RC Release 09.02.00.009
The NAND flash utility functions under CONFIG_CMD_NAND should not be
compiled at SPL stage as the underlying functions are under separate
Kconfigs viz. CONFIG_ENV_IS_IN_NAND and hence are not supported at
SPL stage right now for splash screen.
Long term, the NAND flash utility functions and their dependencies need
to be tied with splash screen specific Kconfigs too as splash logo
file can be present in NAND storage before bootup.
Signed-off-by: Devarsh Thakkar <devarsht@ti.com>
Create separate helper for just reserving framebuffer region without
creating or enabling simple-framebuffer node.
This is useful for scenarios where user want to preserve the bootloader
splash screen till OS boots up and display server gets started without
displaying anything else in between and thus not requiring
simple-framebuffer.
Enable and update simple-framebuffer node using the video handoff
bloblist if video was enabled at SPL stage and corresponding video
bloblist was received at u-boot proper with necessary parameters.
Don't compile ubifs splash mount command for SPL build as this command
is not supported (and also not enabled) during SPL stage.
This fixes below compilation error, when CONFIG_CMD_UBIFS is enabled in
defconfig along with splash screen enabled at SPL stage:
"aarch64-none-linux-gnu-ld.bfd: common/cli.o: in function `run_command':
u-boot-next/u-boot/common/cli.c:51: undefined reference to
`parse_string_outer'
u-boot-next/u-boot/common/cli.c:51:(.text.run_command+0x10): relocation
truncated to fit: R_AARCH64_JUMP26 against undefined symbol
`parse_string_outer' make[2]: ***
[u-boot-next/u-boot/scripts/Makefile.spl:527: spl/u-boot-spl] Error 1
make[1]: *** [u-boot-next/u-boot/Makefile:2053: spl/u-boot-spl] Error 2
make[1]: Leaving directory 'u-boot-next/u-boot/out/a53' make: ***
[Makefile:177: sub-make] Error 2"
Fixes: eb9217dc03 ("common: Enable splash functions at SPL")
Don't propagate error on bloblist failure as it is possible that splash
logo file may not have been present in expected location since common
defconfig is being used for other bootmodes too.
simple-framebuffer.
RC Release 09.00.00.008
The new config CONFIG_AVB_PUBKEY_FILE is used to specify the path to the
public key file that u-boot uses as the root public key. Previously,
the root public key was hard coded in avb_verify.c and therefore was
non-trivial to replace it with a custom key.
The public key that was hard-coded is extracted as default.avbpubkey
and is used as the default.
Bug: 181924266
Test: DIST_DIR=out/dist BUILD_CONFIG=u-boot/build.config.crosvm.aarch64
build/build.sh -j80
Signed-off-by: Jiyong Park <jiyong@google.com>
(cherry picked from commit e609074ced3dd07ca2a13d4becbae997e3a48c9f)
Signed-off-by: Guillaume La Roque <glaroque@baylibre.com>
[mkorpershoek: fixed conflict around _SPL_TPL_ support]
Signed-off-by: Mattijs Korpershoek <mkorpershoek@baylibre.com>
Tested-by: Guillaume La Roque <glaroque@baylibre.com>
Reviewed-by: Guillaume La Roque <glaroque@baylibre.com>
Ensure that every write is flushed to memory and afterward reads are
from memory.
Since the algorithm rely on the fact that accessing to not existent
memory lead to write at addr / 2 without this modification accesses
to aliased (not physically present) addresses are cached and
wrong size is returned.
This was discovered while working on a TI AM625 based board
where cache is normally enabled, see commit c02712a74849 ("arm: mach-k3: Enable dcache in SPL").
Upstream-Status: Submitted [https://lore.kernel.org/all/20230530133327.178278-1-francesco@dolcini.it]
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
At SPL stage when stack is relocated, the stack pointer needs to be
updated, the stack pointer may point to stack in on chip memory even
though stack is relocated.
Signed-off-by: Nikhil M Jain <n-jain1@ti.com>
During compilation splash_source puts out below warning for type
conversion in splash_load_fit for bmp_load_addr and fit_header.
Change their type to uintptr_t to fix the warnings.
common/splash_source.c: In function âsplash_load_fitâ:
common/splash_source.c:366:22: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
366 | img_header = (struct legacy_img_hdr *)bmp_load_addr;
common/splash_source.c:376:49: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
376 | res = splash_storage_read_raw(location, (u32)fit_header, fit_size);
common/splash_source.c:401:25: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
401 | memmove((void *)bmp_load_addr, internal_splash_data, internal_splash_size);
The above warnings are generated if CONFIG_FIT is enabled.
Use config SPL_VIDEO_REMOVE to remove video driver at SPL stage before
jumping to next stage, in place of CONFIG_SPL_VIDEO, to allow user to
remove video if required.
Reviewed-by: Devarsh Thakkar <devarsht@ti.com>
U-boot proper can use frame buffer address passed from SPL to reserve
the memory area used by framebuffer set in SPL so that splash image
set in SPL continues to get displayed while u-boot proper is running.
Put the framebuffer address and size in a bloblist to make them
available at u-boot proper, if in u-boot proper CONFIG_VIDEO is defined.
When video is set up in SPL, U-Boot proper needs to use the correct
parameters so it can write to the display.
Put these in a bloblist so they are available to U-Boot proper.
In A53 SPL stage, CONFIG_USB_STORAGE is defined, which causes
compilation error in splash_source, while trying to compile
splash_load_fs.This failure is due to finding no declaration of function
usb_init. usb_init in SPL stage is only declared when
CONFIG_SPL_USB_STORAGE is defined, thus use CONFIG_IS_ENABLED to check
for SPL_USB_STORAGE at SPL stage.
Add method to remove video driver before loading u-boot proper. When
bootstage changes from SPL to u-boot proper, this method will reset the
display controller so that it stops displaying towards the end of SPL
stage, thus avoiding displaying of artefacts when control is passed to
further stages and framebuffer region is used by some other component.
Avoid using preprocessor compilation directives and instead use simple
logical expressions for better readability since compiler will anyway
optimize out the respective code block if condition is not satisfied.
To support splash screen at both u-boot proper and SPL use
CONFIG_IS_ENABLED and CONFIG_VAL to check for video related Kconfigs at
respective stages.
Replace CONFIG_CMD_BMP with CONFIG_BMP to enable splash_display function
at u-boot proper and SPL.
Add rule to compile bmp.c at SPL and u-boot proper when CONFIG_SPL_BMP
and CONFIG_BMP are defined.
To enable splash screen at SPL, need to compile cmd/bmp.c which also
includes bmp commands, since SPL doesn't use commands split bmp.c into
common/bmp.c which includes all bmp functions and cmd/bmp.c which only
contains bmp commands.
Add function delclaration for bmp_info in video.h.
Add CONFIG_BMP and CONFIG_SPL_BMP which enable displaying bmp images at
To enable splash screen and loading bmp from boot media, add rules to
compile splash.c and splash_source.c at SPL stage only when
CONFIG_SPL_SPLASH_SCREEN and CONFIG_SPL_SPLASH_SOURCE are defined.
If early stack usage is exactly same as SIZE_LIMIT_PROVIDE_STACK, then
its most likely to have overflowed beyond this limit and corrupted any
regions beyond stack. Warn about this to the user.
Signed-off-by: Vignesh Raghavendra <vigneshr@ti.com>
Releasing the flash into proper state, after the loading completes,
is important for the next stage bootloader/kernel to be able to use
the MTD device. This would enable to reset the device for fresh
use by next boot stage.
Signed-off-by: Apurva Nandan <a-nandan@ti.com>
Introduce support for using MTD subsystem for loading images from
memory flashes. This will provide the support of using mtd functions
which are abstracted over the type of flash being used, to load the
boot images from the flash.
Currently, add support for only SPI NAND flashes. This can be extended
to all other flash types, when required.
Only RAW NANDs are supported in the SPL, so create a new Kconfig config
for building SPI NAND subsystem in the SPL build using
SPL_NAND_SPI_SUPPORT Kconfig option.
Add a CONFIG option to deal with this automatically, printing a warning
when U-Boot starts up. This can be useful if the device tree comes from
another project.
We will maintain this through the 2023.07 release, providing 6 months
for people to notice.
Version 4:
Acked-by: Michal Simek <michal.simek@amd.com>
The second call to cli_ch_process() is in the wrong place, meaning that
the one of the characters of an invalid escape sequence is swallowed
instead of being returned.
Fix the bug and add a test to cover this.
This behaviour matches that of the code before cli_getch() was
introduced. This was verified on the commit before b08e9d4b66 i.e.:
7d850f85aad ("sandbox: Enable mmc command and legacy images")
Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
This function does not behave as expected when unknown escape sequences
are sent to it:
- it fails to store (and thus echo) the last character of the invalid
sequence
- it fails to set esc_len to 0 when it finishes emitting the invalid
sequence, meaning that the following character will appear to be part
of a new escape sequence
- it processes the first character of the rejected sequence as a valid
character, just starting the sequence all over again
The last two bugs conspire to produce an "impossible condition #876"
message which is the main symptom of this behaviour.
Fix these bugs and add a test to verify the behaviour.
This configuration setting is only relevant if the board supports USB.
It should not be in the main menu but in the USB menu.
The setting is only relevant in USB host mode.
Fixes: 5454dea3137d ("usb: hub: allow to increase HUB_DEBOUNCE_TIMEOUT")
Signed-off-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
USB hubs run in host mode not in gadget mode. Hence, compiling usb_hub.c
should not be selected by CONFIG_USB_GADGET.
Suggested-by: Marek Vasut <marex@denx.de>
The arg->session is not valid if arg->ret != NULL, so can't be
assigned, correct this.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@globallogic.com>
Reviewed-by: Jens Wiklander <jens.wiklander@linaro.org>
Reset the serial flags so that the debug UART can be used (if enabled)
in the small window where there is no serial device. This can avoid a hang
in some cases.
This change was made for the benefit of RISC-V but broke other
architectures also. In particular, tracing cannot work without this value.
Add it back for architectures which support it.
Fixes: 3c9fc23c443 ("sandbox: don't refer to symbol _init")
https://source.denx.de/u-boot/custodians/u-boot-efi
Pull request for efi-2023-04-rc2
Documentation:
* Provide page with links to talks on U-Boot
UEFI:
* Enable CTRL+S to save the boot order in eficonfig command
* Run attribute check for QueryVariableInfo() only for the file store
* Bug fixes
Others:
* Improve output formatting of the coninfo command
# -----END PGP SIGNATURE-----
# gpg: Signature made Fri 10 Feb 2023 12:15:45 PM EST
# gpg: using RSA key 6DC4F9C71F29A6FA06B76D33C481DBBC2C051AC4
# gpg: Good signature from "Heinrich Schuchardt <xypron.glpk@gmx.de>" [unknown]
# gpg: aka "[jpeg image of size 1389]" [unknown]
# gpg: WARNING: This key is not certified with a trusted signature!
# gpg: There is no indication that the signature belongs to the owner.
# Primary key fingerprint: 6DC4 F9C7 1F29 A6FA 06B7 6D33 C481 DBBC 2C05 1AC4
This converts 2 usages of this option to the non-SPL form, since there is
no SPL_VIDEO defined in Kconfig
This converts 1 usage of this option to the non-SPL form, since there is
no SPL_SPLASH_SOURCE defined in Kconfig
no SPL_SAVE_PREV_BL_INITRAMFS_START_ADDR defined in Kconfig
no SPL_SAVE_PREV_BL_FDT_ADDR defined in Kconfig
no SPL_OF_EMBED defined in Kconfig
This converts 3 usages of this option to the non-SPL form, since there is
no SPL_NEEDS_MANUAL_RELOC defined in Kconfig
no SPL_HUSH_PARSER defined in Kconfig
The change boot order menu in eficonfig can have at most INT_MAX lines
and it is troublesome to scroll down to the "Save" entry.
This commit assigns CTRL+S to save the boot order.
Signed-off-by: Masahisa Kojima <masahisa.kojima@linaro.org>
Acked-by: Heinrich Schuchardt <heinrich.schuchardt@canonical.com>
no SPL_CMD_SHA1SUM defined in Kconfig
no SPL_CMD_HASH defined in Kconfig
This is not used. Drop the driver and Kconfig option.
