path: root/common
2009-06-12cmd_i2c: Fix i2c help command output when CONFIG_I2C_MUXPeter Tyser
When CONFIG_I2C_MUX was defined the output of 'help i2c' was not correct, eg: => help i2c i2c bus [muxtype:muxaddr:muxchannel] - add a new bus reached over muxes. speed [speed] - show or set I2C bus speed i2c dev [dev] - show or set current I2C bus ... It has been changed to: i2c speed [speed] - show or set I2C bus speed i2c bus [muxtype:muxaddr:muxchannel] - add a new bus reached over muxes i2c dev [dev] - show or set current I2C bus ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12cmd_i2c: Clean up trivial helper functionsPeter Tyser
2009-06-12cmd_i2c: Clean up i2c command argument parsingPeter Tyser
argc and argv should only be modified once instead of once for every i2c sub-command Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12i2c: Update references to individual i2c commandsPeter Tyser
The individual i2c commands imd, imm, inm, imw, icrc32, iprobe, iloop, and isdram are no longer available so all references to them have been updated to the new form of "i2c <cmd>". Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12i2c: Remove deprecated individual i2c commandsPeter Tyser
The following individual I2C commands have been removed: imd, imm, inm, imw, icrc32, iprobe, iloop, isdram. The functionality of the individual commands is still available via the 'i2c' command. This change only has an impact on those boards which did not have CONFIG_I2C_CMD_TREE defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12i2c: Create common default i2c_[set|get]_bus_speed() functionsPeter Tyser
New default, weak i2c_get_bus_speed() and i2c_set_bus_speed() functions replace a number of architecture-specific implementations. Also, providing default functions will allow all boards to enable CONFIG_I2C_CMD_TREE. This was previously not possible since the tree-form of the i2c command provides the ability to display and modify the i2c bus speed which requires i2c_[set|get]_bus_speed() to be present. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12i2c.h: Provide a default CONFIG_SYS_I2C_SLAVE valuePeter Tyser
Many boards/controllers/drivers don't support an I2C slave interface, however CONFIG_SYS_I2C_SLAVE is used in common code so provide a default Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-02mmc: check find_mmc_device return valueRabin Vincent
find_mmc_device returns NULL if an invalid device number is specified. Check for this to avoid dereferencing NULL pointers. Signed-off-by: Rabin Vincent <rabin@rab.in>
2009-06-02mmc: clean up help textsRabin Vincent
Remove some repeated words and superfluous newlines in the mmc command help entries. Signed-off-by: Rabin Vincent <rabin@rab.in>
2009-05-28jffs2/mtdparts: Fix problem with usage from JFFS2 and MTDPARTS togetherStefan Roese
Currently using JFFS2 with MTDPARTS enabled doesn't work. This is because mtdparts_init() is available in both files, cmd_mtdparts.c and cmd_jffs2.c. Please note that in the original cmd_jffs2.c file (before the jffs2/mtdparts command/file split those 2 different versions already existed. So this is nothing new. The main problem is that the variables "current_dev" and "current_partnum" are declared in both files now. This doesn't work. This patch now changes the names of those variable to more specific names: "current_mtd_dev" and "current_mtd_partnum". This is because this patch also changes the declaration from static to global, so that they can be used from both files. Please note that my first tests were not successful. The MTD devices selected via mtdparts are now accessed but I'm failing to see the directory listed via the "ls" command. Nothing is displayed. Perhaps I didn't generate the JFFS2 image correctly (I never used JFFS2 in U-Boot before). Not sure. Perhaps somebody else could take a look at this as well. I'll continue looking into this on Monday. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Renaud barbier <renaud.barbier@ge.com>
2009-05-20Merge branch 'master' of git://git.denx.de/u-boot-ubiWolfgang Denk
2009-05-20common: fix inline--weak error spotted by gcc 4.4Kim Phillips
cmd_ide.c:547: error: inline function 'ide_inb' cannot be declared weak removing the inline attribute fixes it. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-05-20UBI: fix return code in ubi_volume_readAndreas Huber
Return -ENODEV instead of 0 when trying to read from a non existing volume. Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-05-15Remove inline qualifier from show_boot_progress()Emil Medve
The 'inline' is conflicting with the semantic of 'weak' attribute and with the way the show_boot_progress() function is used. Also gcc 4.4 is complaining about it: main.c:51: error: inline function 'show_boot_progress' cannot be declared weak Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
2009-05-15netloop: updates for NetLoopHeiko Schocher
Fix some issues introduced from commit: 2f70c49e5b9813635ad73666aa30f304c7fdeda9 suggested by Mike Frysinger. - added some comment for the env_id variable in common_cmd_nvedit.c - moved some variables in fn scope instead of file scope - NetInitLoop now static void Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-04-28cmd_ext2.c: fix compile warningsWolfgang Denk
Get rid of these warnings: cmd_ext2.c:247: warning: format '%ld' expects type 'long int', but argument 2 has type 'int' cmd_ext2.c:248: warning: format '%lX' expects type 'long unsigned int', but argument 3 has type 'int' Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-28ubi: Remove flash selection parameter (nor|nand|onenand) from "ubi part"Stefan Roese
This patch removes the now unnecessary flash type parameter from the "ubi part" command. Currently the user has to define the type of flash he will be using UBI on. Example: => ubi part nor partition1 With this patch this type parameter is not needed anymore. The user can now select the partition directly without the flash type paramter. Example: => ubi part partition1 This breaks backward compatibility right now because of the change in the command syntax. But UBI support is still quite fresh and the advantage of this new command is syntax big enough for this change. Additionally the code is much cleaner now. Signed-off-by: Stefan Roese <sr@denx.de> CC: Kyungmin Park <kyungmin.park@samsung.com>
2009-04-28Separate mtdparts command from jffs2Ladislav Michl
On Thu, Mar 19, 2009 at 01:30:36PM +0100, Stefan Roese wrote: > Currently the mtdparts commands are included in the jffs2 command support. > This doesn't make sense anymore since other commands (e.g. UBI) use this > infrastructure as well now. This patch separates the mtdparts commands from > the jffs2 commands making it possible to only select mtdparts when no JFFS2 > support is needed. One more leftover... Let nboot command know about partitions even if JFFS2 support is not enabled. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Stefan Roese <sr@denx.de>
2009-04-28cmd_ide: Remove unused AmigaOneG3SE codePeter Tyser
The output_data_short() and input_data_short() functions for the AmigaOneG3SE are unused and result in compiler warnings. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-28mtdpart command: align output columnsDavid Brownell
Make the headers in the "mtdparts" command output line up with their columns ... strike the extra TAB character. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-04-28fs: Fix the wrong type of varGao Guanhua
The filelen should be signed type, not unsigned type. otherwise, The condition as below never take. if (filelen < 0) Signed-off-by: Gao Guanhua <B22826@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com>
2009-04-16cmd_nand: drop duplicate NULL ptr checkMike Frysinger
The first if statement checks for NULL ptrs, so there is no need to check it again in later else cases (such as .oob). Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Scott Wood <scottwood@freescale.com>
2009-04-05One more fix for building env_embedded.oWolfgang Denk
In addition to the changes for CONFIG_ENV_IS_IN_FLASH as done in commit afcbce07, we also need to do the same for CONFIG_ENV_IS_IN_EEPROM and CONFIG_ENV_IS_IN_NVRAM. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-04common/image.c: Relocate strings in tables.Scott Wood
Without this, u-boot can crash or print garbage if the original link address no longer points to a valid string. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-04-04UBI/cfi-mtd: Fix mtd name for multiple chipsAndreas Huber
On platforms with multiple NOR chips, currently only the first one can be selected using the "ubi part" command. This patch fixes this problem by using different names for the NOR "mtd devices". It also changes the name of the NOR MTD device from "cfi-mtd" to "norX" (X indexing the device numer) to better match the mtdparts defaults. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Andreas Huber <andreas.huber@keymile.com>
2009-04-04cmd_mmc: add support for device command for selecting mmc deviceMinkyu Kang
This patch improves device command for selecting mmc device Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-04-04more command usage cleanupMike Frysinger
Fix up a few dangling commands like in "Command usage cleanup" commit. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-04Separate mtdparts command from jffs2Ladislav Michl
On Thu, Mar 19, 2009 at 01:30:36PM +0100, Stefan Roese wrote: > Currently the mtdparts commands are included in the jffs2 command support. > This doesn't make sense anymore since other commands (e.g. UBI) use this > infrastructure as well now. This patch separates the mtdparts commands from > the jffs2 commands making it possible to only select mtdparts when no JFFS2 > support is needed. ... and to make it useful for NAND chips as well, we should also remove now unrelated CONFIG_JFFS2_NAND. Note that struct part_info etc is in jffs2/load_kernel.h which is a bit misleading filename for that purpose, but that can be fixed later (tm). Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-04-04add dataflash mmc mux missing supportJean-Christophe PLAGNIOL-VILLARD
2009-04-04Fix quoting bug introduced by commit 74de7aefWolfgang Denk
2009-04-04Fix building of env_embedded.oWolfgang Denk
Since commit a706bfc7 common/env_embedded.o and tools/envcrc were only built when CONFIG_ENV_IS_EMBEDDED was set, but this breaks building for many boards. We always have to build these files when CONFIG_ENV_IS_IN_FLASH is set. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-04rename include/zlib.h to include/u-boot/zlib.hJean-Christophe PLAGNIOL-VILLARD
Some systems have zlib.h installed in /usr/include/. This isn't the desired file for u-boot code - we want the one in include/zlib.h. This rename will avoid the conflict. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-04common/Makefile: Conditionally compile env_embedded.oPeter Tyser
2009-04-03mflash: Initial mflash supportunsik Kim
Mflash is fusion memory device mainly targeted consumer eletronic and mobile phone. Internally, it have nand flash and other hardware logics and supports some different operation (ATA, IO, XIP) modes. IO mode is custom mode for the host that doesn't have IDE interface. (Many mobile targeted SoC doesn't have IDE bus) This driver support mflash IO mode. Followings are brief descriptions about IO mode. 1. IO mode based on ATA protocol and uses some custom command. (read confirm, write confirm) 2. IO mode uses SRAM bus interface. Signed-off-by: unsik Kim <donari75@gmail.com>
2009-04-03Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2009-04-03Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2009-04-03Noisily disable the legacy NAND subsystem.Scott Wood
Legacy NAND is marked for feature removal after April 2009 (i.e. this upcoming release). There are still several boards that reference it (though many do so only for disk-on-chip support which has been silently disabled for a while now). These boards will now fail to build with #error, though the code is still there if the user removes #error. The plan is to remove the code outright in the next release, along with any board code that refers to it (such as board/esd/common/auto_update.c). Also, remove the legacy NAND API description from README.nand. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-02Blackfin: drop newline from OTP helpMike Frysinger
Looks like I accidentally added a newline to the OTP help when merging and older change. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-30fsl-ddr: add the DDR3 SPD infrastructureDave Liu
- support mirrored DIMMs, not support register DIMMs - test passed on P2020DS board with MT9JSF12872AY-1G1D1 - test passed on MPC8569MDS board with MT8JSF12864HY-1G1D1 Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Travis Wheatley <travis.wheatley@freescale.com>
2009-03-29ARM: fix warning: 'print_eth' defined but not usedWolfgang Denk
This warning got issued for all ARM systems that don't have CONFIG_CMD_NET enabled. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-28Fix implicit declaration of function 'eth_[gs]etenv_enetaddr'Wolfgang Denk
...and some other compile warnings. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-27command.c: Expose the core of do_help as _do_help to the rest of u-boot.Detlev Zundel
Other commands implementing subcommands can reuse this code nicely. Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Andreas Pfefferle <ap@denx.de>
2009-03-27ppc: cleanup compiler errors/warningsHeiko Schocher
Current u-boot top of tree builds with warnings/errors for the following boards: ads5121 cpci5200 mecp5200 v38b IAD210 MBX MBX860T NX823 RPXClassic debris PN62 following patch solves this. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-03-23Enable multi chip support in the NAND layerWolfgang Grandegger
This patch adds support for NAND_MAX_CHIPS to the MTD NAND layer. Multi-chips devices are displayed as shown: Device 0: 2x NAND 512MiB 3,3V 8-bit, sector size 128 KiB Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-20UBIFS: Add UBIFS commandsStefan Roese
This patchset adds these UBIFS related commands: - ubifsmount Mount an UBIFS volume - ubifsls List a directory of the mounted UBIFS volume - ubifsload Load a file from the mounted UBIFS volume to memory Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-03-20nvedit: do not update global bi_enetaddr and do not call eth_set_enetaddr()Mike Frysinger
Since the ethernet layer handles updating of device addresses itself from the environment, there is no point in calling eth_set_enetaddr(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20lynxkdi: get mac address from environmentMike Frysinger
