As with i2c_read() and i2c_write(), add a dm_ prefix to the driver model
versions of these functions to avoid conflicts.
Acked-by: Heiko Schocher <hs@denx.de>
At present on some architectures we set up the following before calling
board_init_f():
- global_data
- stack
- early malloc memory
Adding the code to support early malloc and global data setup to every
arch's assembler start-up is a pain. Also this code is not actually
architecture-specific. We can use common code for all architectures and
with a bit of care we can write this code in C.
Add a new function to deal with this. It should be called after memory
is available, with a pointer to the top of the area that should be used
before relocation. The function will set things up and return the lowest
memory address that it allocated/used. That can then be set as the top
of the stack.
Note that on some archs this function will use the stack, so the stack
pointer should be set to same value as is pased to board_init_f_mem().
A margin of 128 bytes will be left for this stack, so that it is not
overwritten. This means that 64 bytes is wasted by this early call.
This is not strictly necessary on several more modern archs, so we could
remove this at the cost of some arch-dependent code.
With this function there is no-longer any need for the assembler code to
zero global_data or set up the early malloc pointers.
All callers of malloc should already do error checking, and may even be able
to continue without the alloc succeeding.
Moreover, common/malloc_simple.c is the only user of .rodata.str1.1 in
common/built-in.o when building the SPL, triggering this gcc bug:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=54303
Causing .rodata to grow with e.g. 0xc21 bytes, nullifying all benefits of
using malloc_simple in the first place.
Segfaults can occur when a mandatory argument is not provided to
"demo hello" and "demo status". Eg:
=> demo hello
Segmentation fault (core dumped)
Add a check to ensure all required arguments are provided.
include/splash.h
lcd_logo() currently performs tasks well beyond just displaying the logo.
It has code which displays splash image, it has logic which determines
when the different display features are displayed, and it is coupled with
the lcd console because it holds the responsibility of returning the
lcd console base address.
Make lcd_logo() just about the logo by:
* Moving splash image display code into a dedicated function
* Moving the logic regarding when various features are displayed to
lcd_clear() (which is arguably not the correct name for housing such
code either, but it is currently the most fitting location code wise)
* Move the responsibility of setting the console base address to
lcd_clear() too.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Tested-by: Bo Shen <voice.shen@atmel.com>
Tested-by: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
We now have api functions that can support compiling simplefb code as its own
module. Since this code is not part of the display functionality, extract it
to its own file.
Raspberry Pi is updated to accommodate the changes.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
The name "bitmap_plot" is misleading because it implies that this is a generic
function capable of dealing with any bitmap, but its implementation only works
with the logo data.
Rename the function to better reflect this.
This cleanup mostly focuses on removing unnecessary whitespace and comments
which are superfluous and/or do not conform to the coding style.
Remove unused includes.
Reduce the lcd_display_bitmap #ifdef complexity by extracting Atmel-specific
code for setting cmap for bitmap images into a new function lcd_set_cmap().
A default version is implemented with the remainder of the code.
Get rid of platform-specific #ifdefs in bitmap_plot() by moving the generic
case of setting cmap into the weak lcd_logo_set_cmap().
Reduce the bitmap_plot #ifdef complexity by extracting MPC823-specific code for
setting cmap into its own implementation of lcd_logo_set_cmap(), implemented in
mpc8xx_lcd.c. In the MPC823 implementation, ARRAY_SIZE(bmp_logo_palette) is
switched for BMP_LOGO_COLORS to avoid having to include bmp_logo_data.h, which
would cause a compilation error because the logo data and palette arrays would
be defined twice.
This is a step towards cleaning bitmap_plot() of platform-specific code.
Reduce the bitmap_plot #ifdef complexity by extracting Atmel-specific code for
setting cmap into a new function lcd_logo_set_cmap(), which is implemented in
atmel_lcdfb driver and defined as part of common/lcd.c api with a weak dummy
version. In the Atmel implementation, ARRAY_SIZE(bmp_logo_palette) is
be defined twice.
Reduce the amount of platform-specific code in common/lcd.c by moving MPC823
implementation of fb_put_byte() to mpc8xx_lcd.c. Since we must also have a
default implementation for everybody else, make the remainder of the code
into a weak function.
Reduce the amount of platform-specific code in common/lcd.c by moving Atmel
implementation of fb_put_word() to atmel_lcdfb.c. Since we must also have a
Acked-by: Bo Shen <voice.shen@atmel.com>
configuration_get_cmap() is multiple platform-specific functions stuffed into
one function. Split it into multiple versions, and move each version to the
appropriate driver to reduce the #ifdef complexity.
Microblaze target supports both OF and !OF cases
and from log is not clear which version is running.
Compile code with -fPIC to get GOT. Do not build SPL
with fPIC because it increasing SPL size for nothing.
This is required for architectures still need manual relocation like avr32, mk68
and others.
Tested-by: Michal Simek <michal.simek@xilinx.com>
call hw_watchdog_init() also if CONFIG_AT91SAM9_WATCHDOG
is used.
On some hardware this time can be significant. Add bootstage support for
measuring this. The result can be obtained using 'bootstage report' or
passed on to the Linux via the device tree.
There are missing parameters in help which fpga dump command
requires.
Remove the additional ',' and '\n' from the gettime command help.
Currently the hash functions used in RSA are called directly from the sha1
and sha256 libraries. Change the RSA checksum library to use the progressive
hash API's registered with struct hash_algo. This will allow the checksum
library to use the hardware accelerated progressive hash API's once available.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
CC: Simon Glass <sjg@chromium.org>
(Fixed build error in am335x_boneblack_vboot due to duplicate CONFIG_DM)
Change-Id: Ic44279432f88d4e8594c6e94feb1cfcae2443a54
The hash_algo structure has some implementations in which progressive hash
API's are not defined. These are basically the hardware based implementations
of SHA. An API is added to find the algo which has progressive hash API's
defined. This can then be integrated with RSA checksum library which uses
Progressive Hash API's.
this is an atempt to make the export of functions typesafe.
I replaced the jumptable void ** by a struct (jt_funcs) with function pointers.
The EXPORT_FUNC macro now has 3 fixed parameters and one
variadic parameter
The first is the name of the exported function,
the rest of the parameters are used to format a functionpointer
in the jumptable,
the EXPORT_FUNC macros are expanded three times,
1. to declare the members of the struct
2. to initialize the structmember pointers
3. to call the functions in stubs.c
Signed-off-by: Martin Dorwig <dorwig@tetronik.com>
(resending to the list since my tweaks are not quite trivial)
Rather than assuming that the chip offset length is 1, allow it to be
provided. This allows chips that don't use the default offset length to
be used (at present they are only supported by the command line 'i2c'
command which sets the offset length explicitly).
Add a dm_ prefix to driver model I2C functions so that we can keep the old
ones around.
This is a little unfortunate, but on reflection it is too difficult to
change the API. We can undo this rename when most boards and drivers are
converted to use driver model for I2C.
Add a new 'demo light' command which uses GPIOs to control imaginary lights.
Each light is assigned a bit number in the overall value. This provides an
example driver for using the new GPIO API.
The common/board_r.c has show_model_r() to display the model name
if the DTB has a "model" property. It sounds useful to have a similar
function in common/board_f.c too because most of the boards show
their board name before relocation.
Instead of implementing the same function in both common/board_f.c
and common/board_r.c, let's split it up into common/show_board_info.c.
To store 10bit chip address, the variable type should not be uchar,
but uint.
Acked-by: Heiko Schocher<hs@denx.de>
Fake option is enabled only when CONFIG_TRACE is
enabled in common/bootm.c:do_boot_states().
The dumpimage is able to extract components contained in a FIT image:
$ ./dumpimage -T flat_dt -i CONTAINER.ITB -p INDEX FILE
The CONTAINER.ITB is a regular FIT container file. The INDEX is the poisition
of the sub-image to be retrieved, and FILE is the file (path+name) to save the
extracted sub-image.
For example, given the following kernel.its to build a kernel.itb:
/dts-v1/;
images {
kernel@1 {
description = "Kernel 2.6.32-34";
data = /incbin/("/boot/vmlinuz-2.6.32-34-generic");
type = "kernel";
arch = "ppc";
os = "linux";
compression = "gzip";
load = <00000000>;
entry = <00000000>;
hash@1 {
algo = "md5";
The dumpimage can extract the 'kernel@1' node through the following command:
$ ./dumpimage -T flat_dt -i kernel.itb -p 0 kernel
Extracted:
Image 0 (kernel@1)
Description: Kernel 2.6.32-34
Created: Wed Oct 22 15:50:26 2014
Type: Kernel Image
Compression: gzip compressed
Data Size: 4040128 Bytes = 3945.44 kB = 3.85 MB
Architecture: PowerPC
OS: Linux
Load Address: 0x00000000
Entry Point: 0x00000000
Hash algo: md5
Hash value: 22352ad39bdc03e2e50f9cc28c1c3652
Which results in the file 'kernel' being exactly the same as '/boot/vmlinuz-2.6.32-34-generic'.
Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
Move the image_save_datafile() function from an U-Multi specific file
(default_image.c) to a file common to all image types (image.c). And rename it
to genimg_save_datafile(), to make clear it is useful for any image type.
A cache flush is required when an image is extracted that is required on another core.
Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive-technologies.com>
Add an optional third argument to the "part list" command which puts a
space seperated list of valid partitions into the given environment
variable. This is useful for allowing boot scripts to iterate of all
partitions of a device.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
New command to determine the filesystem type of a given partition.
Optionally stores the filesystem type in a environment variable.
Move board/compulab/common/splash.c code to
common/splash_source.c to make it available for everybody. This move
renames cl_splash_screen_prepare() to splash_source_load(), and
the compilation of this code is conditional on CONFIG_SPLASH_SOURCE.
splash_source features:
* Provide a standardized way for declaring board specific splash screen
locations
* Provide existing routines for auto loading the splash image from the
locations as declared by the board
* Introduce the "splashsource" environment variable, which makes it
possible to select the splash image source.
cm-t35 and cm-fx6 are updated to use the modified version.
Cc: Tom Rini <trini@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Reviewed-by: Tom Rini <trini@ti.com>
This commit 904672e (lcd: refactor lcd console stuff into its
own file), which cause lcd console address is not initialized.
This patch initialize the lcd console use the default value,
will be update when splash screen is enabled.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Microblaze currently doesn't use printf in SPL. So this one line was the only
reference to it and resulted in the printf functionality to be pulled in.
Exceeding the 4k size limit. Lets change the printf back to puts so that
Microblaze is fixed again. The only drawback is that the detected boot-device
number will not be printed. But this message alone should be helpful enough
to get an idea where the boot process is broken.
Cc: Michal Simek <michal.simek@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
All memory to be reserved for use after relocation by adding a new call
to perform this reservation.
For case where CMD_FPGA_LOADMK is enabled and GZIP disable.
Warning log:
common/built-in.o: In function `do_fpga':
/mnt/disk/u-boot/common/cmd_fpga.c:218: undefined reference to `gunzip'
