show a pretty good size/speed tradeoff. For the rest of U-Boot though, we want to stick with the default -Os as that is mostly control code. So in our case, we would add a line like so to the board specific config.mk file: CFLAGS_lib_generic += -O2 Now all files under lib_generic/ will have -O2 appended to their build. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12config.mk: remove un-needed REMOTE_BUILD checkJean-Christophe PLAGNIOL-VILLARD
as $(obj) is empty when in tree build %.s: %.S $(CPP) $(AFLAGS) -o $@ $< and $(obj)%.s: %.S $(CPP) $(AFLAGS) -o $@ $< are the same Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-01-18build system: treat all Darwin's alikeMike Frysinger
The x86 based version of Darwin behaves the same quirky way as the powerpc Darwin, so only check HOSTOS when setting up Darwin workarounds. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-12-08Remove unneeded CONFIG_SHELL referencesPeter Tyser
Make should be using the bash shell by default which makes CONFIG_SHELL unnecessary Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-09-12make: Remove redundant __ARM__ addition when cross-compiling on *BSDShinya Kuribayashi
__ARM__ is given by arm_config.mk automatically. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-09-07config.mk: Move arch-specific condition to $(ARCH)_config.mkShinya Kuribayashi
2008-06-26Conditionally add -fno-stack-protector to CFLAGSHaavard Skinnemoen
When compile-testing on powerpc, I get errors like this: net/nfs.c:422: undefined reference to `__stack_chk_fail_local' This seems to be because -fstack-protector is on by default, so let's explicitly disable it on all architectures that support the option. The Ubuntu toolchain is affected by this problem, and according to Mike Frysinger, Gentoo has been running with SSP enabled for years. More and more distros are turning SSP on by default, so this problem is likely to get worse in the future. Also, powerpc just happens to be one of the arches I do compile-testing on. There may be other arches affected by this too. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-05-03config.mk: use correct (cross) compilerWolfgang Denk
Some config.mk files reference $(CC) to test for specific tool chain features, so make sure $(CC) gets set before including any such config files. This patch replaces commit b7166e05a5 ("ColdFire: Get information from the correct GCC"). Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-22include autoconf.mk before any other .mk filesMike Frysinger
This bumps the autoconf.mk include step above board/cpu/arch/etc... so that those .mk files can have make if statements based on the current config. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14Only use TEXT_BASE if defined by the boardMike Frysinger
2008-02-04generate u-boot.ldr for Blackfin targetsMike Frysinger
2007-11-20[BUILD] Generate include/autoconf.mk from board config filesGrant Likely
Use cpp and sed to postprocess config.h and import the defined values into include/autoconf.mk. autoconf.mk is then included by config.mk to give 'make' access to the board configuration. Doing this enables conditional compilation at the Makefile level instead of by wrapping every .c file with #ifdef/#endif wrappers. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-11-03blackfin: Move `-D__BLACKFIN__' to $(ARCH)_config.mkShinya Kuribayashi
2007-03-09[Blackfin][PATCH-2/2] Common files changed to support bf533 platformAubrey.Li
2006-10-29Automatically adjust ARFLAGS so "make -s" is really silent.Wolfgang Denk
2006-10-27Don't pass any debug options directly to the assemblerHaavard Skinnemoen
When passing the -g option to gcc, gcc automatically selects a suitable --g<format> option to pass on to the assembler. Thus, there's no point in forcing a specific debug option on the assembler using the -Wa mechanism. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2006-10-24Use -g instead of -gstabs in AFLAGS_DEBUGWolfgang Denk
Patch by Haavard Skinnemoen, 30 Aug 2006 In config.mk, -Wa,-gstabs is unconditionally appended to AFLAGS no matter what the target's preferred debugging format is. This patch simply replaces -gstabs with -g, so that the default debugging format for the architecture is used.
2006-10-09Coding style cleanupWolfgang Denk
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-06-10Merge with /home/hs/U-Boot/u-boot-devWolfgang Denk
2006-05-17Fix gcc 3.4.x AFLAGS setting for m68k platform.Marian Balakowicz
2006-05-09Fixes for gcc 3.4 based m68k toolchain,Marian Balakowicz
based on patch by Jate Sujjavanich.
2006-04-20Add MCF5282 support (without preloader)Heiko Schocher
relocate ichache_State to ram u-boot can run from internal flash Add EB+MCF-EV123 board support. Add m68k Boards to MAKEALL Patch from Jens Scharsig, 08 Aug 2005
2006-03-12Add ADI Blackfin supportWolfgang Denk
- add support for Analog Devices Blackfin BF533 CPU - add support for the ADI BF533 Stamp uClinux board - add support for the ADI BF533 EZKit board Patches by Richard Klingler, June 11th 2005:
2006-03-07Cleanup (get rid of debug code that sneaked in)Wolfgang Denk
2006-02-28Added GPIO initialization of DF signal. Still not working.Markus Klotzbücher
2006-02-07This is the first commit for the u-boot zylonite port. The following has beMarkus Klotzbücher
done so far: * created zylonite board dir (based on lubbock) * extended some - but not all pxa sources and headers for Intel Monahans support (CONFIG_CPU_MONAHANS) * created Makefile zylonite target + MAKEALL entry * added some debug nonsense, remove later, grep for mk@tbd Status: compiles (eldk-4.0), and can be started with BDI, but runs forever and doesn't halt at breakpoints. Hmmm...
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-10-04Make sure only supported compiler options are usedWolfgang Denk
Import "cc-option" shell function from kernel and use it to get the correct ARM GCC options for individual CPUs Patch by Peter Pearse, 30 Jun 2005
