When debugging drivers it is useful to see what I/O accesses were done
and in what order.
Even if the individual accesses are of little interest it can be useful to
verify that the access pattern is consistent each time an operation is
performed. In this case a checksum can be used to characterise the operation
of a driver. The checksum can be compared across different runs of the
operation to verify that the driver is working properly.
In particular, when performing major refactoring of the driver, where the
access pattern should not change, the checksum provides assurance that the
refactoring work has not broken the driver.
Add an I/O tracing feature and associated commands to provide this facility.
It works by sneaking into the io.h heder for an architecture and redirecting
I/O accesses through its tracing mechanism.
For now no commands are provided to examine the trace buffer. The format is
fairly simple, so 'md' is a reasonable substitute.
Note: The checksum feature is only useful for I/O regions where the contents
do not change outside of software control. Where this is not suitable you can
fall back to manually comparing the addresses. It might be useful to enhance
tracing to only checksum the accesses and not the data read/written.
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
commit ecd729500 "Add parameter to md5sum to save the md5 sum"
adds support to build a string to be saved in the env and tries
to zero end it with str_ptr = '\0'; This does actually set the
pointer to the end of the buffer itself to zero. Since the
string was already zero terminated by the sprintf before it,
just remove the line, preventing a clang warning.
cc: Joe Hershberger <joe.hershberger@ni.com>
commit 18b06652cd "tools: include u-boot version of sha256.h"
unconditionally forced the sha256.h from u-boot to be used
for tools instead of the host version. This is fragile though
as it will also include the host version. Therefore move it
to include/u-boot to join u-boot/md5.h etc which were renamed
for the same reason.
cc: Simon Glass <sjg@chromium.org>
At present this tool only checks the configuration signing. Have it also
look at each of the images in the configuration and confirm that they
verify.
Acked-by: Heiko Schocher <hs@denx.de> (v1)
This makes it possible to decompress an image without it being a kernel
and without intending to boot it (as it needed for host tools, for example).
We want to use some of the functionality in this file, so make it
build on the host.
This typo makes the comment confusing. Fix it.
A small change allows this to operate on sandbox.
This can be obtained by looking up the image type, so is redundant. It is
better to centralise this lookup to avoid errors.
This file has code in three different categories:
- Command processing
- OS-specific boot code
- Locating images and setting up to boot
Only the first category really belongs in a file called cmd_bootm.c.
Leave the command processing code where it is. Split out the OS-specific
boot code into bootm_os.c. Split out the other code into bootm.c
Header files and extern declarations are tidied but otherwise no code
changes are made, to make it easier to review.
It is more common to have 0 mean OK, and -ve mean error. Change this
function to work the same way to avoid confusion.
This type is more readily available on the host compiler, so use it instead.
Before this commit, fdt_initrd() just returned if initrd
start address is zero.
But it is possible if the RAM is located at address 0.
This commit makes the return condition more reasonable:
Just return if the size of initrd is zero.
Data written to DTB must be converted to big endian order.
It is usually done by using cpu_to_fdt32(), cpu_to_fdt64(), etc.
fdt_initrd() invoked write_cell(), which always swaps byte order.
It means the function only worked on little endian architectures.
(On big endian architectures, the byte order should be kept as it is)
This commit uses cpu_to_fdt32() and cpu_to_fdt64()
and deletes write_cell().
fdt_fixup_memory_banks() invoked write_cell(), which always
swaps byte order.
This commit adds and uses a new helper function, fdt_pack_reg(),
which works on both big endian and little endian architrectures.
In the next commit, I will add a new function, fdt_pack_reg()
which uses get_cells_len().
Beforehand, this commit adds 'const' qualifier to get_cells_len().
Otherwise, a warning message will appear:
warning: passing argument 1 of 'get_cells_len' discards 'const'
qualifier from pointer target type [enabled by default]
- Do not use a deep indentation. We have only 80-character
on each line and 1 indentation consumes 8 spaces. Before the
code moves far to the right, you should consider to
fix your code. See Linux Documentation/CodingStyle.
- Add CONFIG_OF_STDOUT_VIA_ALIAS and OF_STDOUT_PATH macros
only to their definition. Do not add them to both
callee and caller. This is a tip to avoid using #ifdef
everywhere.
- OF_STDOUT_PATH and CONFIG_OF_STDOUT_VIA_ALIAS are exclusive.
If both are defined, the former takes precedence.
Do not try to fix-up "linux,stdout-path" property twice.
After all, we have realized "force" argument is completely
useless. fdt_chosen() was always called with force = 1.
We should always want to do the same thing
(set appropriate value to the property)
even if the property already exists.
useless. fdt_initrd() was always called with force = 1.
Some functions in fdt_support.c do the same routine:
search a node with a given name ("chosen", "memory", etc.)
or newly create it if it does not exist.
So this commit makes that routine to a helper function.
gd->bd is not used in fdt_support.c.
A board that has a USB ethernet device only may set the usbetheraddr
and not the ethaddr.
ethaddr will be the default MAC address that is chosen and if that
is not populated then the usbethaddr is looked at. If neither are set
then then device tree blob is not modified.
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Currently, U-Boot behaves as follows:
- Begin with no SD card inserted in "mmc 1"
- Execute: mmc dev 1
- This fails, since there is no card
- User plugs in an SD card
- This still fails, since the HW isn't reprobed.
With this change, U-Boot behaves as follows:
- The newly present SD card is detected
I know that "mmc rescan" will force the HW to be reprobed, but I feel it
makes more sense if "mmc dev" always reprobes the HW after selecting the
current MMC device. This allows scripts to just execute "mmc dev", and
not have to also execute "mmc rescan" to check for media presense.
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
The body of init_mmc_device() is now identical to that of do_mmc_rescan()
except for the error codes returned. Modify do_mmc_rescan() to simply
call init_mmc_device() and convert the error codes, to avoid code
duplication.
This allows callers to inject mmc->has_init = 0 between finding the
MMC device, and calling mmc_init(), which forces mmc_init() to rescan
the HW. Future changes will use this feature.
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Currently, "mmc dev 0" does not change the selected HW partition. I
think it makes more sense if "mmc dev 0" is an alias for "mmc dev 0 0",
i.e. that HW partition 0 (main data area) is always selected by default
if the user didn't request a specific partition. Otherwise, the following
happens, which feels wrong:
Select HW partition 1 (boot0):
mmc dev 0 1
Doesn't change the HW partition, so it's still 1 (boot0):
mmc dev 0
With this patch, the second command above re-selects the main data area.
Note that some MMC devices (i.e. SD cards) don't support HW partitions.
However, this patch still works, since mmc_start_init() sets the current
partition number to 0, and mmc_select_hwpart() succeeds if the requested
partition is already selected.
To prevent a warning for clang the loop without a body
is made more clear by moving it to a line of its own.
This prevents a clang warning.
cc: sbabic@denx.de
Clang interpretes an if condition like "if ((a = b) == NULL)
as it tries to assign a value in a statement. Hence if you do
"if ((something)) it warns you that you might be confused.
Hence drop the double braces for plane if statements.
if algo->digest_size is zero nothing is set in the str_output
buffer. An attempt is made to zero end the buffer, but the
pointer to the buffer is set to zero instead. I am unaware if
it causes any actual problems, but solves the following warning:
common/hash.c:217:13: warning: expression which evaluates to zero treated as
a null pointer constant of type 'char *' [-Wnon-literal-null-conversion]
str_ptr = '\0';
Replace run_command() by run_command_repeatable() in places which
depend on the return code to indicate repeatability.
Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com>
run_command() returns 0 on success and 1 on error. However, there are some
invocations which expect 0 or 1 for success (not repeatable or repeatable)
and -1 for error; add run_command_repeatable() for this purpose.
run_command() returns 0 for success, 1 for failure. Fix places which
assume that failure is indicated by a negative return code.
Tested-by: Stefan Roese <sr@denx.de>
When writing values into an FDT it is possible that there will be
insufficient space. If the caller gets a useful error then it can
potentially deal with the situation.
Adjust these functions to return -ENOSPC when the FDT is full.
This function is useful for displaying a hash value, so export it.
When the map_sysmem, then the fatwrite command can support sandbox.
Following command will show how to use it:
=> sb bind 0 sd.img
=> fatls host 0
=> fatwrite host 0 $memaddr filename $filesize
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Remove the common infrastructure of nand_spl and
clean-up the code inside ifdef(CONFIG_NAND_U_BOOT)..endif.
make the use of legacy image format configurable through
the config define CONFIG_IMAGE_FORMAT_LEGACY.
When relying on signed FIT images with required signature check
the legacy image format should be disabled. Therefore introduce
this new define and enable legacy image format if CONFIG_FIT_SIGNATURE
is not set. If CONFIG_FIT_SIGNATURE is set disable per default
the legacy image format.
Cc: Lars Steubesand <lars.steubesand@philips.com>
Cc: Mike Pearce <mike@kaew.be>
Cc: Tom Rini <trini@ti.com>
Assign default environment and set env valid during board_init_f
before relocation as the actual environment will be read from eeprom
later.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Acked-by: Michal Simek <monstr@monstr.eu>
The return code is not consistent with cli_simple_run_command_list(). For the
last command in a sequence, the return code is actually inverted.
Fix it.
When a simple command like 'false' is provided, hush should return the
result of that command. However, hush only does this if the
FLAG_EXIT_FROM_LOOP flag is provided. Without this flag, hush will
happily execute the empty string command immediate after 'false' and
then return a success code.
This behaviour does not seem very useful, and requiring the flag also
seems wrong, since it means that hush will execute only the first command
in a sequence.
Add a check for empty string and fall out of the loop in that case. That
at least fixes the simple command case. This is a change in behaviour but
it is unlikely that the old behaviour would be considered correct in any
case.
Reported-by: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net>
The mask value used in itest overflows and therefore it can return an
incorrect result for something like 'itest 0 == 1'. Fix it.
Now that we wait the correct specification-mandated time at the end of
usb_hub_power_on(), I suspect that CONFIG_USB_HUB_MIN_POWER_ON_DELAY has
no purpose.
For cm_t35.h, we already wait longer than the original MIN_POWER_ON_DELAY,
so this change is safe.
For gw_ventana.h, we will wait as long as the original MIN_POWER_ON_DELAY
iff pgood_delay was at least 200ms. I'm not sure if this is the case or
not, hence I've CC'd relevant people to test this change.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Tim Harvey <tharvey@gateworks.com>
usb_hub_power_on() currently waits for the maximum of (a) the hub port's
power output to become good, (b) the max time the USB specification
allows a device to take to connect.
However, these two operations must occur in series rather than in
parallel. First, the power supply ramps up to the level required to
power the USB device, and then the device may take a certain amount of
time to connect (assert D+/D- pullups).
Related, the maximum time that a device has to assert pullups is 1s not
100ms.
This is explained in "Connect Timing ECN.pdf", itself part of
usb_20_042814.zip from www.usb.org.
It doesn't seem necessary to use memory allocation in this code. The setenv()
will make a copy anyway.
bootdelay_process() never returns in some circumstances, whichs makes the
control flow confusing. Change it so that the decision about how to execute
the boot command is made in the main_loop() code, so it is easier to follow.
Move CLI stuff to cli.c.
Move these details from main (which doesn't care which parser is used) to
cli.c where they belong.
The main loop is easier to follow if the code is grouped into separate
functions. Make this change, so that main_loop() is easier to read.
