Add a new command "sysboot" which parses syslinux menu files and boots
using kernel and initrd specified by menu files. The operation is similar
to "pxe boot" except local files on ext2 or fat filesystem are parsed.
For syslinux, the initrd can be set in the append string as
"initrd=<file>", so try to find it there if we haven't already set the
initrd.
If the file path starts with a '/', then don't pre-pend the bootfile path.
This fixes a problem with running 'pxe boot' multiple times where the
bootfile path gets pre-pended to itself each time.
Kernels can be specified using "linux" or "kernel" entry. The difference
is kernel is supposed to detect the type of file, but for u-boot both are
treated the same.
Use a menu string if present, otherwise use the kernel string.
Include files outside of a menu were not getting included and parsed.
Make the menu timeout apply only when prompt flag is set and after the
menu is displayed. This allows auto boot to work no matter whether prompt
is set or cleared. Use the default selection if the menu times out.
This also fixes the timeout value given to readline_into_buffer to be
seconds instead of 10th of seconds.
Old behavior:
if prompt
display menu and wait for choice
else
wait for timeout
if key pressed
else
exit command
New behavior:
if prompt
display menu
if key pressed
wait for choice
else
boot default entry on timeout
else
boot default entry
This driver is unused and obsolete.
Cc: unsik Kim <donari75@gmail.com>
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
Simplify the code slightly by using a for() loop since this is
basically what we're already doing -- incrementing "ngood" to
the value in "count".
Not only does the source code get simpler, but it also shrinks the
compiled object code too.
While we're here, tweak the summary message to avoid the plural
issue. It isn't that big of a deal, and it's currently wrong
anyways in the single (1 byte) case:
Total of 1 byte were the same
Grammar wise, that should be "was" rather than "were". The new
output people should be able to easily figure out:
Total of 1 byte(s) were the same
Total of 10 byte(s) were the same
Commit 418396e212b59bf907dbccad997ff50f7eb61b16 introduced a
bug that causes nand read and nand write to crash in strcmp
due to a null pointer.
Root cause is that strchr(cmd, '.') returns a null pointer when
the input string does not contain a '.'
The strcmp function does not check for null pointers, resulting
in a crash.
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Scott Wood <scott@tyr.buserror.net>
This patch supports drawing 32bpp decompressed bitmap image.
Signed-off-by: Donghwa Lee <dh09.lee@samsung.com>
Signed-off-by: Kyungmin.park <kyungmin.park@samsung.com>
Drop ifdef around bitmap_plot().
Move CONFIG_LCD_LOGO && !CONFIG_LCD_INFO_BELOW_LOGO ifdefs
to lcd_drawchars() func.
Use available macro for obtaining the size of bmp_logo_palette[]
Currently bmp_display() is static and can not be used directly
in the driver or board code. Export it for other users.
Code based on networking/zcip.c in busybox
commit 8531d76a15890c2c535908ce888b2e2aed35b172
Before this patch, bootp would not overwrite the value, but the
value was still clobbered in the env
cmd_nand.c: In function 'raw_access':
cmd_nand.c:397:9: warning: variable 'rwsize' set but not used
[-Wunused-but-set-variable]
Cc: Scott Wood <scottwood@freescale.com>
cmd_nvedit.c: In function '_do_env_set':
cmd_nvedit.c:207:9: warning: unused variable 'bd' [-Wunused-variable]
cmd_bootm.c: In function 'do_bootz':
cmd_bootm.c:1590:9: warning: variable 'iflag' set but not used
* 'master' of git://git.denx.de/u-boot-usb:
USB: S5P: Add ehci support
usb:udc:samsung Add functions for storing private gadget data in UDC driver
usb:gadget:composite: Support for composite at gadget.h
usb:gadget:composite USB composite gadget support
usb:udc:samsung:cleanup Replace DEBUG_* macros with debug_cond() calls
usb:udc: Remove duplicated USB definitions from include/linux/usb/ch9.h file
USB: Document the QH and qTD antics in EHCI-HCD
USB: Drop cache flush bloat in EHCI-HCD
USB: Drop ehci_alloc/ehci_free in ehci-hcd
USB: Align buffers at cacheline
usb: use noinline define
* 'master' of git://git.denx.de/u-boot-nand-flash:
NAND: Remove ONFI detection message to from bootup log
driver/mtd:IFC: Fix possible memory leak
driver/mtd: IFC NAND: Add support of ONFI NAND flash
mtd, nand: move some printfs to debug output.
nand_util: correct YAFFS image write function
powerpc/85xx: fix NAND boot linker scripts for -fpic
nand: extend .raw accesses to work on multiple pages
* 'master' of git://git.denx.de/u-boot-net:
net: move bootfile init into eth_initialize
net: punt bd->bi_ip_addr
net: cosmetic: netconsole.c checkpatch compliance
net: cosmetic: tftp.* checkpatch compliance
net: cosmetic: sntp.* checkpatch compliance
net: cosmetic: rarp.* checkpatch compliance
net: cosmetic: nfs.* checkpatch compliance
net: cosmetic: net.c checkpatch compliance
net: cosmetic: eth.c checkpatch compliance
net: cosmetic: bootp.* checkpatch compliance
net: cosmetic: net.h checkpatch compliance
net: Remove volatile from net API
This avoids cache-alignment warnings shown in console
when a usb command is entered.
Whenever X bytes of unaligned buffer is invalidated, arm core
invalidates X + Y bytes as per the cache line size and throws
these warnings.
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Building usb for Blackfin boards fails as we get linux/compiler.h
included which expands the "noinline" inside of the attribute and
we get attribute(attribute(noinline)).
Explicitly use the helper define to avoid this.
A use for this is to read, modify, erase, and write an entire block as a
single unit, as a replacement for the biterr command. This way gives
more flexibility in that you can also test multiple bit errors, errors
in the ECC, etc.
This field gets read in one place (by "bdinfo"), and we can replace
that with getenv("ipaddr"). After all, the bi_ip_addr field is kept
up-to-date implicitly with the value of the ipaddr env var.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
sata functions are called even if previous functions failed
because return value is not checked.
CC: Dirk Behme <dirk.behme@de.bosch.com>
CC: Fabio Estevam <fabio.estevam@freescale.com>
* 'agust@denx.de' of git://git.denx.de/u-boot-staging:
lin_gadget: use common linux/compat.h
linux/compat.h: rename from linux/mtd/compat.h
lin_gadget: use common mdelay
gunzip: rename z{alloc, free} to gz{alloc, free}
fs/fat: align disk buffers on cache line to enable DMA and cache
part_dos: align disk buffers on cache line to enable DMA and cache
This lets us use it in more places than just mtd code.
* 'master' of /home/wd/git/u-boot/custodians:
powerpc/85xx: don't touch MAS7 on e500v1 when relocating CCSR
powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during boot
cmd_bdinfo: display the address map size (32-bit vs. 36-bit)
PowerPC: correct the SATA for p1/p2 rdb-pc platform
powerpc/corenet_ds: Slave core in holdoff when boot from SRIO
powerpc/corenet_ds: Slave reads ENV from master when boot from SRIO
powerpc/corenet_ds: Slave uploads ucode when boot from SRIO
powerpc/corenet_ds: Slave module for boot from SRIO
powerpc/corenet_ds: Master module for boot from SRIO
powerpc/corenet_ds: Document for the boot from SRIO
powerpc/corenet_ds: Correct the compilation errors about ENV
powerpc/srio: Rewrite the struct ccsr_rio
powerpc/85xx:Fix lds for nand boot debug info
powerpc/p2041rdb: add env in NAND support
powerpc/p2041rdb: add NAND and NAND boot support
powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boards
powerpc/85xx:Avoid vector table compilation for nand_spl
powerpc/85xx:Fix IVORs addr after vector table relocation
powerpc/85xx:Avoid hardcoded vector address for IVORs
powerpc/p1023rds: Disable nor flash node and enable nand flash node
* 'master' of git://git.denx.de/u-boot-mpc85xx:
Putting "inline" on extern funcs makes no sense, so drop them.
cmd_nand.c: In function ‘arg_off_size’:
cmd_nand.c:216:5: warning: ‘maxsize’ may be used uninitialized in this function [-Wmaybe-uninitialized]
Some Freescale SOCs support 32-bit and 36-bit physical addressing, and
U-Boot must be built to enable one or the other. Add this information
to the bdinfo command.
Signed-off-by: Andy Fleming <afleming@freescale.com>
When boot from SRIO, slave's ENV can be stored in master's memory space,
then slave can fetch the ENV through SRIO interface.
NOTE: Because the slave can not erase, write master's NOR flash by SRIO
interface, so it can not modify the ENV parameters stored in
master's NOR flash using "saveenv" or other commands.
Master needs to:
1. Put the slave's ENV into it's own memory space.
2. Set an inbound SRIO window covered slave's ENV stored in master's
memory space.
Slave needs to:
1. Set a specific TLB entry in order to fetch ucode and ENV from master.
2. Set a LAW entry with the TargetID SRIO1 or SRIO2 for ucode and ENV.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
If one command fails, 'run' command should terminate and not execute
any remaining variables.
Signed-off-by: Timo Ketola <timo@exertus.fi>
Tested-by: Wolfgang Denk <wd@denx.de>
The standalone example does not have get_timer() defined, so we cannot
rely on it being available.
Move the timer function into boootstage.c to avoid this problem.
This corrects a build breakage for the standalone example on some boards.
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Tom Warren <TWarren@nvidia.com>
Cc: Graeme Russ <graeme.russ@gmail.com>
image.c: In function ‘boot_get_ramdisk’:
image.c:800:8: warning: unused variable ‘end’ [-Wunused-variable]
This patch allows loading RAW ramdisk via bootz command. The raw ramdisk is
loaded only in case it's size is specified:
bootz <kernel addr> <ramdisk addr>:<ramdisk size> <fdt addr>
For example:
bootz 0x42000000 0x43000000:0x12345 0x44000000
Cc: albert.u.boot@aribaud.net
Cc: afleming@gmail.com
Cc: Nicolas Pitre <nico@fluxnic.net>
Cc: Detlev Zundel <dzu@denx.de>
This command boots Linux zImage from where the zImage is loaded to. Passing
initrd and fdt is supported.
Tested on i.MX28 based DENX M28EVK
Tested on PXA270 based Voipac PXA270.
NOTE: This currently only supports ARM, but other architectures can be easily
added by defining bootz_setup().
Cc: afleming@gmail.com,
Cc: Simon Glass <sjg@chromium.org>,
The following must be defined:
CONFIG_ENV_IS_IN_FAT
Enable this saving environment to FAT.
FAT_ENV_INTERFACE
Interface the FAT resides on (e.g. mmc).
FAT_ENV_DEVICE
The interface device number (e.g. 0 for mmc0)
FAT_ENV_PART
The device part (e.g. 1 for mmc0:1)
FAT_ENV_FILE
The filename of the environment file.
Author: Maximilian Schwerin <mvs@tigris.de>
Removed dead DEBUG comment.
print in the "log info" command, if "log_version = 2" also the
value from "log->v2.con".
Acked-by: Detlev Zundel <dzu@denx.de>
If the logbuffer contains LOGBUFF_LEN chars, they never got
printed with the "log show" command, because chars get
printed with the following for loop:
for (i = 0; i < (size & LOGBUFF_MASK); i++) {
with size = LOGBUFF_LEN and LOGBUFF_MASK = (LOGBUFF_LEN-1)
for loop never executed ...
Fix this.
Fixed merge conflict.
