When enumerating devices, honour the pci_skip_dev() function. This can
be used by PCI controller drivers to restrict which devices will be
probed.
This is required by the NVIDIA Tegra PCIe controller driver, which will
fail with a data abort exception if an access is attempted to a device
number larger than 0 outside of bus 0. pci_skip_dev() is therefore
implemented to prevent any such accesses.
Signed-off-by: Thierry Reding <treding@nvidia.com>
When listing the devices on a PCI bus, the current code will blindly try
to access all devices. Internally this causes pci_bus_to_hose() to be
repeatedly called and output an error message every time. Prevent this
by calling pci_bus_to_hose() once and abort early if no bus was found.
Some filesystems have a UUID stored in its superblock. To
allow using root=UUID=... for the kernel command line we
need a way to read-out the filesystem UUID.
changes rfc -> v1:
- make the environment variable an option parameter. If not
given, the UUID is printed out. If given, it is stored in the env
variable.
- corrected typos
- return error codes
changes v1 -> v2:
- fix return code of do_fs_uuid(..)
- document do_fs_uuid(..)
- implement fs_uuid_unsuported(..) be more consistent with the
way other optional functionality works
changes v2 -> v3:
- change ext4fs_uuid(..) to make use of #if .. #else .. #endif
construct to get rid of unreachable code
Hit any key to stop autoboot: 0
=> fsuuid
fsuuid - Look up a filesystem UUID
Usage:
fsuuid <interface> <dev>:<part>
- print filesystem UUID
fsuuid <interface> <dev>:<part> <varname>
- set environment variable to filesystem UUID
=> fsuuid mmc 0:1
d9f9fc05-45ae-4a36-a616-fccce0e4f887
=> fsuuid mmc 0:2
eb3db83c-7b28-499f-95ce-9e0bb21cda81
=> fsuuid mmc 0:1 uuid1
=> fsuuid mmc 0:2 uuid2
=> printenv uuid1
uuid1=d9f9fc05-45ae-4a36-a616-fccce0e4f887
=> printenv uuid2
uuid2=eb3db83c-7b28-499f-95ce-9e0bb21cda81
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
We had the problem on an AM33xx platform, that SPL detected an
unsupported boot-device. But since this message is a debug message
it took a bit of time to really know, where the hangup in SPL
resulted from. So let's change this debug message to a printf
and also print the detected boot-device that is not supported.
This makes debugging of such cases much easier.
Cc: Tom Rini <trini@ti.com>
Acked-by: Heiko Schocher <hs@denx.de>
U-Boot has never cared about the type when we get max/min of two
values, but Linux Kernel does. This commit gets min, max, min3, max3
macros synced with the kernel introducing type checks.
Many of references of those macros must be fixed to suppress warnings.
We have two options:
- Use min, max, min3, max3 only when the arguments have the same type
(or add casts to the arguments)
- Use min_t/max_t instead with the appropriate type for the first
argument
Acked-by: Pavel Machek <pavel@denx.de>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
[trini: Fixup arch/blackfin/lib/string.c]
Factor out the common code to make it easier to adjust it.
Reviewed-by: Tom Rini <trini@ti.com>
When enabled, set up driver model for SPL. This allows SPL to use the same
drivers as the main U-Boot.
Acked-by: Tom Rini <trini@ti.com>
Set up the simple malloc() implementation when requested, in preference to
the full malloc().
The simple malloc() implementation is used when memory is tight. It provides
a simple buffer with an incrementing pointer.
At present the implementation is inside dlmalloc. Move it into its own file
so that it is easier to find.
Rather than using relocation as a signal that the full malloc() is
available, add a special GD_FLG_FULL_MALLOC_INIT flag. This signals that the
simple malloc() should no longer be used.
In some cases, such as SPL, even the code space used by the full malloc() is
wasteful. Add a CONFIG_SYS_MALLOC_SIMPLE option to provide only the simple
malloc. In this case the full malloc is not available at all. It saves about
1KB of code space and about 0.5KB of data on Thumb 2.
These are no-longer needed so drop them.
For some CPUs, having malloc() available very early is useful. There is no
reason to delay this since early malloc is allocated before board_init_f()
is called.
Move early malloc() init nearer to the start of the init sequence.
Instead of an x86-specific cpu_init_f() function, use the normal U-Boot one
for this purpose. Also remove a useless/misleading comment.
Instead of having an x86-specific DRAM init function, adjust things so we
can use the normal one.
Use these new functions where possible. They default to a value of 2 so we
cannot use them in some places where we need a default value of 1.
This function is only called within this file so make it static. Also
fix its argument types to be consistent with its caller.
Acked-by: Anatolij Gustschin <agust@denx.de>
Add an additional function for adding information to the device tree before
booting. This permits additions which are not board-specific.
The message about needing to reset should be printed no matter what error
is printed. Also, an error should always be printed.
This function is useful for ensuring that a node exists. Export it so it
can be used more widely.
Since this function can fail, print a message when it does.
Addressing was completely broken for cmd_fpgad.
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
enable to boot only a raw u-boot.bin image from nand with the
CONFIG_SPL_NAND_RAW_ONLY define. This option saves space on
boards where spl space is low.
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Reviewed-by: Bo Shen <voice.shen@atmel.com>
mcc200 and prs200 are old and have no maintainer. Remove the boards.
This also removes the mcc200 specific 1bpp BMP support from
common/lcd.c
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: York Sun <yorksun@freescale.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
When DEBUG is set, output memory region used for malloc().
Skip enclosure service devices when probing for usb storage devices.
This avoids long timeouts when probing for external usb harddisks
which provide "Enclosure Services".
Signed-off-by: Soeren Moch <smoch@web.de>
This is a new version of the patch
"usb_storage: skip all unknown devices when probing"
http://http://lists.denx.de/pipermail/u-boot/2014-November/194622.html
This file got corrupted by the automatic editin of commit 1a45966 "Add
GPL-2.0+ SPDX-License-Identifier to source files"; restore the
opiginal content and manually insert the SPDX ID.
The bug was detected by running cppcheck, which reported:
[common/cmd_fitupd.c:8]: (error) Invalid number of character ({) when
these macros are defined: 'CONFIG_UPDATE_TFTP'.
run_command() returns success even if the command had a syntax error;
correct this behaviour.
Signed-off-by: Rabin Vincent <rabin@rab.in>
Acked-by: Simon Glass <sjg@chromium.org)
Hush segfaults if it sees a syntax error while attempting to parse a
command:
$ ./u-boot -c "'"
syntax error
Segmentation fault (core dumped)
This is due to a NULL pointer dereference of in_str->p in static_peek().
The problem is that the exit condition for the loop in
parse_stream_outer() checks for rcode not being -1, but rcode is only
ever 0 or 1.
Tested-by: Simon Glass <sjg@chromium.org)
Attempting to run:
- an empty string
- a string with just spaces
returns different error codes, 1 for the empty string and 0
for the string with just spaces. Make both of them return
0 for consistency.
Attempting to run the sandbox leads to a segfault, because some dynamic
libraries (outside of u-boot) attempt to use malloc() to allocate memory
before u-boot's gd variable is initialized.
Check for gd not being NULL in the SYS_MALLOC_F_LEN handling, so that
malloc() doesn't crash when called at this point.
$ gdb -q --args ./u-boot
(gdb) r
Program received signal SIGSEGV, Segmentation fault.
0x0000000000412b9b in malloc (bytes=bytes@entry=37) at common/dlmalloc.c:2184
2184 if (!(gd->flags & GD_FLG_RELOC)) {
(gdb) p gd
$1 = (gd_t *) 0x0
(gdb) bt
#0 0x0000000000412b9b in malloc (bytes=bytes@entry=37) at common/dlmalloc.c:2184
#1 0x00007ffff75bf8e1 in set_binding_values (domainname=0x7ffff11f4f12 "libgpg-error", dirnamep=0x7fffffffe168, codesetp=0x0)
at bindtextdom.c:228
#2 0x00007ffff75bfb4c in set_binding_values (codesetp=0x0, dirnamep=0x7fffffffe168, domainname=<optimized out>) at bindtextdom.c:350
#3 __bindtextdomain (domainname=<optimized out>, dirname=0x7ffff11f4f00 "/usr/share/locale") at bindtextdom.c:348
#4 0x00007ffff11eca17 in ?? () from /lib/x86_64-linux-gnu/libgpg-error.so.0
#5 0x00007ffff7dea9fa in call_init (l=<optimized out>, argc=argc@entry=1, argv=argv@entry=0x7fffffffe208,
env=env@entry=0x7fffffffe218) at dl-init.c:78
#6 0x00007ffff7deaae3 in call_init (env=0x7fffffffe218, argv=0x7fffffffe208, argc=1, l=<optimized out>) at dl-init.c:36
#7 _dl_init (main_map=0x7ffff7ffe1a8, argc=1, argv=0x7fffffffe208, env=0x7fffffffe218) at dl-init.c:126
#8 0x00007ffff7ddd1ca in _dl_start_user () from /lib64/ld-linux-x86-64.so.2
I believe that when no DTB is around we should return 1.
This why I fixed such scenarious to not return zero anymore.
Else kernel might get NULL pointer to DTB which doesn't exists.
Signed-off-by: Noam Camus <noamc@ezchip.com>
Waiting an interrupt packet to complete in usb_kbd_poll_for_event, causes
a 40 ms latency for each call to usb_kbd_testc, which is undesirable.
Using control messages leads to lower (but still not 0) latency, but some
devices do not work well with control messages (e.g. my kvm behaves funny
with them).
This commit adds support for using the int_queue mechanism which at least
the ehci-hcd driver supports. This allows polling with 0 latency, while
using interrupt packets.
Instead of looking them up every time we need them.
stdio_register makes a malloc-ed copy of struct stdio_dev through stdio_clone,
free the malloc-ed memory on stdio_deregister.
Free the keyboard hid-report buffer and private data on deregister.
This is not used anywhere, so lets remove it.
Do as the Linux kernel does and power on any ports which are not yet one,
this is enough.
If the device has a parent, it is instantiated from usb_hub_port_connect_change
and the portnr is right there in dev->portnr, so there is no need for this
whole dance to look it up.
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This is a bit odd in that we are permitted to boot images for either, even
though they are separate architectures.
Commit ae83d882f5fdf7aa7c5aec09cfafb593153c25d6 moved the fixed size mentioned
in the comment but missed the comment.
This patch makes the following changes:
- Set kernel entry point correctly
- Append bootargs from image to global bootargs instead
of replacing them
- Return end address instead of size from android_image_get_end()
- Give correct parameter to genimg_get_format() in boot_get_ramdisk()
- Move ramdisk message printing from android_image_get_kernel() to
android_image_get_ramdisk()
Signed-off-by: Ahmad Draidi <ar2000jp@gmail.com>
Actually, unmap_sysmem() does nothing. Just in case.
- Do not insert a whitespace between a function name and
an open paranthesis
- Fix comment style
- Do not split an error message into multiple lines
even if it exceeds 80 columns
- Do not split "for" statement where it fits in 80 columns
- Do not use assignment in if condition
CHUNK_TYPE_DONT_CARE should skip over the specified number of blocks, but
currently fails to increment the device block address. This results in
filesystem images getting written incorrectly. Add the missing block
address incrementing.
Cc: Steve Rae <srae@broadcom.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Steve Rae <srae@broadcom.com>
allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT.
Do not hang in spl_register_fat_device but return an error value.
It allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT.
If FAT load fails, then EXT load is tried.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Add EXT filesystem support to SPL.
[trini: Fix a warning and checkpatch problems]
