We should aim for a single point of entry to the commands, whichever
parser is used.
This saves about 1KB of code space on ARM with CONFIG_SYS_HUSH_PARSER
defined.
Boards can select either the 'built-in' parser or the hush parser. We
should not call builtin_run_command() if we are using the hush parser.
We use run_command() instead, since it knows how to call the correct
parser.
This is a more sensible name, so rename it.
The current run_command() is only one of the parsing options - the other
is hush. We should not call run_command() when the hush parser is being
used. So we rename this function to better explain its purpose.
It really isn't clear why this is here and there is no comment, so
drop it.
Following the corresponding Linux code, this patch relaxes reset timings
waiting at least 100ms after power to the ports. There are some reports
that it helps make enumeration work better on some high speed devices.
Furthermore, the wait is only done once after power has been enabled
on all ports.
CC: Remy Bohmer <linux@bohmer.net>
CC: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
This moves keyboard polling logic from USB HCD drivers into USB
keyboard driver. Remove usb_event_poll() as keyboard polling was
the only user of this API. With this patch USB keyboard works with
EHCI controllers again. Tested on a tegra2 seaboard.
Signed-off-by: Allen Martin <amartin@nvidia.com>
If CONSOLE_MUX is enabled, reevaluate console stdin when USB keyboard
device is detected.
When keys are pressed on the numeric keypad, emit key codes for the numbers,
operators, dot and enter.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
When doing a "GET_REPORT" request on the keyboard control endpoint,
the report ID should 0 (ie report ID not used) rather than 1
as reports are not used in boot mode.
Cc: Remy Bohmer <linux@bohmer.net>
* 'master' of git://git.denx.de/u-boot-nand-flash:
cmd_nand.c: Fix 'nand dump' after latest MTD resync
mtd/nand:Fix wrong usage of is_blank() in fsl_ifc_run_command
mtd/nand: Fix IFC driver to support 2K NAND page
nand: reinstate lazy bad block scanning
Revert "nand: make 1-bit software ECC configurable"
With 2a8e0fc nand_do_read_ops changed in behavior slightly (keeping in sync
with the kernel which did this change in b64d39d8) such that the OOB data is
always copied into oobbuf and never appended to datbuf. Within U-Boot only
the nand_dump function (for the dump nand subcommand) was expecting the OOB
data to only be appended to datbuf. So we now change nand_dump to not
malloc extra space, correct the comment about datbuf and OOB data and switch
the pointer to oobbuf before printing.
Cc: Scott Wood <scottwood@freescale.com>
The commit message of a28afca (Add uboot "fdt_high" enviroment variable)
states that fdt_high behaves similarly to the existing initrd_high.
But fdt_high actually has an outstanding difference from initrd_high.
The former specifies the start address, while the later specifies the
end address.
As fdt_high and initrd_high will likely be used together, it'd be nice
to have them behave same. The patch changes the behavior of fdt_high
to have it aligned with initrd_high.
The document of fdt_high in README is updated with an example to
demonstrate the usage of this environment variable.
* 'trini@ti.com' of git://git.denx.de/u-boot-staging:
usb_ether: fix typo
cmd_eeprom: typo
doc: complete, typos
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
* 'sf' of git://git.denx.de/u-boot-blackfin:
README: Add description of SPI Flash (SF) command configuration
sf command: allow default bus and chip selects
sf: eeprom_m95xxx: set a sane default timeout
sf: eeprom_m95xxx: fix up style
This patch allows a board configuration file to provide default bus
and chip-selects for SPI flash so that first argument to the 'sf' command
is optional.
On boards that use the mxc_spi driver and a GPIO for chip select, this allows
a much simpler command line:
U-Boot> sf probe
instead of
U-Boot> sf probe 0x5300
Tested-by: Jason Liu <jason.hui@linaro.org>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
add support for printing various clock frequency info found
in SOC such as ARM core frequency, DSP core frequency and DDR
frequency as part of bdinfo command.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Tom Rini <trini@ti.com>
Cc: Jason Hobbs <jason.hobbs@calxeda.com>
Acked-by: Jason Hobbs <jason.hobbs@calxeda.com>
show a menu on startup instead running the shell.
Cc: Mike Frysinger <vapier@gentoo.org>
add the possibility to show a statusline when printing a menu
add possibility to add a timeout when reading a line
into a buffer.
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
When performing large bulk reads from a CD or DVD using the U-Boot
usb_storage driver, it generates requests of up to 20 blocks at a time.
With a standard 512-byte block size, that is 10240 bytes and within the
limit of U-Boot's EHCI driver (maximum 5 pages at 4k per page).
Unfortunately CD-ROM media has a 2048-byte blocksize, resulting in a
maximum transfer size of 40960 bytes, which does not fit.
Since the EHCI specification is impossibly obtuse and far beyond my
comprehension, I chose to dynamically compute the limit based on the
blocksize.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
env_get_char_spec() function is duplicated across multiple environment
files.
Remove the duplication by providing a default implementation.
Add "weak" declaration, so the default implementation can be overridden.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Replace also __FUNCTION__ with standard __func__
* 'next' of ../next:
mkenvimage: Add version info switch (-V)
mkenvimage: Fix getopt() error handling
mkenvimage: Fix some typos
phy: add Micrel KS8721BL phy definition
net: introduce per device index
mvgbe: remove setting of ethaddr within the driver
x86: Add support for specifying an initrd with the zboot command
x86: Refactor the zboot innards so they can be reused with a vboot image
x86: Add infrastructure to extract an e820 table from the coreboot tables
x86: Add support for booting Linux using the 32 bit boot protocol
x86: Clean up the x86 zimage code in preparation to extend it
x86: Import code from coreboot's libpayload to parse the coreboot table
x86: Initial commit for running as a coreboot payload
CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c
CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c
CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c
CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c
CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c
CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c
CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c
CHECKPATCH: ./board/esd/hh405/fpgadata.c
CHECKPATCH: ./board/esd/pci405/fpgadata.c
CHECKPATCH: ./board/esd/tasreg/fpgadata.c
CHECKPATCH: ./board/esd/apc405/fpgadata.c
CHECKPATCH: ./board/esd/voh405/fpgadata.c
CHECKPATCH: ./board/esd/ash405/fpgadata.c
CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c
CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c
CHECKPATCH: ./board/esd/ar405/fpgadata.c
CHECKPATCH: ./board/esd/plu405/fpgadata.c
CHECKPATCH: ./board/esd/wuh405/fpgadata.c
CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c
CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c
CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c
CHECKPATCH: ./board/esd/canbt/fpgadata.c
CHECKPATCH: ./board/esd/du405/fpgadata.c
CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c
CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c
avr32:mmu.c: fix printf() length modifier
fat.c: fix printf() length modifier
cmd_sf.c: fix printf() length modifier
Make printf and vprintf safe from buffer overruns
vsprintf: Move function documentation into header file
Add safe vsnprintf and snprintf library functions
Move vsprintf functions into their own header
tools/mkenvimage.c
* 'master' of /home/wd/git/u-boot/custodians:
common/cmd_pxe.c: Fix GCC 4.6 build warnings
AVR32: fix timer_init() function
The switch to strict_strtoul() was not done correctly - this fixes
the compile error when CONFIG_CMD_TFTPPUT is active.
There appears to very little use of strict_strtoul() in commands, so
it might be easier to switch to simple_strtoul(). If not, we should
decide the best way to use strict_strtoul(). For now I have added a
friendly message which will of course increase code size.
Fix:
cmd_pxe.c: In function 'parse_pxefile_top':
cmd_pxe.c:941:5: warning: 'err' may be used uninitialized in this
function [-Wuninitialized]
cmd_pxe.c:921:6: note: 'err' was declared here
do_env_import() missed the final '\0' terminator when calculating the
size of an environment data block. This led to an erroneous 'bad CRC,
import failed' message for a checksum protected environment (-c.)
Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
size_t is not always 'unsigned int', use corret length modifer.
This patch fixes following warning:
---8<---
cmd_sf.c: In function 'spi_flash_update_block':
cmd_sf.c:130: warning: format '%#x' expects type 'unsigend int', but argument 4 has type 'size_t'
cmd_sf.c:135: warning: format '%x' expects type 'unsigned int', but argument 3 has type 'size_t'
--->8---
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
cc: Mike Frysinger <vapier@gentoo.org>
cc: Thomas Chou <thomas@wytron.com.tw>
utilize the added vscnprintf functions to avoid buffer overruns
The implementation is fairly dumb in that it doesn't detect
that the buffer is too small, but at least will not cause crashes.
Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
In 9792987721c7980453fe6447c3fa6593b44f8458 Stefan describes a usecase
where the previous behavior of leaving wMaxPacketSize be unaligned
caused fatal problems. The initial fix for this problem was incomplete
however as it showed another cases of non-aligned access that previously
worked implicitly. This switches to making sure that all access of
wMaxPacketSize are done via (get|put)_unaligned.
In order to maintain a level of readability to the code in some cases
we now use a variable for the value of wMaxPacketSize and in others, a
macro.
OpenRISC:
Tested-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Beagleboard xM, Pandaboard run-tested, s5p_goni build-tested.
We already flush the kernel image after we've loaded it to ensure
visiblity to the other cores. We need to do the same thing for the
ramdisk and device tree images. In AMP boot scenarios we might not be
HW cache coherent with the secondary core that we are loading and
setting the ramdisk and device tree up for. Thus we need to ensure
we've flushed the regions of memory utilized by ramdisk and device tree
so the loadding and any modifications (from decompression or fdt updates)
are made visible to the secondary cores.
* 'master' of git://git.denx.de/u-boot-usb:
USB: efikamx: Enable USB on EfikaMX and EfikaSB
USB: Add generic ULPI layer and a viewport
USB: EHCI: Allow EHCI post-powerup configuration in board files
USB: mx51evk: add end enable USB host support on port 1
USB: mx53loco: add end enable USB host support on port 1
USB: MX5: Add MX5 usb post-init callback
USB: MX5: Abstract out mx51 USB pixmux configuration
USB: MX5: add generic USB EHCI support for mx51 and mx53
USB: MX5: add helper functions to enable USB clocks
usb:gadget:s5p Enable the USB Gadget framework at GONI
usb:gadget:s5p USB Device Controller (UDC) implementation
ehci: speed up initialization
usb: add help for missing start subcommand
cosmetic: remove excess whitespace from usb command help
usb: align usb_endpoint_descriptor to 16-bit boundary
usbtty: init endpoints prior to startup events
pxa: convert pxa27x_udc to use read and write functions
pxa: activate the first usb host port on pxa27x by default
pxa: fix usb host register mismatch
ehci-fsl: correct size of ehci caplength
USB: Add usb_event_poll() to get keyboards working with EHCI
USB: gadaget: add Marvell controller support
USB: Fix complaints about strict aliasing in OHCI-HCD
USB: Drop dead code from usb_kbd.c
USB: Rework usb_kbd.c
USB: Add functionality to poll the USB keyboard via control EP
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
* Support dynamic allocation of devices
* Passing data via usb device privptr
* Reorder functions to avoid forward declarations
* Introduce generic polling mechanism to fix musb and ehci-hcd breakage
due to using "extern new;" to access keyboard driver data!
This allows the keyboard to avoid requests via Interrupt Endpoint altogether and
run all requests via Control Endpoint. This uses the Get_Report request.
Rebased on current code.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Using mmap to allocate memory from the OS for RAM simulation we can use
u-boot own malloc implementation.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
This patch adds support for console output before the console is inited.
The main purpose of this is to deal with a very early panic() which would
otherwise cause a silent hang.
A new board_pre_console_putc() function is added to the board API. If
provided by the board it will be called in the event of console output
before the console is ready. This function should turn on all UARTs and
spray the character out if it possibly can.
The feature is controlled by a new CONFIG_PRE_CONSOLE_PUTC option.
Acked-by: Graeme Russ <graeme.russ@gmail.com>
During the rebase of commit 00b7d6e "USB: Squash checkpatch warnings
in usb_kbd.c" I missed a brace, resulting in a number of build errors.
Fix these.
