Now that we have sha1 and md5 in lib_generic, allow people to use
them on the command line, for checking downloaded files.
Signed-off-by: Robin Getz <rgetz@analog.com>
If the size of a region equal to 4G it can't be represnted in a 32-bit
BAR so we should have marked that case as MEM64.
Additionally bump the number of inbound windows up to 4 to handle the
fact that Freescale PPCs that have an implicit window for CCSRBAR.
An off-by-one error in hush.c resulted in an unintentional free() call
every time a command was executed
The only environment type that uses this variable is spi flash, and that is
only because it is reimplementing the common set_default_env() function.
So fix the spi flash code and kill off the default_environment_size in the
process.
While we're here, fix the broken #ifdef handling in _exports.h.
Make the ext2load command return 0 on success (instead of the file
length).
Also fix output format (get rid of random newlines) and some coding
style issues (long lines etc.).
Loading vxWorks 5.x images resulted just into 3 or 4 lines of output.
With vxWorks 6.x and the new GCC it emits about 30 lines, which is
far too noisy in my opinion.
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
Now 'env_addr' type is loff_t so use correct field type.
This moves some extern declaration from lcd.c to lcd.h, removing
unneeded ifdef around a pair of them. Additionally, since
gunzip_bmp() was declared static in cmd_bmp.c but extern in lcd.c, I
removed the static. The extra "#include <lcd.h>" in cmd_bmp.c is
added to ensure the header is consistent with the source.
This has been compile-tested on both ARM (at91 boards) and PowerPC
(HH405_config, TQM823L_LCD_config, mcc200_config), to test all use
combinations.
Signed-off-by: Alessandro Rubini <rubini@gnudd.it>
[agust@denx.de: removed gunzip_bmp() fixes as commit c01171ea did it]
This patch removes the static declaration from gunzip_bmp()
Without it, the gunzip_bmp() function is not visible to
common/lcd.c and fails to compile with an error.
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
- Fix command help message
- Disable DEBUG by default
- Fix whitespace issues
- Fix lines > 80 characters
Signed-off-by: Peter Tyser <ptyser@gmail.com>
Support for this type was lost during the bootm refactoring.
Signed-off-by: Detlev Zundel <dzu@denx.de>
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot.
http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html
> DNS can be enabled by setting CFG_CMD_DNS. After performing a query,
> the serverip environment var is updated.
> Probably there are some cosmetic issues with the patch. Unfortunatly I
> do not have the time to correct these. So if anybody else likes DNS
> support in U-Boot and has the time, feel free to patch it in the main tree.
Here it is again - slightly modified & smaller:
- update to 2009-06 (Pieter's patch was for U-Boot 1.2.0)
- README.dns is added
- syntax is changed (now takes a third option, the env var to store
the result in)
- add a random port() function in net.c
- sort Makefile in ./net/Makefile
- dns just returns unless a env var is given
- run through checkpatch, and clean up style issues
- remove packet from stack
- cleaned up some comments
- failure returns much faster (if server responds, don't wait for
timeout)
- use built in functions (memcpy) rather than byte copy.
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl>
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
Fix incorrect information about size units and correct typo.
Signed-off-by: Andrzej Wolski <awolski@poczta.fm>
fix this gcc 4.4 warning:
xyzModem.c: In function 'xyzModem_stream_open':
xyzModem.c:564: warning: 'dummy' is used uninitialized in this function
Commit 5669ed45 ("cmd_flash.c: fix warning: unused variable
'addr_first'/'addr_last'") changed the #ifdef logic areound the
declaration of these variables and missed a combination of settings
of HAS_DATAFLASH with SYS_NO_FLASH; this patch fixes this.
Also spotted by Alessandro Rubini <rubini@gnudd.com>
From: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
This patch adds support for the Tundra TSI148 VME-bridge. It's used on
the upcoming esd VME8349 board.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Create stdio_print_current_devices() for this purpose
The sub-command parser missed a brace, so "return 0;" is always
taken and no error message is diplayed if you say "i2c scan"
instead of "i2c probe", for example.
Proper brace is added. Also, a misleading and unneeded else
is removed.
Signed-off-by: Alessandro Rubini <rubini@gnudd.com.it>
So far the console API uses the following naming convention:
======Extract======
typedef struct device_t;
int device_register (device_t * dev);
int devices_init (void);
int device_deregister(char *devname);
struct list_head* device_get_list(void);
device_t* device_get_by_name(char* name);
device_t* device_clone(device_t *dev);
which is too generic and confusing.
Instead of using device_XX and device_t we change this
into stdio_XX and stdio_dev
This will also allow to add later a generic device mechanism in order
to have support for multiple devices and driver instances.
Edited commit message.
The curr_device variable really should be namespaced with a "sata_" prefix
since it is only used by the sata code. It also avoids random conflicts
with other pieces of code (like cmd_mmc):
common/libcommon.a(cmd_sata.o):(.data.curr_device+0x0):
multiple definition of `curr_device'
common/libcommon.a(cmd_mmc.o):(.data.curr_device+0x0): first defined here
The curr_device variable isn't used outside of cmd_mmc, so mark it static
to avoid conflicts with other pieces of code (like sata which also exports
a curr_device). Otherwise we end up with stuff like:
This patch adds support splash image positioning by adding an
additional variable "splashpos" to the environment. Please see
README for details.
Signed-off-by: Matthias Weisser <matthias.weisser@graf-syteco.de>
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Legacy NAND had been scheduled for removal. Any boards that use this
were already not building in the previous release due to an #error.
The disk on chip code in common/cmd_doc.c relies on legacy NAND,
and it has also been removed. There is newer disk on chip code
in drivers/mtd/nand; someone with access to hardware and sufficient
time and motivation can try to get that working, but for now disk
on chip is not supported.
Also use mtd operation instead of onenand functions
This patch implements simple hwconfig infrastructure: an
interface for software knobs to control a hardware.
This is very simple implementation, i.e. it is implemented
via `hwconfig' environment variable. Later we could write
some "hwconfig <enable|disable|list>" commands, ncurses
interface for Award BIOS-like interface, and frame-buffer
interface for AMI GUI[1] BIOS-like interface with mouse
support[2].
Current implementation details/limitations:
1. Doesn't support options dependencies and mutual exclusion.
We can implement this by integrating apt-get[3] into the
u-boot. But I didn't bother yet.
2. Since we don't implement hwconfig command, i.e. we're working
with the environement directly, there is no way to tell that
toggling a particular option will need a reboot to take
an effect. So, for now it's advised to always reboot the
target after modifying hwconfig variable.
3. We support hwconfig options with arguments. For example,
set hwconfig dr_usb:mode=peripheral,phy_type=ulpi
That means:
- dr_usb - enable Dual-Role USB controller;
- dr_usb:mode=peripheral - USB in Function mode;
- dr_usb:phy_type=ulpi - USB should work with ULPI PHYs;
The purpose of this simple implementation is to define some
internal API and then we can continue improving user experience
by adding more mature interface, like hwconfig command with
bells and whistles. Or not adding, if we feel that current
interface fits its needs.
[1] http://en.wikipedia.org/wiki/American_Megatrends
[2] Regarding ncurses and GUI with mouse support -- I'm just
kidding.
[3] The comment regarding apt-get is also a joke, meaning that
dependency tracking could be non-trivial. For example, for
enabling HW feature X we may need to disable Y, and turn Z
into reduced mode (like RMII-only interface for ethernet,
no MII).
It's quite trivial to implement simple cases though.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Change strtoul number base of argv 3 from 0 to 16
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
Check that an argument is passed to ubifsmount and that addresses and
sizes are actually numbers for ubifsload. Also improve the instructions
a bit.
Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
The VID header offset is sometimes needed to initialize the UBI
partition. This patch adds it (optionally) to the command line
for the ubi part command.
(Lines have been properly wrapped since last version)
If use the onenand boot, the env_relocate_spec() calls mtd->read(),
and the type of the argument #2 of mtd->read() was changed to loff_t.
But, the "env_addr" type is still unsigned long, thus this patch change
the type from unsigned long to loff_t.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
Currently, when booting from NAND using nand_spl, in the beginning the default
environment is used until later in boot process the dynamic environment is read
out. This way environment variables that must be interpreted early, like the
baudrate or "silent", cannot be modified dynamically and remain at their
default values. Fix this problem by reading out main and redundand (if used)
copies of the environment in the nand_spl code.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
The "nand markbad" and "onenand markbad" commands did not check if an
argument was passed; if this was forgotten, no error was raised but
block 0 was marked as bad.
While fixing this bug, clean up the code a bit and allow to pass more
than one block address, thus allowing to mark several blocks as bad
in a single command invocation.
Remove an unused "total" variable in multiple functions.
Defining the next two configs allows to switch the serial port from the
console using the setenv stdin and stdout
1. #define CONFIG_SERIAL_MULTI 1 /* Enable both serial ports */
2. #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Newer Blackfin parts can an on-chip ROM that can boot LDRs over SPI flashes,
so add a new 'spibootldr' command to take advantage of it.
Use the standard lowercase "xx" capitalization that other Freescale
architectures use for CPU defines to prevent confusion and errors
Move needed definitions (register descriptions etc.) from
include/mpc512x.h into include/asm-ppc/immap_512x.h.
Instead of using a #define'd register offset, use a function that
provides the PATA controller's base address.
All the rest of include/mpc512x.h are register offset definitions
which can be eliminated by proper use of C structures.
There are only a few register offsets remaining that are needed in
cpu/mpc512x/start.S; for these we provide cpu/mpc512x/asm-offsets.h
which is intended as a temporary workaround only. In a later patch
this file will be removed, too, and then auto-generated from the
respective C structs.
Cc: John Rigby <jcrigby@gmail.com>
Many of the help messages were not really helpful; for example, many
commands that take no arguments would not print a correct synopsis
line, but "No additional help available." which is not exactly wrong,
but not helpful either.
Commit ``Make "usage" messages more helpful.'' changed this
partially. But it also became clear that lots of "Usage" and "Help"
messages (fields "usage" and "help" in struct cmd_tbl_s respective)
were actually redundant.
This patch cleans this up - for example:
Before:
=> help dtt
dtt - Digital Thermometer and Thermostat
Usage:
dtt - Read temperature from digital thermometer and thermostat.
After:
=> help dtt
dtt - Read temperature from Digital Thermometer and Thermostat
Usage:
dtt
In case of incorrect command invocations U-Boot used to print pretty
useless "usage" messages, for example:
=> nand markbad
Usage:
nand - NAND sub-system
In the result, the user would have to run the "help" command to get
the (available) information about correct command usage. Change this,
so that this information gets always printed.
Note that this changes the user interface of all commands, but
hopefully to the better.
The printing code would check the same environment byte multiple times and
write to the console one byte at a time. For some devices (such as the
Blackfin JTAG console which operates in 8 bytes at a time), this is pretty
damned slow. So create a small 16 byte buffer to fill up and send to puts
as needed. In the process, unify the different print functions, shrink
the resulting code (source and compiled), and avoid excess env reads as
those too can be somewhat expensive depending on the board.
The kernel stores address<->symbol names in it so things can be decoded at
runtime. Do it in U-Boot, and we get nice symbol decoding when crashing.
