Move this uncommon header out of the common header.
Move this header out of the common header.
Fix up some incorrect code style in calls to functions in the log.h
header, mostly debug().
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Move this fairly uncommon header out of the common header.
Some of the enum members are wrong. Fix them.
We should not be using typedefs and these make it harder to use
forward declarations (to reduce header file inclusions). Drop the typedef.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
Fix up some style problems in flash.h while we are here.
Some functions use the wrong code style and generate checkpatch errors.
Fix these.
With CONFIG_DM_PCI enabled, PCI buses are not enumerated at boot, as they
are without that config option enabled. However, there are cases such as DM
PCI-based Ethernet devices that need the PCI bus enumerated so that they
can be discovered by their drivers.
Currently, to solve this, some boards enumerate the pci bus using
"pci enum" preboot command, while others do it manually in board files
(in board_init/board_late_init/etc. functions).
In order to possibly make the pci enumeration process uniform across all
boards, introduce CONFIG_PCI_INIT_R Kconfig option.
This change also preserves the current behavior in the !DM_PCI case
(pci_init is run unconditionally at boot).
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
Use IS_ENABLED() instead of #ifdef in should_load_env and initr_env
functions.
No functional change intended.
CONFIG_SYS_SDRAM_BASE maybe zero. Avoid a build warning when compiling with
-Wtype-limits.
A large number of boards call preloader_console_init unconditionally.
Currently, they fail to build with CONFIG_SPL_SERIAL=n, because the
function is undefined in that case. To fix the build, always define
preloader_console_init, but make it no-op when CONFIG_SPL_SERIAL=n.
For the few boards that did check for CONFIG_SPL_SERIAL before calling
preloader_console_init, remove the checks, since the function can now
be called unconditionally.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Have this symbol follow the pattern of all other such symbols.
Signed-off-by: Trevor Woerner <twoerner@gmail.com>
Currently displaying status line is done in a weak function
menu_display_statusline().
bootmenu.c overrides the weak default function.
It calls menu_default_choice() and interprets the data as
struct bootmenu_entry.
pxe boot also uses common menu code for pxe menus.
If there is a system that enables both bootmenu and pxe,
menu_display_statusline() defined in bootmenu.c will be called
and it will interpret struct pxe_label as struct bootmenu_entry.
This leads to data aborts and pxe menu corruptions.
This patch adds support for client defined statusline function
to resolve the above bug.
Signed-off-by: Thirupathaiah Annapureddy <thiruan@linux.microsoft.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
i.MX for 2020.07
- imxrt: fix LCD clock, fix doc
- new board: Coral Dev
- imx8: enable Cache in SPL. SNVS, update SCFW API
- imx8MM: fix reset, 8MQ quand and QuadLite, CPU speed grading
- MX6ULL : is_imx6ull to include i.MX6ULZ
- Net: add config to enable TXC delay
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/682033914
Current print_cpuinfo gets the first udevice in CPU class to return
the cpu info. This has problem if the boot CPU is not fixed.
Changing to use new API cpu_get_current_dev to fix the issue.
Signed-off-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
When enable CONFG_SPL_DM_USB_GADGET, sdp should use
usb_gadget_initialize() and usb_gadget_release() to
support DM gadget driver.
Signed-off-by: Sherry Sun <sherry.sun@nxp.com>
Because SDP directly jumps to next level boot image, we'd better
clean up the USB driver before it. Implement a weak callback function,
that spl sdp can use it to clean up USB driver.
Add a new configuration CONFIG_SPL_SDP_USB_DEV to specify the
usb index for spl sdp driver, so that we change use different device.
The default value is 0.
Need initialize UDC before run sdp download
Signed-off-by: Frank Li <Frank.Li@nxp.com>
mode"
The CONFIG_SPL_FORCE_MMC_BOOT config flag is not needed as its behavior
is the correct one in all cases; using spl_boot_device() instead of the
boot_device parameter will lead to inconsistency issues, for example,
when a board_boot_order() is defined. In fact, this is the reason the
parameter was introduced in the first place, in commit 2b1cdafa9fdd
("common: Pass the boot device into spl_boot_mode()").
This reverts commit 772b55723bcbe8ebe84f579d9cdc831d8e18579d.
Link: https://lists.denx.de/pipermail/u-boot/2020-April/405979.html
Signed-off-by: Harald Seiler <hws@denx.de>
Drop initr_bedbug wrapper and call bedbug_init directly during the init
sequence.
Signed-off-by: Ovidiu Panait <ovpanait@gmail.com>
initr_enable_interrupts() is an ARM-specific wrapper over
enable_interrupts(), which is run during the common init sequence. It can
be eliminated by moving the enable_interrupts() call to the end of
interrupt_init() function, in arch/arm/lib/interrupts*.c.
times
Malloc gets initialized with a call to mem_malloc_init() with the address
the allocation starts to and its size. Currently it is not possible to
move the malloc from one memory area to another as the malloc would eventually
fail.
This patch adds in the ability to re-init the malloc with the updated
start address and the size.
One of the use cases of this feature is SPL U-Boot running from within
the static memory and calling to malloc init from within board_init_f():
arch/arm/cpu/armv8/start.S:reset vector
arch/arm/cpu/armv8/start.S:main()
arch/arm/lib/crt0_64.S:board_init_f()
board/<my_board>/common/spl.c:board_init_f()
board/<my_board>/common/spl.c:mem_malloc_init((ulong)CONFIG_SYS_SPL_MALLOC_START,
CONFIG_SYS_SPL_MALLOC_SIZE);
Shortly after the DDR (main) memory is init and ready we call to malloc init
again but this time with the start address in the DDR memory and a much greater
size for moving the allocation off the static to the DDR memory:
board/<my_board>/common/spl.c:mem_malloc_init((ulong)CONFIG_SPL_MALLOC_OFFSET,
CONFIG_SPL_MALLOC_SIZE);
Where CONFIG_SYS_SPL_MALLOC_START and CONFIG_SPL_MALLOC_OFFSET are the start
addresses of the malloc in the static and DDR memories respectively and
CONFIG_SYS_SPL_MALLOC_SIZE=SZ_16K and CONFIG_SPL_MALLOC_SIZE=SZ_2M are
the sizes of the mallocs in these memories. Note, now we have a much greater
memory, enlarging from 16K to 2M, available for allocation.
There is an alternative approach already existing in U-Boot with the use of
an early (simplified) malloc and the proper (dlamalloc) malloc however
necessitating managing the two mallocs whereas this approach proposes using
a single dlmalloc.
Signed-off-by: Marek Bykowski <marek.bykowski@gmail.com>
The signature check on config node is broken on fit with padding.
To compute the signature for config node, U-Boot compute the
signature on all properties of requested node for this config,
except for the property "data". But, when padding is used for
binary in a fit, there isn't a property "data" but two properties:
"data-offset" and "data-size". So to fix the check of signature,
we also don't use the properties "data-offset" and "data-size"
when checking the signature on config node.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
free() checks if its argument is NULL. Don't duplicate this in the calling
code.
Move Python tools to use absolute paths
Minor buildman fixes for new features
Make libfdt code more similar to upsteam
This patch adds support for decompressing LZMA compressed u-boot payload
in legacy uImage format.
Using this patch together with u-boot-lzma.img may be useful for some
platforms as they can reduce the size and load time of u-boot payload.
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
With the if statement now for the legacy image handling, the compiler
now generates this compile time warning:
common/spl/spl_nor.c:27:6: warning: unused variable 'ret' [-Wunused-variable]
This patch removes this warning by changing the 'ret' variable handling.
Cc: Weijie Gao <weijie.gao@mediatek.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Move the legacy image loading into spl_legacy.c. This makes it easier
to extend the legacy image handling with new features that other
SPL loaders might use (e.g. spl_spi.c etc).
Use IS_ENABLED() instead of #ifdef CONFIG_ to remove one #ifdef.
This patch moves the legacy image handling into a separate file, which
will be extended with other legacy image features later.
No function change intended.
There is no need to cast from (void *) before assigning to a pointer.
fdt_region APIs are not part of libfdt. They are U-Boot extension
for the verified boot. Split the declarations related to fdt_region
out of <fdt_region.h>. This allows <linux/libfdt.h> to become a
simple wrapper file, like Linux does.
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
My goal is to sync lib/libfdt/ with scripts/dtc/libfdt/, that is,
make lib/libfdt/ contain only wrapper files.
fdt_region.c was written only for U-Boot to implement the verified
boot. So, this belongs to the same group as common/fdt_support.c,
which is a collection of U-Boot own fdt helpers.
Move lib/libfdt/fdt_region.c to common/fdt_region.c . This is
necessary only when CONFIG_(SPL_TPL_)_FIT_SIGNATURE is enabled.
The free() function checks if its argument is NULL. It is superfluous to do
the same check on the calling side.
Introduce arch_reserve_mmu to allow for architecture-specific reserve_mmu
routines. Also, define a weak nop stub for it.
Move the ARM-specific reserve_mmu definition from common/board_f.c
to arch/arm/lib/cache.c.
Two nearly concurrent commits (d4d65e112 and bcee8d676) added a
SPL_DM_GPIO symbol. Resolve the duplication in favor of the version
in drivers/gpio/Kconfig.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
Reviewed-by: Frieder Schrempf <frieder.schrempf@kontron.de>
We cannot run unit tests in SPL. So remove the unit test support.
Do not build image_sign_info helper functions in SPL if not needed.
Fixes: b983cc2da0ba ("lib: rsa: decouple rsa from FIT image verification")
With SBI v0.2 HSM extension, only a single hart need to boot and
enter operating system. The booting hart can bring up secondary
harts one by one afterwards.
For U-Boot running in SPL, SMP can be turned on, while in U-Boot
proper, SMP can be optionally turned off if using SBI v0.2 HSM.
Introduce a new SPL_SMP Kconfig option to support this.
Reviewed-by: Atish Patra <atish.patra@wdc.com>
