Properly pass break code back from readline.
Patch by Roger Blofeld, 31 Jul 2006
Patch by Stefan Roese, 07 Aug 2006
problems with some USB storage devices. Some code readability improvements.
Patch by Stefan Roese, 27 Jul 2006
Patch by Ladislav Michl, 14 Sep 2005
Patch by JinHua Luo, 01 Sep 2005
Problem pointed out by Andrew Dyer, 13 Jun 2005
- Support for TQM5200S (short version without graphic controller)
- Support for modules with 'N' type S29GL128N Spansion flashes
(requires changes to flash layout)
- Support for MPC5200B cpu (mostly support for second SDRAM bank)
Notes:
- Board-dependend code for RPXLITE and RPXCLASSIC-based boards
placed to the drivers/rpx_pmcia.c file to avoid duplication.
Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c).
- drivers/i82365.c has been split into two parts located at
board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are
the only boards using CONFIG_82365).
- Changes were tested for clean build and *very* *few* boards.
Patch by Thomas Lange, Aug 11 2005
Patch by Martin Krause, 8 Jun 2006
This patch supports two serial consoles on boards with
a MPC5xxx CPU. The console can be switched at runtime
by setting stdin, stdout and stderr to the desired serial
interface (serial0 or serial1). The PSCs to be used as
console port are definded by CONFIG_PSC_CONSOLE
and CONFIG_PSC_CONSOLE2.
See README.serial_multi for details.
- Add IXP4xx NPE ethernet MAC support
- Add support for Intel IXDPG425 board
- Add support for Prodrive PDNB3 board
- Add IRQ support
Patch by Stefan Roese, 23 May 2006
[This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still
sufferes from licensing issues. Blame Intel.]
(needed because of differences in the PCMCIA hardware).
Patch by Stefan Roese, 10 May 2006
Patch by Jon Loeliger, 01. May 2006
- fix some compiler/parser error, if using m68k tool chain
- optical fix for protect on/off all messages, if using more
then one bank
Patch by Jens Scharsig, 28 July 2005
Necessary defines and data structures were copied to DoC specific files
so that legacy NAND code could be entirely removed from u-boot tree
in the near future.
Patch by Stefano Babic, 29 Mar 2006
* Memory Map Update for Delta board: U-Boot is at 0x80000000-0x84000000
Merge with /home/mk/8-benq/u-boot
- Add Intel legacy lock/unlock support to common CFI driver
On some Intel flash's (e.g. Intel J3) legacy unlocking is
supported, meaning that unlocking of one sector will unlock
all sectors of this bank. Using this feature, unlocking
of all sectors upon startup (via env var "unlock=yes") will
get much faster.
- Fixed problem with multiple reads of envronment variable
"unlock" as pointed out by Reinhard Arlt & Anders Larsen.
- Removed unwanted linefeeds from "protect" command when
CFG_FLASH_PROTECTION is enabled.
- Changed p3p400 board to use CFG_FLASH_PROTECTION
Patch by Stefan Roese, 01 Apr 2006
* Changes/fixes for drivers/cfi_flash.c:
- Correctly handle the cases where CFG_HZ != 1000 (several
XScale-based boards)
- Fix the timeout calculation of buffered writes (off by a
factor of 1000)
Patch by Anders Larsen, 31 Mar 2006
CFG_BOOTM_LEN to adjust this setting.
As mentioned by Robin Getz on 2005-05-24 the size of uncompressed
uImages was restricted to 4MBytes. This default size is now
increased to 8Mbytes and can be overrided by setting CFG_BOOTM_LEN
in the board config file.
Patch by Stefan Roese, 13 Mar 2006
incorrectly generating start/stop conditions on the bus.
Patch by Andrew Dyer, 26 Jul 2005
Patch by Sam Song, 19 Jun 2005
Patch by Andrew Dyer, 13 Jun 2005
- add support for Analog Devices Blackfin BF533 CPU
- add support for the ADI BF533 Stamp uClinux board
- add support for the ADI BF533 EZKit board
Patches by Richard Klingler, June 11th 2005:
