pxe.c provides both the "pxe" command which relies on a network, and the
"sysboot" command which doesn't. Fix the file to compile when network
support isn't enabled. This is useful e.g. on the Raspberry Pi which has
no network support yet, but will soon support the sysboot command.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
There is a strange comment in fit_image_load().
This function can be used for loading Kernel Image, FDT
as well as ramdisk.
- When CONFIG_DISPLAY_CPUINFO is not enabled,
print_cpuinfo() should be defined as an empty function
in a header, include/common.h
- Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif
from caller, common/board_f.c and arch/arm/lib/board.c
- Remove redundant prototypes in arch/arm/lib/board.c,
arch/arm/include/asm/arch-am33x/sys_proto.h and
board/nokia/rx51/rx51.h, keeping the one in include/common.h
- Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition
where it is missing
Useful rules in scripts/Makefile.lib allows us to easily
generate a device tree blob and wrap it in assembly code.
We do not need to parse a linker script to get output format and arch.
This commit deletes ./u-boot.dtb since it is a copy of dts/dt.dtb.
Now we are ready to switch over to real Kbuild.
This commit disables temporary scripts:
scripts/{Makefile.build.tmp, Makefile.host.tmp}
and enables real Kbuild scripts:
scripts/{Makefile.build,Makefile.host,Makefile.lib}.
This switch is triggered by the line in scripts/Kbuild.include
-build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj
+build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj
We need to adjust some build scripts for U-Boot.
But smaller amount of modification is preferable.
Additionally, we need to fix compiler flags which are
locally added or removed.
In Kbuild, it is not allowed to change CFLAGS locally.
Instead, ccflags-y, asflags-y, cppflags-y,
CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o
are prepared for that purpose.
Tested-by: Gerhard Sittig <gsi@denx.de>
This commit changes the working directory
where the build process occurs.
Before this commit, build process occurred under the source
tree for both in-tree and out-of-tree build.
That's why we needed to add $(obj) prefix to all generated
files in makefiles like follows:
$(obj)u-boot.bin: $(obj)u-boot
Here, $(obj) is empty for in-tree build, whereas it points
to the output directory for out-of-tree build.
And our old build system changes the current working directory
with "make -C <sub-dir>" syntax when descending into the
sub-directories.
On the other hand, Kbuild uses a different idea
to handle out-of-tree build and directory descending.
The build process of Kbuild always occurs under the output tree.
When "O=dir/to/store/output/files" is given, the build system
changes the current working directory to that directory and
restarts the make.
Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>"
syntax for descending into sub-directories.
(We can write it like "make $(obj)=<sub-dir>" with a shorthand.)
This means the current working directory is always the top
of the output directory.
Add spl_sata to read a fat partition from a bootable SATA
drive.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Reviewed-by: Roger Quadros <rogerq@ti.com>
Unlike other commands (for example, "fatwrite"), ext4write would
interpret the "sizebytes" as decimal number. This is not only
inconsistend and unexpected to most users, it also breaks usage
like this:
tftp ${addr} ${name}
ext4write mmc 0:2 ${addr} ${filename} ${filesize}
Change this to use the standard notation of base 16 input format.
See also commit b770e88
WARNING: this is a change to the user interface!!
Cc: Uma Shankar <uma.shankar@samsung.com>
Cc: Stephen Warren <swarren@nvidia.com>
This is much like a regular shell's -e operator, except that it takes
multiple arguments to specify the device type and device/partition ID
in addition to the usual filename:
if test -e mmc 0:1 /boot/boot.scr; then echo yes; else echo no; fi
This emulates bash:
$ if test; then echo yes; else echo no; fi
no
Currently, the code sets expr = -1 in this case, which gets mapped to
0 (true) at the end of do_test() by the logical -> shell exit code
conversion.
Currently, ! can only be parsed as the first operator in an expression.
This prevents the following from working:
$ if test ! ! 1 -eq 1; then echo yes; else echo no; fi
yes
$ if test ! 1 -eq 2 -a ! 3 -eq 4; then echo yes; else echo no; fi
yes
Fix this by parsing ! like any other operator, and and handling it
similarly to -a and -o.
This better mirrors the behaviour of bash, for example:
$ if test -z = -z; then echo yes; else echo no; fi
yes
This is parsed as a string comparison of "-z" and "-z", since the check
for the binary "=" operator occurs first. Without this change, the
command would be parsed as a -z test of "-", followed by a syntax error;
a trailing -z without and operand.
This is a behavioural change, but I believe any commands affected were
previously invalid or bizarely formed.
do_test() currently uses strcmp() twice to determine which operator is
present; once to determine how many arguments the operator needs, then
a second time to actually decode the operator and implement it.
Rewrite the code so that a table lookup is used to translate the operator
string to an integer, and use a more efficient switch statement to decode
and execute the operator.
This approach also acts as enablement for the following patches.
This patch should introduce no behavioural change.
The open and close mmc sub-commands implement a hard-coded set of values
specific to the SMDK5250 platform. Remove these commands as what they
did can be done instead with a series of mmc dev / bootpart / bootbus
commands instead now.
Cc: Amar <amarendra.xt@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
Add a bootbus sub-command to the mmc command to allow for setting
the boot_bus_width, reset_boot_bus_width and boot_mode fields of
BOOT_BUS_WIDTH (EXT_CSD[177]).
Add a partconf sub-command to the mmc command to allow for setting
the boot_ack, boot_partition and partition_access fields of
PARTITION_CONFIG (formerly BOOT_CONFIG, EXT_CSD[179]). Part of this
requires changing the check for 'part' from an strncmp to a strcmp, like
the rest of the sub-commands.
Cc: Andy Fleming <afleming@gmail.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Rename 'bootpart' to 'bootpart-resize' to better reflect what this
command is for.
We use the switch CONFIG_SUPPORT_EMMC_BOOT today to enable some
additional features of the eMMC boot partitions. Add support for being
told that we have booted from one of these partitions to the spl
framework and implement this on TI OMAP/related.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Francois Bedard <fbedard@synopsys.com>
Signed-off-by: Dennis Gilmore <dennis@ausil.us>
People who write (or scripts that auto-generate) extlinux.conf don't
want to know about HW-specific information such as FDT filenames. Create
a new extlinux.conf tag "fdtdir" that specifies only the directory where
FDT files are located, and defer all knowledge of the filename to U-Boot.
The algorithm implemented is:
if $fdt_addr_r is set:
if "fdt" tag was specified in extlinux.conf:
load the FDT from the filename in the tag
else if "fdtdir" tag was specified in extlinux.conf:
if "fdtfile" is set in the environment:
load the FDT from filename in "$fdtfile"
else:
load the FDT from some automatically generated filename
if no FDT file was loaded, and $fdtaddr is set:
# This indicates an FDT packaged with firmware
use the FDT at $fdtaddr
A small part of an example /boot/extlinux.conf might be:
LABEL primary
LINUX zImage
FDTDIR ./
LABEL failsafe
LINUX bkp/zImage
FDTDIR bkp/
... with /boot/tegra20-seaboard.dtb or /boot/bkp/tegra20-seaboard.dtb
being loaded by the sysboot/pxe code.
The specification for extlinux.conf[1] states that "fdt" is an alias for
"devicetree". To date, U-Boot only implements "fdt". Rectify that.
[1] http://freedesktop.org/wiki/Specifications/BootLoaderSpec/
Command provides just dump subcommand for showing clock
frequencies in a soc.
Changes:
- le16_to_cpu() to get_unaligned_le16()
- le32_to_cpu() to get_unaligned_le32()
when access fields in struct bmp header.
This changes avoids data abort exception caused by unaligned data access.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Acked-by: Anatolij Gustschin <agust@denx.de>
This is only required for "PIC" relocation and doesn't apply to modern
"PIE" relocation which does data relocation as well as code.
"init_sequence_r" is just an array that consists of compile-time
adresses of init functions. Since this is basically an array of integers
(pointers to "void" to be more precise) it won't be modified during
relocation - it will be just copied to new location as it is.
As a consequence on execution after relocation "initcall_run_list" will
be jumping to pre-relocation addresses. As long as we don't overwrite
pre-relocation memory area init calls are executed correctly. But still
it is dangerous because after relocation we don't expect initially used
memory to stay untouched.
Cc: Tom Rini <trini@ti.com>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Doug Anderson <dianders@chromium.org>
Cc: Thomas Langer <thomas.langer@lantiq.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Add SPL support to be able to detect a USB Mass Storage device
connected to a USB host. Once a USB Mass storage device is detected
the SPL will load the u-boot.img from a FAT partition to target address.
Move the FAT functions to a common location for reuse.
The change to add 64bit initrd support broke 32bit initrd support as it
always set 64bits worth of data into the properties, even on 32bit
systems. The fix is to use addr_cell_len (which already says how much
data is in 'tmp') to set the property, rather than always setting 8.
Thanks to Stephen Warren for pointing out the fix here.
Reported-by: Otavio Salvador <otavio@ossystems.com.br>
when creating the hashtable, for each environmentvariable
getenv(ENV_CALLBACK_VAR) and getenv(ENV_FLAGS_VAR) is called,
which costs at this point a lot of time. So call this two
getenv() calls only once.
Boottime on the ids8313 board without this patch:
2013-12-19 13:38:22,894: NAND: 128 MiB
2013-12-19 13:38:27,659: In: serial
(~4.8 sec)
Bootime with this patch on the ids8313 board:
2013-12-19 13:40:25,332: NAND: 128 MiB
2013-12-19 13:40:25,546: In: serial
(~0.2 sec)
For standalone images, bootm had a special case where the OS boot function
was NULL but did actually exist. It was just called manually.
This was removed by commit 35fc84fa which checks for the non-existence of
this function before the special case is examined.
There is no obvious reason why standalone is handled with a special case.
Adjust the code so that standalone has a normal OS boot function. We still
need a special case for when the function returns, but at least we can
avoid the main problem.
This is intended to fix the reported:
ERROR: booting os 'U-Boot' (17) is not supported
but needs testing.
Otherwise, when booting VxWorks kernel, the incorrect message will
be seen:
ARM Unknown OS Kernel Image (uncompressed)
Signed-off-by: Miao Yan <miao.yan@windriver.com>
Compiling of full list of commands does not advance the counter,
so it always results in an empty list.
This seems to be (inadvertently?) introduced by commit
6c7c946cadfafdea80eb930e3181085b907a0362.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
Before this change ums mode can not be entered when device
was using the same usb port for usb/uart communication.
Switching USB cable from UART to USB always causes ums exit.
"env_eeprom_bus" is no longer in use (it was introduced in commit
548738b4d43af841ff58c787bce297ac6a8bf7d1 "cmd_eeprom: I2C updates").
As in "eeprom_bus_write" we just reset I2C bus with the one we saved in
"old_bus".
Add map_sysmem() calls so that this test works correctly on sandbox.
Reviewed-by: Hung-ying Tyan <tyanh@chromium.org>
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be
added to include/configs/exynos5-dt.h now.
include/configs/exynos5250-dt.h
Signed-off-by: David Feng <fenghua@phytium.com.cn>
Relocation code based on a patch by Scott Wood, which is:
The eMMC and the SD-Card specifications describe the optional SET_DSR command.
During measurements at our lab we found that some cards implementing this feature
having really strong driver strengts per default. This can lead to voltage peaks
above the specification of the host on signal edges for data sent from a card to
the host.
Since availability of a given card type may be shorter than the time a certain
hardware will be produced it is useful to have support for this command (Alternative
would be changing termination resistors and adapting the driver strength of the
host to the used card.)
Following proposal for an implementation:
- new field that reflects CSD field DSR_IMP in struct mmc
- new field for design specific DSR value in struct mmc
- board code can set DSR value in mmc struct just after registering an controller
- mmc_startup sends the the stored DSR value before selecting a card, if DSR_IMP is set
Additionally the mmc command is extended to make is possible to play around with different
DSR values.
The concept was tested on a i.MX53 based platform using a Micron eMMC card where the default
DSR is 0x0400 (12mA) but in our design 0x0100 (0x0100) were enough. To use this feature for
instance on a mx53loco one have to add a call to mmc_set_dsr() in board_mmc_init() after
calling fsl_esdhc_initialize() for the eMMC.
Signed-off-by: Markus Niebel <Markus.Niebel@tqs.de>
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
It is useful to be able to save and restore the RAM contents of sandbox
U-Boot either for setting up tests, for later analysys, or for chaining
together multiple tests which need to keep the same memory contents.
Add a function to provide a memory file for U-Boot. This is read on
start-up and written when shutting down. If the file does not exist
on start-up, it will be created when shutting down.
