path: root/common
2014-06-11common: hash: zero end the string instead of the pointerJeroen Hofstee
if algo->digest_size is zero nothing is set in the str_output buffer. An attempt is made to zero end the buffer, but the pointer to the buffer is set to zero instead. I am unaware if it causes any actual problems, but solves the following warning: common/hash.c:217:13: warning: expression which evaluates to zero treated as a null pointer constant of type 'char *' [-Wnon-literal-null-conversion] str_ptr = '\0'; ^~~~ cc: Simon Glass <sjg@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-06-11Use run_command_repeatable()Thomas Betker
Replace run_command() by run_command_repeatable() in places which depend on the return code to indicate repeatability. Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-06-11Add run_command_repeatable()Thomas Betker
run_command() returns 0 on success and 1 on error. However, there are some invocations which expect 0 or 1 for success (not repeatable or repeatable) and -1 for error; add run_command_repeatable() for this purpose. Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-06-11Check run_command() return code properlyThomas Betker
run_command() returns 0 for success, 1 for failure. Fix places which assume that failure is indicated by a negative return code. Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Roese <sr@denx.de>
2014-06-11fdt: Update functions which write to an FDT to return -ENOSPCSimon Glass
When writing values into an FDT it is possible that there will be insufficient space. If the caller gets a useful error then it can potentially deal with the situation. Adjust these functions to return -ENOSPC when the FDT is full. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-11hash: Export the function to show a hashSimon Glass
This function is useful for displaying a hash value, so export it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-10Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-06-05fs: fatwrite: use map_sysmem before use file_fat_writeWu, Josh
When the map_sysmem, then the fatwrite command can support sandbox. Following command will show how to use it: => sb bind 0 sd.img => fatls host 0 => fatwrite host 0 $memaddr filename $filesize Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-05nand_spl: remove nand_spl infrastructureMasahiro Yamada
Remove the common infrastructure of nand_spl and clean-up the code inside ifdef(CONFIG_NAND_U_BOOT)..endif. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-05bootm: make use of legacy image format configurableHeiko Schocher
make the use of legacy image format configurable through the config define CONFIG_IMAGE_FORMAT_LEGACY. When relying on signed FIT images with required signature check the legacy image format should be disabled. Therefore introduce this new define and enable legacy image format if CONFIG_FIT_SIGNATURE is not set. If CONFIG_FIT_SIGNATURE is set disable per default the legacy image format. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Lars Steubesand <lars.steubesand@philips.com> Cc: Mike Pearce <mike@kaew.be> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-05env_eeprom: Assign default environment during board_init_fSiva Durga Prasad Paladugu
Assign default environment and set env valid during board_init_f before relocation as the actual environment will be read from eeprom later. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Acked-by: Michal Simek <monstr@monstr.eu>
2014-06-05Correct return code from builtin_run_command_list()Simon Glass
The return code is not consistent with cli_simple_run_command_list(). For the last command in a sequence, the return code is actually inverted. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-05Fix hush to give the correct return code for a simple commandSimon Glass
When a simple command like 'false' is provided, hush should return the result of that command. However, hush only does this if the FLAG_EXIT_FROM_LOOP flag is provided. Without this flag, hush will happily execute the empty string command immediate after 'false' and then return a success code. This behaviour does not seem very useful, and requiring the flag also seems wrong, since it means that hush will execute only the first command in a sequence. Add a check for empty string and fall out of the loop in that case. That at least fixes the simple command case. This is a change in behaviour but it is unlikely that the old behaviour would be considered correct in any case. Reported-by: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-05Fix itest mask overflowSimon Glass
The mask value used in itest overflows and therefore it can return an incorrect result for something like 'itest 0 == 1'. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-06-01usb: hub: remove CONFIG_USB_HUB_MIN_POWER_ON_DELAYStephen Warren
Now that we wait the correct specification-mandated time at the end of usb_hub_power_on(), I suspect that CONFIG_USB_HUB_MIN_POWER_ON_DELAY has no purpose. For cm_t35.h, we already wait longer than the original MIN_POWER_ON_DELAY, so this change is safe. For gw_ventana.h, we will wait as long as the original MIN_POWER_ON_DELAY iff pgood_delay was at least 200ms. I'm not sure if this is the case or not, hence I've CC'd relevant people to test this change. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-06-01usb: hub: fix power good delay timingStephen Warren
usb_hub_power_on() currently waits for the maximum of (a) the hub port's power output to become good, (b) the max time the USB specification allows a device to take to connect. However, these two operations must occur in series rather than in parallel. First, the power supply ramps up to the level required to power the USB device, and then the device may take a certain amount of time to connect (assert D+/D- pullups). Related, the maximum time that a device has to assert pullups is 1s not 100ms. This is explained in "Connect Timing ECN.pdf", itself part of usb_20_042814.zip from www.usb.org. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-05-30Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-05-29main: Avoid unncessary strdup()/free()Simon Glass
It doesn't seem necessary to use memory allocation in this code. The setenv() will make a copy anyway. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29main: Make the execution path a little clearer in main.cSimon Glass
bootdelay_process() never returns in some circumstances, whichs makes the control flow confusing. Change it so that the decision about how to execute the boot command is made in the main_loop() code, so it is easier to follow. Move CLI stuff to cli.c. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29main: Hide the hush/simple details inside cli.cSimon Glass
Move these details from main (which doesn't care which parser is used) to cli.c where they belong. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Simplify the main loopSimon Glass
The main loop is easier to follow if the code is grouped into separate functions. Make this change, so that main_loop() is easier to read. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29m68k: powerpc: Clean up do_mdm_initSimon Glass
This code seems unnecessarily complex. We really just need to check the global_data. Now that is it all in one place, and not arch-specific, this is pretty easy. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Rename bootretry functions and remove #ifdefsSimon Glass
Add a bootretry_ prefix to these two functions, and remove the need for the #ifdef around everything (it moves to the Makefile). Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move bootretry code into bootretry.c and clean upSimon Glass
This code is only used by one board, so it seems a shame to clutter up the readline code with it. Move it into its own file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move command line API into cli.cSimon Glass
We now have a single entry point to the CLI, whether simple or hush. Put this in its own file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Move autoboot code to autoboot.cSimon Glass
The autoboot code is complex and long. It deserves its own file with a simple interface from main.c. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Add cli_ prefix to readline functionsSimon Glass
This makes it clear where the code resides. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Split out simple parser and readline into separate filesSimon Glass
It doesn't make sense to have the simple parser and the readline code all in main. Split them out into separate files. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29move CLI prototypes to cli.h and add commentsSimon Glass
Move the CLI prototypes from common.h to cli.h as part of an effort to reduce the size of common.h. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Rename hush to cli_hushSimon Glass
Hush is a command-line interpreter, so rename it to make that clearer. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29Remove unnecessary use of hush header fileSimon Glass
Some files include hush.h but don't actually use it. Remove this where possible. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-27dm: rename device struct to udeviceHeiko Schocher
using UBI and DM together leads in compiler error, as both define a "struct device", so rename "struct device" in include/dm/device.h to "struct udevice", as we use linux code (MTD/UBI/UBIFS some USB code,...) and cannot change the linux "struct device" Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Marek Vasut <marex@denx.de>
2014-05-27mkimage: add atmelimageAndreas Bießmann
The new atmelimage converts a machine code BLOB to bootable ROM image. Atmel ROM has no sophisticated image format, it only checks the first 7 ARM vectors. The vectors can contain valid B or LDR opcodes, the 6'th vector contains the image size to load. Additionally the PMECC header can be written by the atmelimage target. The parameters must be given via the -n switch as a coma separated list. For example: mkimage -T atmelimage \ -n usePmecc=1,sectorPerPage=4,sectorSize=512,spareSize=64,eccBits=4,eccOffset=36 \ -d spl/u-boot-spl.bin boot.bin A provided image can be checked for correct header setup. It prints out the PMECC header parameters if it has one and the 6'th interrupt vector content. ---8<--- Image Type: ATMEL ROM-Boot Image with PMECC Header PMECC header ==================== eccOffset: 36 sectorSize: 512 eccBitReq: 4 spareSize: 64 nbSectorPerPage: 4 usePmecc: 1 ==================== 6'th vector has 17044 set --->8--- A SPL binary modified with the atmelimage mkimage target was succesfully booted on a sama5d34ek via MMC and NAND. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Heiko Schocher <hs@denx.de> Tested-by: Bo Shen <voice.shen@atmel.com>
2014-05-23Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2014-05-23cmd_mmc: use new mmc_select_hwpart() functionStephen Warren
The implementation of mmc_select_hwpart() was cribbed from do_mmcops(). Update do_mmcops() to call mmc_select_hwpart() to avoid duplication. <panto> Manual patch update due to patch order. Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-05-23cmd_part: fix typo in part command help textStephen Warren
All the sub-commands start with the main command name, but it was missing from one of the help texts. <panto> typos fix. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-05-23eMMC: cmd_mmc.c adds the 'rpmb' sub-command for the 'mmc' commandPierre Aubert
This sub-command adds support for the RPMB partition of an eMMC: * mmc rpmb key <address of the authentication key> Programs the authentication key in the eMMC This key can not be overwritten. * mmc rpmb read <address> <block> <#count> [address of key] Reads <#count> blocks of 256 bytes in the RPMB partition beginning at block number <block>. If the optionnal address of the authentication key is provided, the Message Authentication Code (MAC) is verified on each block. * mmc rpmb write <address> <block> <#count> <address of key> Writes <#count> blocks of 256 bytes in the RPMB partition beginning at block number <block>. The datas are signed with the key provided. * mmc rpmb counter Returns the 'Write counter' of the RPMB partition. The sub-command is conditional on compilation flag CONFIG_SUPPORT_EMMC_RPMB Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Pierre Aubert <p.aubert@staubli.com> CC: Wolfgang Denk <wd@denx.de>
2014-05-23Add the function 'confirm_yesno' for interactivePierre Aubert
User's confirmation is asked in different commands. This commit adds a function for such confirmation. Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
2014-05-22Merge branch 'fpga' of git://www.denx.de/git/u-boot-microblazeTom Rini
2014-05-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-05-22Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2014-05-20fpga: Added support to load bit stream from SD/MMCSiva Durga Prasad Paladugu
Added support to load a bitstream image in chunks by reading it in chunks from SD/MMC. Command format: loadfs [dev] [address] [image size] [blocksize] <interface> [<dev[:part]>] <filename> Example: fpga loadfs 0 1000000 3dbafc 4000 mmc 0 fpga.bin Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: Add support to load partial bitstreamsMichal Simek
Added support to load partial bitstreams. The partial bitstreams can be loaded using the below commands Commands: fpga loadp <dev> <addr> <size> fpga loadbp <dev> <addr> <size> The full bit streams can be loaded using the old commands(fpga load and fpga loadb). Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: Define bitstream type based on command selectionMichal Simek
Clean up partial, full and compressed bitstream handling. U-Boot supports full bitstream loading and partial based on detection which is not 100% correct. Extending fpga_load/fpga_loadbitstream() with one more argument which stores bitstream type. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20fpga: Guard the LOADMK functionality with CMD_FPGA_LOADMKSiva Durga Prasad Paladugu
Guard the LOADMK functionality with config to provide an option to enable or disable it. Enable it for all platforms in mainline which enable CONFIG_CMD_FPGA. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-20Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
Conflicts: boards.cfg Conflicts were trivial once u-boot-arm/master boards.cfg was reformatted (commit 6130c146) to match u-boot/master's own reformatting (commit 1b37fa83).
2014-05-15Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-05-15nand: remove CONFIG_SYS_NAND_PAGE_SIZETim Harvey
We only need to read in the size of struct image_header and thus don't need to know the page size of the nand device. Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2014-05-12common/board_f: Fix size variableYork Sun
DRAM size should use 64-bit variable when the size could be more than 4GB. Caught and verified on P4080DS with 4GB DDR. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12common/board_f: Initialized global data for generic boardYork Sun
Some platforms (tested on mpc85xx, mpc86xx) use global data before calling function baord_inti_f(). The data should not be cleared later. Any arch which uses global data in generic board board_init_f() should define CONFIG_SYS_GENERIC_GLOBAL_DATA. Signed-off-by: York Sun <yorksun@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Simon Glass <sjg@chromium.org> CC: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org>
