Prepare v2014.10
Implement an API that can be used by drivers to allocate memory from a
pool that is mapped uncached. This is useful if drivers would otherwise
need to do extensive cache maintenance (or explicitly maintaining the
cache isn't safe).
The API is protected using the new CONFIG_SYS_NONCACHED_MEMORY setting.
Boards can set this to the size to be used for the non-cached area. The
area will typically be right below the malloc() area, but architectures
should take care of aligning the beginning and end of the area to honor
any mapping restrictions. Architectures must also ensure that mappings
established for this area do not overlap with the malloc() area (which
should remain cached for improved performance).
While the API is currently only implemented for ARM v7, it should be
generic enough to allow other architectures to implement it as well.
Signed-off-by: Thierry Reding <treding@nvidia.com>
README
When DEBUG is set, output memory region used for malloc().
When enumerating devices, honour the pci_skip_dev() function. This can
be used by PCI controller drivers to restrict which devices will be
probed.
This is required by the NVIDIA Tegra PCIe controller driver, which will
fail with a data abort exception if an access is attempted to a device
number larger than 0 outside of bus 0. pci_skip_dev() is therefore
implemented to prevent any such accesses.
When listing the devices on a PCI bus, the current code will blindly try
to access all devices. Internally this causes pci_bus_to_hose() to be
repeatedly called and output an error message every time. Prevent this
by calling pci_bus_to_hose() once and abort early if no bus was found.
Since on powerpc phys_size_t can be unsigned long long, this printout
line can result in a not nice compile warning.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
At least on OMAP, init_sata() no longer performs scsi_scan()
so we must do it explicitly here.
Cc: Dan Murphy <dmurphy@ti.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
Commit 294b91a5817147d4b7f47be2ac69bac2a1f26491 moved initr_malloc
earlier than initr_unlock_ram_in_cache. This causes issue on T4240.
It may be related to locked L1 d-cache and unlocked L2 cache. D-
cache could and should be unlock earlier for normal operation.
This patch moves initr_unlock_ram_in_cache before initr_malloc. It
has been verified on the following boards, in which only T4240QDS
suffered and has been since fixed: T4240QDS, T2080QDS, P5040DS,
P4080DS, MPC8572DS, MPC8536DS, MPC8641HPCN, B4860QDS.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Scott Wood <scottwood@freescale.com>
CC: Simon Glass <sjg@chromium.org>
On a couple of platforms I've tripped over long PXE append lines overflowing
this array, due to having CONFIG_SYS_CBSIZE == 256. When doing preseeded Debian
installs it's pretty trivial to exceed that.
Since the symptom can be a silent hang or a crash add a check. Of course the
affected boards would also need an increased CBSIZE to actually work.
Note that due to the printing of the final bootargs string CONFIG_SYS_PBSIZE
also needs to be sufficiently large.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
[trini: Use %zd not %d in printf for all args]
Fix a trivial conflict in dw_mmc.c after talking with Marek.
drivers/mmc/dw_mmc.c
Like many platforms, the Altera socfpga platform requires that the
preloader be "signed" in a certain way or the built-in boot ROM will
not boot the code.
This change automatically creates an appropriately signed preloader
from an SPL image.
The signed image includes a CRC which must, of course, be generated
with a CRC generator that the SoCFPGA boot ROM agrees with otherwise
the boot ROM will reject the image.
Unfortunately the CRC used in this boot ROM is not the same as the
Adler CRC in lib/crc32.c. Indeed the Adler code is not technically a
CRC but is more correctly described as a checksum.
Thus, the appropriate CRC generator is added to lib/ as crc32_alt.c.
Signed-off-by: Charles Manning <cdhmanning@gmail.com>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
Cc: Pavel Machek <pavel@denx.de>
Acked-by: Pavel Machek <pavel@denx.de>
V2: - Zap unused constant
- Explicitly print an error message in case of error
- Rework the hdr_checksum() function to take the *header directly
instead of a plan buffer pointer
Use the new force parameter to make the stdio_deregister succeed, replacing
stdin with a nulldev, and assume that the usb keyboard will come back after
the reset.
In some cases we really want to move forward with a deregister, add a force
parameter to allow this, and replace the dev with a nulldev in this case.
We now always properly deregister the keyboard before calling
drv_usb_kbd_init(), so we can drop the check for already being registered.
We need to call usb_kbd_deregister() before calling usb_stop().
usbkbd's stdio_dev->priv points to the usb_device, and usb_kbd_testc
dereferences usb_device->privptr.
usb_stop zeros usb_device, leaving usb_device->privptr NULL, causing
bad things (tm) to happen once control returns to the main loop and
usb_kbd_testc gets called.
Calling usb_kbd_deregister() avoids this. Note that we do not allow
the "usb reset" to continue when the deregister fails. This will be fixed
in a later patch.
For the same reasons always fail "usb stop" if the usb_kbd_deregister() fails,
even in the force path. This can happen when CONFIG_SYS_STDIO_DEREGISTER is
not set.
ENODEV menas no usb keyboard was registered, threat this as a successful
usb_kbd_deregister.
sub-command 'bootpart-resize' check for argc == 4,
it will retrun CMD_RET_FAILURE when argc value not matched.
but bootpart-resize's maxarg is 3, which means you never execute
this sub-command successfully.
fix it by change bootpart-resize maxarg to 4.
Signed-off-by: wally.yeh <wally.yeh@atrustcorp.com>
Cc: Pierre Aubert <p.aubert@staubli.com>
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
The code to set the MMC partition uses an weak function to obtain the
correct partition number. Use that instead of the compile-time default
when deciding whether it needs to switch back.
Fixes: 6e7b7df4df43574 ("env_mmc: support env partition setup in runtime")
Signed-off-by: Peter A. Bigot <pab@pabigot.com>
Acked-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
In preparation for changing the error handling in this code for driver
model, move it into its own function.
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
of_bus_default_count_cells can be used to get the #address-cells
and #size-cells defined by the current node's parent node. This
is required when using of_read_number to read from FDT nodes that
can be 32 or 64 bytes depending on values defined by the parent.
Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
This is being done so that it can be used outside 'fdt_support.c'. Making
life more convenient when reading device node properties that can be 32
or 64 bits long.
Cc: Scott Wood <scottwood@freescale.com>
[1] Move driver/core/, driver/input/ and drivers/input/ entries
from the top Makefile to drivers/Makefile
[2] Remove the conditional by CONFIG_DM in drivers/core/Makefile
because the whole drivers/core directory is already selected
by CONFIG_DM in the upper level
[3] Likewise for CONFIG_DM_DEMO in drivers/demo/Makefile
[4] Simplify common/Makefile - both CONFIG_DDR_SPD and
CONFIG_SPD_EEPROM are boolean macros so they can directly
select objects
The arg_off() and arg_off_size() update the 'current NAND
device' variable (dev). This is then used when assigning the
(nand_info_t*)nand value. Place the assignment after the
arg_off(_size) calls to prevent using incorrect (nand_info_t*)
nand value.
Signed-off-by: Rostislav Lisovy <lisovy@merica.cz>
Since CONFIG_CMD_IMPORTENV is defined in config_cmd_defaults.h,
it should be enabled for all the boards except bf506f-ezkit
that undefs it explicitely.
Since CONFIG_CMD_GO is defined in config_cmd_defaults.h
(and no board undefs it its own header), it can be moved to
Kconfig with the default value "y".
Since CONFIG_CMD_EXPORTENV is defined in config_cmd_defaults.h,
Since CONFIG_CMD_CRC32 is defined in config_cmd_defaults.h,
it is enabled for all the boards except the ones undefining it
explicitly:
kwb
tseries_mmc
tseries_nand
tseries_spi
vct_platinum_onenand_small
vct_platinum_small
vct_platinumavc_onenand_small
vct_platinumavc_small
vct_premium_onenand_small
vct_premium_small
The default value of this config option should be "y" and
"# CONFIG_CMD_CRC32 is not set" should be added for those exceptions.
CONFIG_CMD_BOOTM is defined in config_cmd_defaults.h
which is forcebly included from each board.
So, the default value of "config CMD_BOOTM" should be "y".
For some boards undefining it (bf506f-ezkit, controlcenterd_TRAILBLA,
controlcenterd_TRAILBLAZER_DEVELOP, controlcenterd_TRAILBLAZER),
"# CONFIG_CMD_BOOTM is not set" should be added to their defconfig.
This would be useful to start moving various config options.
This is not supported properly on sandbox, and interferes with running
tests, since when a test script is piped in, some commands will call
ctrlc() which will drop characters from the test script.
- add capability to "fastboot flash" with sparse format images
Signed-off-by: Steve Rae <srae@broadcom.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
- update static function
- additional debugging statements
- update "fastboot command" information
- add missing include file
- update spelling
- add support for 'fastboot flash' command for eMMC devices
Currently, CONFIG_SPL_SPI_* #defines are used for controlling SPI boot in
SPL. These #defines do not allow the user to select SPI mode for the SPI flash
(there's no CONFIG_SPL_SPI_MODE, so the SPI mode is hardcoded in
spi_spl_load.c), and duplicate information already provided by
CONFIG_SF_DEFAULT_* #defines.
Kill CONFIG_SPL_SPI_*, and use CONFIG_SF_DEFAULT_* instead.
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Hannes Petermaier <hannes.petermaier@br-automation.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
gd->fdt_blob is used for FDT control of U-Boot.
If CONFIG_OF_CONTROL is not defined, it is useless.
This was breaking the build for some boards:
MPC8536DS MPC8536DS_36BIT MPC8536DS_SDCARD MPC8536DS_SPIFLASH qemu-ppce500
Include only these features for some PPC boards if the configuration for MultiProcessor
is enabled.
Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
Cc: York Sun <yorksun@freescale.com>
Acked-by: York Sun <yorksun@freescale.com>
update to provide usable implementation to U-Boot
- port dprintf() to debug()
- update formatting
- remove unnecessary functions
Add original file (pristine) from :
https://www.codeaurora.org/cgit/quic/la/kernel/lk/plain/app/aboot/aboot.c?h=master
[3b5092d20bd15a7a2879c13e9f64acc48d04af2d]
There are two ways to run into handle_exception, run command 'kgdb' and
encounter a breakpoint which triggers exception handling.
The origin source code only saves regs when first run command 'kgdb'.
Take the following for example, When run 'kgdb', regs is saved to entry_regs.
When run 'bootz', regs is not saved. However, if we set a breakpoint, then
continue. When breakpoint is reached, run `quit`, and Now return to the
instruction which follows kgdb, but not bootz.This may cause errors. So,
save regs for each handle_exception call to return to the correct place.
Example:
Target | Host
=>kgdb | (gdb)b bootz
| (gdb)c
=>bootz |
| (gdb)Here stop because of breakpoint
| (gdb)q
Signed-off-by: Peng Fan <van.freenix@gmail.com>
The parameters of size_t type shall be formatted using "%zu" and not
using "%d".
Precision argument for the "%.*s" parameters shall be of int type.
Signed-off-by: Vasili Galka <vvv444@gmail.com>
For some boards board_init() will change GPIOs, so we need to have driver
model available before then. Adjust the board init to arrange this, but
enable it for driver model only, just to be safe.
This does create additional #ifdef logic, but it is safer than trying to
make a pervasive change which may cause some boards to break.
Since driver model registers itself with the stdio subsystem, and we
want to avoid delayed registration and other complexity associated with
the current serial console, move the stdio subsystem init earlier when
driver model is used for serial.
This simplifies the implementation. Should there be any problems with
this approach they can be dealt with as boards are converted over to
use driver model for serial.
