Fix MPC5200 FEC driver
* Patch by Brad Parker, 02 Aug 2003:
fix sc520_cdp problems
* Implement Boot Cycle Detection (Req. 2.3 of OSDL CGL Reqirements)
* Allow erase command to cross flash bank boundaries
Add support for LynuxWorks Kernel Downloadable Images (KDIs).
Both LynxOS and BlueCat linux KDIs are supported.
* Patch by Richard Woodruff, 25 Jul 2003:
use more reliable reset for OMAP/925T
* Patch by Nye Liu, 25 Jul 2003:
fix typo in mpc8xx.h
* Patch by Richard Woodruff, 24 Jul 2003:
Fixes for cmd_nand.c:
- Fixed null dereferece which could result in incorrect ECC values.
- Added support for devices with no Ready/Busy signal hooked up.
- Added OMAP1510 read/write protect handling.
- Fixed nand.h's ECCPOS. A conflict existed with POS5 and badblock
for non-JFFS2.
- Switched default ECC to be JFFS2.
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
add delay to get I2C working with "imm" command and s3c24x0_i2c.c
* Patch by Richard Woodruff, 17 July 03:
- Fixed bug in OMAP1510 baud rate divisor settings.
* Patch by Nye Liu, 16 July 2003:
MPC860FADS fixes:
- add MPC86xADS support (uses MPC86xADS.h)
- add 866P/T core support (also MPC859T/MPC859DSL/MPC852T)
o PLPRCR changes
o BRG changes (EXTAL/XTAL restricted to 10MHz)
o don't trust gclk() software measurement by default, depend on
CONFIG_8xx_GCLK_FREQ
- add DRAM SIMM not installed detection
- use more "correct" SDRAM initialization sequence
- allow different SDRAM sizes (8xxADS has 8M)
- default DER is 0
- remove unused MAMR defines from FADS860T.h (all done in fads.c)
- rename MAMR/MBMR defines to be more consistent. Should eventually
be merged into MxMR to better reflect the PowerQUICC datasheet.
* Patch by Yuli Barcohen, 16 Jul 2003:
support new Motorola PQ2FADS-ZU evaluation board which replaced
MPC8260ADS and MPC8266ADS
make logbuf compile without POST
- add I2C support for s3c2400 systems (trab board)
- (re-) add "ping" to command table
* Fix handling of "slow" POST routines
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
* Add support for TQM823M, TQM850M, TQM855M and TQM860M modules
* Add support for Am29LV160ML, Am29LV320ML, and Am29LV640ML
mirror bit flash on TQM8xxM modules
Improve documentation of I2C configuration in README
* Fix problems with previous log buffer "fixes"
* Fix minor help text issues
* "log append" did not append a newline
(autoscript, bmp, bsp, fat, mmc, nand, portio, ...)
sort when sorting command name list). Minor cleanup here and there.
- Allow to call sysmon function interactively
- PIC on LWMON board needs delay after power-on
- Add missing RSR definitions for MPC8xx
- Improve log buffer handling: guarantee clean reset after power-on
- Add support for EXBITGEN board
- Add support for SL8245 board
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
Update for MPC8260ADS board
* Patch by Murray Jensen, 23 Jun 2003:
- cleanup of GCC 3.x compiler warnings
add large memory support for MPC8266ADS board
* Patch by Richard Woodruff, 19 June 03:
- Enabled standard u-boot device abstraction for ARM
- Enabled console device for ARM
- Initilized bi_baudrate for ARM
* Patch by Bill Hargen, 23 Apr 2003:
fix byte order for 824x I2C addresses (write op)
- Hymod board database mods: add "who" field and new xilinx chip types
- provide new "init_cmd_timeout()" function so code external to
"common/main.c" can use the "reset_cmd_timeout()" function before
entering the main loop
- add DTT support for adm1021 (new file dtt/adm1021.c; config
slightly different. see include/configs/hymod.h for an example
(requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and
CFG_DTT_ADM1021 defined)
- add new "eeprom_probe()" function which has similar args and
behaves in a similar way to "eeprom_read()" etc.
- add 8260 FCC ethernet loopback code (new "eth_loopback_test()"
function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST)
- gdbtools copyright update
- ensure that set_msr() executes the "sync" and "isync" instructions
after the "mtmsr" instruction in cpu/mpc8260/interrupts.c
- 8260 I/O ports fix: Open Drain should be set last when configuring
- add SIU IRQ defines for 8260
- allow LDSCRIPT override and OBJCFLAGS initialization: change to
config.mk to allow board configurations to override the GNU
linker script, selected via the LDSCRIPT, make variable, and to
give an initial value to the OBJCFLAGS make variable
- 8260 i2c enhancement:
o correctly extends the timeout depending on the size of all
queued messages for both transmit and receive
o will not continue with receive if transmit times out
o ensures that the error callback is done for all queued tx
and rx messages
o correctly detects both tx and rx timeouts, only delivers one to
the callback, and does not overwrite an earlier error
o logic in i2c_probe now correct
- add "vprintf()" function so that "panic()" function can be
technically correct
- many Hymod board changes
- add support for Logotronic DL datalogger board
- cleanup serial line after kermit binary download
- add debugX macro (debug level support)
- update mach-types.h to latest arm.linux.org.uk master list.
Modifications for Atmel AT91RM9200DK ARM920T based development kit
- Add Atmel DataFlash support for reading and writing.
- Add possibility to boot a Linux from DataFlash with BOOTM command.
- Add Flash detection on Atmel AT91RM9200DK
(between Atmel AT49BV1614 and AT49BV1614A flashes)
- Replace old Ethernet PHY layer functions
- Change link address
* Patch by Frank Smith, 9 Jun 2003:
use CRIT_EXCEPTION for machine check on 4xx
* Patch by Detlev Zundel, 13 Jun 2003:
added implementation of the "carinfo" command in cmd_immap.c
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
* Add support for TQM862L at 100/50 MHz
* Patch by Pantelis Antoniou, 02 Jun 2003:
major reconstruction of networking code;
add "ping" support (outgoing only!)
- Added support for custom keyboards, initialized by defining a
board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD .
- Added support for the RBC823 board.
- cpu/mpc8xx/lcd.c now automatically calculates the
Horizontal Pixel Count field.
* Fix alignment problem in BOOTP (dhcp_leasetime option)
[pointed out by Nicolas Lacressonnière, 2 Jun 2003]
* Patch by Mark Rakes, 14 May 2003:
add support for Intel e1000 gig cards.
* Patch by Nye Liu, 3 Jun 2003:
fix critical typo in MAMR definition (include/mpc8xx.h)
* Fix requirement to align U-Boot image on 16 kB boundaries on PPC.
* Patch by Klaus Heydeck, 2 Jun 2003
Minor changes for KUP4K configuration
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
* Fix alignment problems with flash driver for TRAB board
* Patch by Donald White, 21 May 2003:
fix calculation of base address in pci_hose_config_device()
* Fix bug in command line parsing: "cmd1;cmd2" is supposed to always
execute "cmd2", even if "cmd1" fails. Note that this is different
to "run var1 var2" where the contents of "var2" will NOT be
executed when a command in "var1" fails.
Fix problem with only partially cleared .bss segment
* Patch by Rune Torgersen, 12 May 2003:
get PCI to work on a MPC8266ADS board; incorporate change to
cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
allow to pass boot bitmap addresses in environment variables;
allow for zero boot delay
* Patch by Christian Geißinger, 19 May 2002:
On TRAB: wait until the dummy byte has been completely sent
update for CrayL1 board
* Patch by Pantelis Antoniou, 21 Apr 2003:
add boot support for ARTOS (a proprietary OS)
* Patch by Steven Scholz, 11 Apr 2003:
Add support for RTC DS1338
* Patch by Rod Boyce, 24 Jan 2003:
Fix counting of extended partitions in diskboot command
allow the use of CFG_LOADS when CFG_NO_FLASH is set
(includes support for Intel 82365 and compatible PC Card controllers,
and Yenta-compatible PCI-to-CardBus controllers)
* Patch by Keith Outwater, 28 Apr 2003:
- Miscellaneous corrections and additions to GEN860T board specific code.
- Added GEN860_SC variant to GEN860T.
- Miscellaneous corrections to GEN860T documentation.
- Correct duplicate entry in U-Boot CREDITS file.
- Add GEN860T_SC entry in MAINTAINERS file.
- Update CREDITS file with GEN860T_SC info.
* Update Smiths Aerospace addresses in MAINTAINERS file
* Fix error handling in hush's version of "run" command
- Splashscreen support
- modem support
- sysmon support
- temperature dependend enabling of LCD
* Allow booting from old "PPCBoot" disk partitions
* Add support for TQM8255 Board / MPC8255 CPU
* MPC823 LCD driver: Fill color map backwards, to allow for steady
display when Linux takes over
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS (this time for real).
* Add support for "bmp info" and "bmp display" commands to load
bitmap images; this can be used (for example in a "preboot"
command) to display a splash screen very quickly after poweron.
* Add support for 133 MHz clock on INCA-IP board
Update for R360MPI board
* Add new meaning to "autostart" environment variable:
If set to "no", a standalone image passed to the
"bootm" command will be copied to the load address
(and eventually uncompressed), but NOT be started.
This can be used to load and uncompress arbitrary
data.
* Set max brightness for MN11236 displays on TRAB board
* Add support for Purple Board (MIPS64 5Kc)
* Add support for MIPS64 5Kc CPUs
Add IDMA example code (tested on 8260 only)
* Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS
* Patch by Denis Peter, 04 Apr 2003:
- update MIP405-4 board
* Patches by Denis Peter, 03 April 2003:
- fix PCI IRQs on MPL boards
- fix two more un-relocated pointer problems
* Fix behaviour of "run" command:
- print error message iv variable does not exist
- terminate processing of arguments in case of error
* Patches by Peter Figuli, 10 Mar 2003
- Add support for BTUART on PXA platform
- Add support for WEP EP250 (PXA) board
* Fix flash problems on INCA-IP; add tool to allow bruning images to
flash using a BDI2000
* Implement fix for I2C Edge Conditions problem for all boards that
use the bit-banging driver (common/soft_i2c.c)
* Add patches by Robert Schwebel, 31 Mar 2003:
- csb226 board: bring in sync with innokom/memsetup.S
- csb226 board: fix MDREFR handling
- misc doc fixes / extensions
- innokom board: cleanup, MDREFR fix in memsetup.S, config update
- add BOOT_PROGRESS to armlinux.c
- Add port to MPC555/556 microcontrollers
- Add support for cmi customer board with
Intel 28F128J3A, 28F320J3A or 28F640J3A flash.
* Patch by Rick Bronson, 28 Mar 2003:
- fix common/cmd_nand.c
- add threads / scheduler example code
- add ctrl-c support for kermit download
- align bdinfo output on ARM
* Add CPU ID, version, and clock speed for INCA-IP
