path: root/common
2015-05-14usb: Stop reset procedure when a dev is handed over to a companion hcdHans de Goede
Short circuit the retry loop in legacy_hub_port_reset() by returning an error from usb_control_msg() when a device was handed over to a companion by the ehci code. This avoids trying to reset low / fullspeed devices 5 times needlessly. Also do not print an error when a device has been handed over. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-14usb: legacy_hub_port_reset() check and propagate usb_set_port_feature() errorsHans de Goede
Actually check for usb_set_port_feature() errors and propagate these if they happen. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-14usb: usb_control_msg() propagate controller error codeHans de Goede
Propagate the error returned by submit_control_msg() rather then always returning -EIO when the hcd code indicates an error. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-14Use map_sysmem when accessing memory in setexprJoe Hershberger
The setexpr command used to segfault when accessing memory in sandbox. The pointer accesses should be mapped. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-14Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2015-05-14spl: Correct address in spl_relocate_stack_gd()Simon Glass
During the Kconfig conversion one of the changes was missed. CONFIG_SPL_STACK_R should be CONFIG_SPL_STACK_R_ADDR since we want the address. Reported-by: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-13edid: Add a function to read detailed monitor timingsSimon Glass
For digital displays (such as EDP LCDs) we would like to read the EDID information and use that to set display timings. Provide a function to do this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-10ppc4xx: Remove sc3 boardStefan Roese
As this board seems to be unmaintained for quite some time, and its not moved to the generic board ingrastructure, lets remove it. This will also enable us to remove the CONFIG_AUTOBOOT_DELAY_STR2 and CONFIG_AUTOBOOT_STOP_STR2 macros, as this sc3 board is the only one using one of this macros. A removal patch will follow soon. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Juergen Beisert <jbeisert@eurodsn.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-05-10Fix broken verify functionality in crc32 commandJoe Hershberger
Introduced in change d20a40de9db07de1f1f06a79a4da1cdda5379b75 "Roll crc32 into hash infrastructure" The crc32 command with no -v expects an optional 3rd argument to be an address to store the result in. With the -v switch, the last argument is a crc, not an address. In the case where -v is set, we should set the HASH_FLAG_ENV flag since that will first look for the value to be a digest value, which matches the expected API for the crc32 command. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-10Fix inconsistency of VERIFY defines in cmd_memJoe Hershberger
Introduced in change d20a40de9db07de1f1f06a79a4da1cdda5379b75 "Roll crc32 into hash infrastructure" Use a consistent define to enable the verify feature in crc32 command. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-05-10cmd_part: fix usage textmaxin.john@enea.com
Fix the usage info from: part part uuid <interface> <dev>:<part> to part uuid <interface> <dev>:<part> Signed-off-by: Maxin B. John <maxin.john@enea.com> Reviewed-By: Sjoerd Simons <sjoerd.simons@collabora.co.uk
2015-05-10spl: spl_mmc: Partition raw boot mode for eMMCPaul Kocialkowski
This adds support for providing a partition number instead of a sector for eMMC. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-05-10spl: spl_mmc: Clearer structure in spl_mmc_load_image and cosmeticsPaul Kocialkowski
This refactors spl_mmc_load_image to use a switch/case structure and easier to understand spl_start_uboot checks. This also introduces some more automatic fallback on the next mmc boot mode as long as it keeps failing. Lines that go beyond 80 chars are also reduced by reducing the number of tabs. Debug and error strings are refctored to match a common style. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> [trini: Fix a thinko in the SPL_EXT_SUPPORT + SPL_OS conversion, make part be __maybe_unused] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-05-08image: android: handle default kernel addressMaxime Ripard
The two tools that create android boot images, mkbootimg and the fastboot client, set the kernel address by default to 0x10008000. U-boot always honors this field, and will try to relocate the kernel to whatever value is set in the header, which won't be mapped to the actual RAM on most platforms, resulting in the kernel obviously not booting. All the targets in U-Boot right now will download the android boot image to CONFIG_SYS_LOAD_ADDR, which means that it will already have been downloaded to some location that is suitable for execution. In order to have the kernel booting even with the default boot image kernel address, if that address is used, just execute the kernel where it is. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2015-05-06usb: Fix maxpacketsize for first descriptor read for low-speed usb devsHans de Goede
This fixes descriptor reading of lowspeed devices through ohci not working. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Marek Vasut <marex@denx.de>
2015-05-05dm: rtc: Convert 'date' command to support driver modelSimon Glass
Adjust this command so that it supports using driver model for I2C, i.e. CONFIG_DM_I2C. This will permit it to be used in sandbox also. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-05-05dm: rtc: Rename to_tm() to rtc_to_tm() and add error codeSimon Glass
Rename this function so that it is clear that it is provided by the RTC. Also return an error when it cannot function as expected. This is unlikely to occur since it works for dates since 1752 and many RTCs do not support such old dates. Still it is better to be accurate. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-05-05dm: rtc: Rename gregorian day functionSimon Glass
Change this function name to something more descriptive. Also return a failure code if it cannot calculate a correct value. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-05-05fdt: Correct warning in fdt_setup_simplefb_node()Simon Glass
Adjust the printf() string to avoid a warning on sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-30x86: Allow CPUs to be set up after relocationSimon Glass
This permits init of additional CPU cores after relocation and when driver model is ready. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-29Add a 'cpu' command to print CPU informationSimon Glass
Add a simple command which provides access to a list of available CPUs along with descriptions and basic information. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-29Fix comment nits in board_f.cSimon Glass
Try to make it a little clearer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-04-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-04-28Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2015-04-24Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-04-23armv8/ls2085aqds: NAND boot supportScott Wood
This adds NAND boot support for LS2085AQDS, using SPL framework. Details of forming NAND image can be found in README. Signed-off-by: Scott Wood <scottwood@freescale.com> [York Sun: Remove +S from defconfig after commit 252ed872] Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-23Merge branch 'master' of git://git.denx.de/u-boot-dmTom Rini
2015-04-23cmd, nand: add more info to "nand info"Heiko Schocher
add subpagesize, nand options and bbt options to the "nand info" output. => nand info Device 0: nand0, sector size 256 KiB Page size 4096 b OOB size 256 b Erase size 262144 b subpagesize 4096 b options 0x 200 bbt options 0x 8000 Signed-off-by: Heiko Schocher <hs@denx.de>
2015-04-23rtc: Set valid date after resetMarek Vasut
Some RTC chips tend to set garbage date after reset. This patch sets the date to 2000-01-01 00:00 immediatelly after the RTC chip reset is issued using the "date reset" command. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@konsulko.com>
2015-04-23armv8/fsl-lsch3: Update early MMU tableYork Sun
During booting, IFC is mapped to low region. After booting up, IFC is remapped to high region for larger space. The environmental variables are also stored at high region. In order to read the variables during booting, a virtual mapping is required. Cache was enabled for entire IFC space before. Actually the first two entries are big enough (4MB) to cover the boot code and environmental variables. Remove extra entries. Move OCRAM entry out of ifdef. Signed-off-by: York Sun <yorksun@freescale.com>
2015-04-23cmd_mem: Store last address/size/etc as ulongScott Wood
Otherwise the high 32 bits get truncated on 64-bit U-boot. Signed-off-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: York Sun <yorksun@freescale.com>
2015-04-23dm: Init device tree as well as driver model in SPLSimon Glass
If enabled, make sure that the device tree is available in SPL before setting up driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23Correct malloc_limit value for pre-relocation malloc()Simon Glass
The limit is measured from the start of the malloc() area and is not an absolute address. Correct this. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23Move initf_malloc() to a common placeSimon Glass
To allow this function to be used from SPL, move it to the malloc() code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23fdt: Rename setup_fdt() and make it prepare alsoSimon Glass
There is little reason to split these two functions. Bring them together which simplifies the init sequence. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23fdt: sandbox: Move setup code from board_f to fdtdecSimon Glass
We want to be able to set up the device tree in SPL, so move this code to a common place. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-23cmd_led: Extend led command to support blinking and more ledsStefan Roese
This patch extends the U-Boot "led" command to support automatic blinking by setting a blink frequency in milliseconds. Additionally the number of supported LEDs is increased to 6 (0...5). This will be used by the PCA9551 LED driver. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-22cmd_scsi: Enable SoC AHCI device on platforms with PCItang yuantian
Current driver assumes the AHCI is connected to PCI, this is not true on some SoCs, e.g. LS1021A, which has PCI but the AHCI is in SoC. This patch will enable embedded AHCI devices on platforms with PCI. PCI AHCI devices still can be used by commenting CONFIG_SCSI_AHCI_PLAT option in head file. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-04-22unzip: add gzwrite command to write compressed image to block deviceEric Nelson
Add gzwrite command to write gzip-compressed images to block devices. Input must be gzip-compressed according to RFC1952, since the crc and file size in the trailer will be confirmed during operation. The decompressed file size must be specified on the command line for images with decompressed sizes >= 4GiB because the trailer only contains the low 32 bits of the original file size. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2015-04-22fdt: add new fdt_fixup_display function to configure displayTim Harvey
Add 'fdt_fixup_display' function to fixup device-tree native-mode property of display-timings node to select timings for a specific display. This is useful if a device-tree has configurations for multiple display timings for undetectable displays. see kernel Documentation/devicetree/bindings/video/display-timing.txt Signed-off-by: Tim Harvey <tharvey@gateworks.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-22cmd_sf: Fix problem with "sf update" and unaligned lengthStefan Roese
On SoCFPGA, using "sf update" with an non-4byte aligned length leads to a hangup (and reboot via watchdog). This is because of the unaligned access in the cadence QSPI driver which is hard to prevent since the data is written into a 4-byte wide FIFO. This patch fixes this problem by changing the behavior of the last sector write (not sector aligned). The new code is even simpler and copies the source data into the temp buffer and now uses the temp buffer to write the complete sector. So only one SPI sector write is used now instead of 2 in the old version. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Gerlando Falauto <gerlando.falauto@keymile.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Holger Brunck <holger.brunck@keymile.com> Acked-by: Gerlando Falauto <gerlando.falauto@keymile.com> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2015-04-21kconfig: remove duplicated CMD_DNS optionAndrey Skvortsov
two CMD_DNS options were added by commit 60296a835cb17 ("commands: add more command entries in Kconfig") Signed-off-by: Andrey Skvortsov <andrej.skvortzov@gmail.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-20mii: add read-modify-write option to mii commandTim James
When accessing PHY registers it is often desirable to only update selected bits, so it is necessary to first read the current value before writing back an modified value with the relevant bits updated. To simplify this and to allow such operations to be incorporated into simple shell scripts propose adding a 'modify' option to the existing mii command, which takes a mask indicating the bits to be updated in addition to a data value containing the new bits, ie, <updated> = (<data> & <mask>) | (<current> & ~<mask>). Signed-off-by: Tim <tim.james@macltd.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Tom Rini <trini@konsulko.com> Cc: Tim <tim.james@macltd.com>
2015-04-20Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2015-04-19pxe: Ensure all memory access is to mapped memorySjoerd Simons
Properly map memory through map_sysmem so that pxe can be used from the sandbox. Tested in sandbox as well as on jetson-tk1, odroid-xu3, snow as peach-pi boards Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-19sandbox: Implement host dev [device]Sjoerd Simons
A common pattern to check if a certain device exists (e.g. in config_distro_bootcmd) is to use: <interface> dev [device] Implement host dev [device] so this pattern can be used for sandbox host devices. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-19sandbox: Renamed sb command to hostSjoerd Simons
As suggested by Simon Glass, rename the sb command to host but keep the old sb command as an alias Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: exynos: Move CONFIG_CMD_SOUND to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18Kconfig: Move CONFIG_BOOTSTAGE to KconfigSimon Glass
Move CONFIG_BOOT_STAGE and its associated options to Kconfig. Adjust existing users and code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: net: Adjust PHY interface to work with CONFIG_DM_ETHSimon Glass
When driver model is used for Ethernet a few functions are passed a udevice instead of an eth_device. Also add a function to find a PHY type given its name. This will be used to decode the device tree node. Finally, put a phy_interface field in struct eth_pdata since this is an important part of the platform data for Ethernet. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
