This commit provides distinction between DFU device detach and reset.
The -R behavior is preserved with proper handling of the dfu-util's -e
switch, which detach the DFU device.
By running dfu-util -e; one can force device to finish the execution of
dfu command on target and execute some other scripted commands.
Moreover, some naming has been changed - the dfu_reset() method now is known
as dfu_detach(). New name better reflects the purpose of the code.
It was also necessary to increase the number of usb_gadget_handle_interrupts()
calls since we also must wait for detection of the USB reset event.
Example usage:
1. -e (detach) switch
dfu-util -a0 -D file1.bin;dfu-util -a3 -D uImage;dfu-util -e
access to u-boot prompt.
2. -R (reset) switch
dfu-util -a0 -D file1.bin;dfu-util -R -a3 -D uImage
target board reset
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
The gpio command mostly relies on gpio_request() and gpio_free() being
nops, in that you can request a GPIO twice. With driver model this is
now implemented correctly, so it fails.
Change the command to deal with a failure to claim the GPIO.
The GPIO list is very long in many cases and most of them are not used.
By default, show only the GPIOs that are in use, and provide a flag to show
all of them. This makes the 'gpio status' command much more pleasant.
In order to do this, driver model now exposes a method for obtaining the
'function' of a GPIO, which describes whether it is an input or output, for
example. Implementation of this method is optional.
The default format for arm64 Linux kernels is the "Image" format,
described in Documentation/arm64/booting.txt. This, along with an
optional gzip compression on top is all that is generated by default.
The Image format has a magic number within the header for verification,
a text_offset where the Image must be run from, an image_size that
includes the BSS and reserved fields.
This does not support automatic detection of a gzip compressed image.
One specific USB 3.0 device behaves strangely when reset by
usb_new_device()'s call to hub_port_reset(). For some reason, the device
appears to briefly drop off the bus when this second bus reset is
executed, yet if we retry this loop, it'll eventually come back after
another two resets.
If USB bus reset is executed over and over within usb_new_device()'s call
to hub_port_reset(), I see the following sequence of results, which
repeats as long as you want:
1) STAT_C_CONNECTION = 1 STAT_CONNECTION = 0 USB_PORT_STAT_ENABLE 0
2) STAT_C_CONNECTION = 1 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 0
3) STAT_C_CONNECTION = 1 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 1
The device in question is a SanDisk Ultra USB 3.0 16GB memory stick with
USB VID/PID 0x0781/0x5581.
In order to allow this device to work with U-Boot, ignore the
{C_,}CONNECTION bits in the status/change registers, and only use the
ENABLE bit to determine if the reset was successful.
To be honest, extensive investigation has failed to determine why this
problem occurs. I'd love to know! I don't know if it's caused by:
* A HW bug in the device
* A HW bug in the Tegra USB controller
* A SW bug in the U-Boot Tegra USB driver
* A SW bug in the U-Boot USB core
This issue only occurs when the device's USB3 pins are attached to the
host; if only the USB2 pins are connected the issue does not occur. The
USB3 controller on Tegra is in reset, so is not actively communicating
with the device at all - a USB3 analyzer confirms this. Slightly
unplugging the device (so the USB3 pins don't contact) or using a USB2
cable or hub as an intermediary avoids the problem. For some reason,
the Linux kernel (either on the same Tegra board, or on an x86 host)
has no issue with the device, and I observe no disconnections during
reset.
This change won't affect any USB device that already works, since such
devices could not currently be triggering the error return this patch
removes, or they wouldn't be working currently.
However, this patch is quite reliable in practice, hence I hope it's
acceptable to solve the problem.
The only potential fallout I can see from this patch is:
* A broken device that triggers C_CONNECTION/!CONNECTION now causes the
loop in hub_port_reset() to run multiple times. If it never succeeds,
this will cause "usb start" to take roughly 1s extra to execute.
* If the user unplugs a device while hub_port_reset() is executing, and
very quickly swaps in a new device, hub_port_reset() might succeed on
the new device. This would mean that any information cached about the
original device (from the descriptor read in usb_new_device(), which
simply caches the max packet size) might be invalid, which would cause
problems talking to the new device. However, without this change, the
new device wouldn't work anyway, so this is probably not much of a
loss.
As we support both Host and Device mode operation, an OTG controller
can return -ENODEV on a port which it found to be in Device mode during
Host mode scan for devices. In case -ENODEV is returned, print that the
port is not available and continue instead of screaming a bloody error
message.
Commit e3a5bbce broke the FIT image tests by not loading a ramdisk even if
a load address is provided in the FIT. The rationale was that a load address
of 0 should be considered to mean 'do not load'.
Add a new load operation which supports this feature, so that the ramdisk
will be loaded if a non-zero load address is provided.
resync ubi subsystem with linux:
commit 455c6fdbd219161bd09b1165f11699d6d73de11c
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Sun Mar 30 20:40:15 2014 -0700
Linux 3.14
A nice side effect of this, is we introduce UBI Fastmap support
to U-Boot.
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Joerg Krause <jkrause@posteo.de>
CONFIG_SPL_NET_SUPPORT is not the only time we want SPL to ahve
environment, CONFIG_SPL_ENV_SUPPORT is when we want it.
This patch implements the generic board init as described in
doc/README.generic-board.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
arg[0] might not be NULL even if argc < 1, so fix this as before.
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Commit b3dd64f5d537 "bootm: use genimg_get_kernel_addr()" introduced
a bug for booting FIT image. It's because calling fit_parse_config()
twice will give us wrong value in img_addr.
Add a new function genimg_get_kernel_addr_fit() whichl will always
return fit_uname_config and fit_uname_kernel for CONFIG_FIT.
genimg_get_kernel_addr() will ignore those to parameters.
Reported-by: York Sun <yorksun@freescale.com>
Use cli_simple_process_macros, so that environment
variables (e.g. ${console}) can be used in append strings.
This allows u-boot to load different OS or Bare Metal application on
different cores of the i.MX6 SoC.
For example: running Android on cpu0 and a RT OS like QNX/FreeRTOS on cpu1.
Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
add missing put_mtd_device, so mtd->usecount gets correct
decremented in get_mtd_info().
Cc: Tom Rini <trini@ti.com>
most todays LCDs support 32bpp e.g. the framebuffer memory is 32bpp
organized.
To support 24bpp BMPs we need to take only 3 byte from the bpp and set
one byte from the FB to 0.
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
prevents a clang warning that the function is
never used.
cc: agust@denx.de
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
This patch removes following two functions:
- lcd_getbgcolor(...)
not used somewhere outside lcd.c, internally we use now the global
variable lcd_color_bg (was return value of function before)
- lcd_getfgcolor(...)
not used in any place of u-boot
[agust: rebased]
- Adds support for 32-bit organized framebuffers to the LCD-framework.
Cc: agust@denx.de
We must ensure the buffer we read the env into is aligned or we may get
warnings later on.
Use the new API which is originally taken out from boot_get_kernel
of bootm.c
[trini: Fix warnings with CONFIG_FIT]
Trying bootm for zImage will print out several error message which
is not necessary for this case. So detect image format firstly, only
try bootm for legacy and FIT format image then try bootz for others.
This patch needs new function genimg_get_kernel_addr().
Kernel address is normally stored as a string argument of bootm or bootz.
This function is taken out from boot_get_kernel() of bootm.c, which can be
reused by others.
Since libfdt now has an fdt_resize() function, we need to rename the
U-Boot one.
Fix ext4load help text.
Signed-off-by: Pavel Machek <pavel@denx.de>
I happened to spot this while working in the area.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
When "pxe boot" downloads the initrd/kernel/DTB, netboot_common() saves
the downloaded filename to global variable BootFile. If the boot
operation is aborted, this global state is not cleared. If "dhcp" is
executed later without any arguments, BootFile is not cleared, and when
the DHCP response is received, BootpCopyNetParams() writes the value into
environment variable bootfile.
This causes the following scenario:
* Boot script executes dhcp; pxe get; pxe boot
* User CTRL-C's the PXE menu, which causes the first menu item to be
booted, which causes some file to be downloaded.
(This boot-on-CTRL-C behaviour is arguably a bug too, but it's a
separate bug and the bug this patch fixes would still exist if the user
simply waited to press CTRL-C until "pxe boot" started downloading
files)
* User CTRL-C's the file downloads, but the filename is still written to
the bootfile environment variable.
* User re-runs the boot command, which in my case executes "dhcp; pxe get;
pxe boot" again, and "dhcp" picks up the saved bootfile environment
variable and proceeds to download a file that it shouldn't.
To solve this, modify the implementation of "pxe get" to clear BootFile
if the whole boot operation fails, which avoids this whole mess.
An alternative would be to modify netboot_common() such that the no-
arguments case explicitly clears the global variable BootFile. However,
that would prevent the following command sequences from working:
$ dhcp filename # downloads "filename"
$ dhcp # downloads $bootfile, i.e. "filename"
or:
$ setenv bootfile filename
... and I assume someone relies on U-Boot working that way.
Commit d4f5ef59cc7 "dfu: defer parsing of device string to IO backend" changed
the function signature of dfu_init_env_entities(). Adjust cmd_thordown.c
to match that change.
Also, apply the same change as commit d6d37d737b58e "dfu: free entities
when parsing fails" to cmd_thordown.c.
Fixes: d4f5ef59cc7 ("dfu: defer parsing of device string to IO backend")
Devices are not all identified by a single integer. To support
this, defer the parsing of the device string to the IO backed, so that
it can apply the appropriate rules.
SPI devices are specified as controller:chip_select. SPI/SF support will
be added soon.
MMC devices can also be specified as controller[.hwpart][:partition] in
many commands, although we don't support that syntax in DFU.
These commands may be used to determine the size of a file without
actually reading the whole file content into memory. This may be used
to determine if the file will fit into the memory buffer that will
contain it. In particular, the DFU code will use it for this purpose
in the next commit.
- init hardware watchdog if applicable
- use CONFIG_SYS_MONITOR_LEN as the gd monitor len for Blackfin
- reserve u-boot memory at the top field of the RAM for Blackfin
- avoid refer to CONFIG_SYS_MONITOR_LEN, which is not defined by Blackfin
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Add callback with __weak annotation to allow setup of environment
partition number in runtime from a board file.
Propagate mmc_switch_part() return value into init_mmc_for_env() instead
of -1 in case of failure.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
Some architecture needs extra device tree setup. Instead of adding
yet another hook, convert arch_fixup_memory_node to be a generic
FDT fixup function.
[maz: collapsed 3 patches into one, rewrote commit message]
Signed-off-by: Ma Haijun <mahaijuns@gmail.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Use CONFIG_SOC_KEYSTONE in common places instead of defining
a lot of "if def .. || if def " for different Keystone2 SoC types.
Acked-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
For sandbox we have a fallback console which is used very early in
U-Boot, before serial drivers are available. Rather than try to guess
when to switch to the real console, add a flag so we can be sure. This
makes sure that sandbox can always output a panic() message, for example,
and avoids silent failure (which is very annoying in sandbox).
If the console is not present, we try to reduce overhead by stopping any
output in vprintf(), before it gets to putc(). This is of dubious merit
in general, but in the case of sandbox it is incorrect since we have a
fallback console which reports errors very early in U-Boot. If this is
defeated U-Boot can hang or exit with no indication of what is wrong.
Remove the optimisation for sandbox.
The current functions for adding and removing devices require a device name.
This is not convenient for driver model, which wants to store a pointer to
the relevant device. Add new functions which provide this feature and adjust
the old ones to call these.
Initialise devices marked 'pre-reloc' and make them available prior to
relocation. Note that this requires pre-reloc malloc() to be available.
Driver model currently only operates after relocation is complete. In this
state U-Boot typically has a small amount of memory available. In adding
support for driver model prior to relocation we must try to use as little
memory as possible.
In addition, on some machines the memory has not be inited and/or the CPU
is not running at full speed or the data cache is off. These can reduce
execution performance, so the less initialisation that is done before
relocation the better.
An immediately-obvious improvement is to only initialise drivers which are
actually going to be used before relocation. On many boards the only such
driver is a serial UART, so this provides a very large potential benefit.
Allow drivers to mark themselves as 'pre-reloc' which means that they will
be initialised prior to relocation. This can be done either with a driver
flag or with a 'dm,pre-reloc' device tree property.
To support this, the various dm scanning function now take a 'pre_reloc_only'
parameter which indicates that only drivers marked pre-reloc should be
bound.
At present stdio device functions do not get any clue as to which stdio
device is being acted on. Some implementations go to great lengths to work
around this, such as defining a whole separate set of functions for each
possible device.
For driver model we need to associate a stdio_dev with a device. It doesn't
seem possible to continue with this work-around approach.
Instead, add a stdio_dev pointer to each of the stdio member functions.
Note: The serial drivers have the same problem, but it is not strictly
necessary to fix that to get driver model running. Also, if we convert
serial over to driver model the problem will go away.
Code size increases by 244 bytes for Thumb2 and 428 for PowerPC.
22: stdio: Pass device pointer to stdio methods
arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0
powerpc: (for 1/1 boards) all +428.0 text +428.0
There is no point in setting a structure's memory to NULL when it has
already been zeroed with memset().
Also, there is no need to create a stub function for stdio to call - if the
function is NULL it will not be called.
This is a clean-up, with no change in functionality.
Tun on DEBUG in malloc(). This adds code space and slows things down but
for sandbox this is acceptable. We gain the ability to check for memory
leaks in tests.
