path: root/common
2011-10-27arm, logbuffer: make it compilecleanHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-10-26net: tftpput: add tftpput commandSimon Glass
This adds the tftpput command to U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26tftpput: add save_addr and save_size global variablesSimon Glass
We need something akin to load_addr to handle saving data. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Rename TFTP to TFTPGETSimon Glass
This is a better name for this protocol. Also remove the typedef to keep checkpatch happy, and move zeroing of NetBootFileXferSize a little earlier since TFTPPUT will need to change this. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26Add setenv_ulong() and setenv_addr()Simon Glass
It seems we put numbers and addresses into environment variables a lot. We should have some functions to do this. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26Move simple_itoa to vsprintfSimon Glass
This function is generally useful and shouldn't hide away in hush. It has been moved as is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-23mkimage: adding support for Davinci AIS imageStefano Babic
Some Davinci processors supports the Application Image Script (AIS) boot process. The patch adds the generation of the AIS image inside the mkimage tool to make possible to generate a bootable U-boot without external tools (TI Davinci AIS Generator). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-23Add getenv_ulong() to read an integer from an environment variableSimon Glass
This is not an uncommon operation in U-Boot, so let's put it in a common function. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23common: fix missing function pointer relocation in fixup_cmdtable()Daniel Schwierzeck
In commit fa28bd2eef588ec2048ccafedb2b384d5a355858 patch v1 was applied instead of v2. This is an incremental patch to update that commit to version 2. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-10-22hwmon: Provide dtt_init()Dirk Eibach
Our boards rely on dtt for initialization of fan hardware. dtt_init() was implemented to be called form board specific code. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22checkpatch whitespace cleanupsStephen Warren
This avoids the following checkpatch warning in later patches: ERROR: "(foo*)" should be "(foo *)" ERROR: space required before the open brace '{' ERROR: space prohibited before that close parenthesis ')' ERROR: spaces required around that '||' (ctx:WxV) WARNING: space prohibited between function name and open parenthesis '(' WARNING: line over 80 characters This fixes all the white-space warnings/errors in my subsequent patch, and within this current patch. A number of other checkpatch warnings and errors are still present in this patch itself, but are beyond simple whitespace fixes, so are not solved by this patch. v2: New patch Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-10-22nds32: common bdinfo, bootm, image supportMacpaul Lin
Add support of NDS32 to common commands bdinfo, bootm, and image format. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-22cmd_bdinfo: replace print_str() with print_mhz()Timur Tabi
The print_str() helper function for cmd_bdinfo can print any string, but it is only used to print MHz values. Replace it with print_mhz() that takes a number and converts it to a string internally. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-10-21removed static from images in cmd_bootm.cSimon Schwarz
This removes static modifier from images variable in cmd_bootm.c. Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
2011-10-21Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: mpc85xx: Add inline GPIO acessor functions powerpc/85xx: wait for alignment before resetting SERDES RX lanes (SERDES9) powerpc/85xx: Fix P2020DS booting powerpc/85xx: Update USB device tree status based on pin settings fdt: Add new fdt_set_node_status & fdt_set_status_by_alias helpers powerpc/85xx: Add support for RMan LIODN initialization powerpc/85xx: Update device tree handling for SRIO powerpc/85xx: Update setting of SRIO LIODNs fm: Don't allow disabling of FM1-DTSEC1 fm-eth: Don't mark the MAC we use for MDIO as disabled in device tree
2011-10-20cosmetic: Fixup fixup_silent_linux() for checkpatchDoug Anderson
Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Anton Staaf <robotboy@chromium.org>
2011-10-18fdt: Add new fdt_set_node_status & fdt_set_status_by_alias helpersShengzhou Liu
Add common function fdt_set_node_status() to assist in various locations that we set a nodes status. This function utilizes the status values that are part of the EPAPR spec (on power.org). fdt_set_status_by_alias() is based on fdt_set_node_status() but uses an alias string to identify the node to update. We also add some shortcut functions to help the common cases of setting "okay" and "disabled": fdt_status_okay() fdt_status_disabled() fdt_status_okay_by_alias() fdt_status_disabled_by_alias() Finally, we fixup the corenet_ds ethernet code which previously had a function by the same name that can be replaced with the new helpers. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2011-10-17sandbox: Use uintptr_t for 32/64-bit compatibilitySimon Glass
This fixes a problems when building on some 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Disable built-in mallocSimon Glass
We prefer to U-Boot's malloc but for now it is easier to use the C library's version. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Add bootm supportSimon Glass
This adds sandbox architecture support to bootm, although it is probably not useful to load sandbox code into the address space and execute it. This change at least make the file build correctly on 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-17sandbox: Add board info for architectureSimon Glass
This is required for the bdinfo command to work. Signed-off-by: Simon Glass <sjg@chromium.org> Fix syntax error. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-17Fix use of int as pointer in image.cSimon Glass
It is better to use %p in this case. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17Add pxe commandJason Hobbs
Add pxe command, which is intended to mimic PXELINUX functionality. 'pxe get' uses tftp to retrieve a file based on UUID, MAC address or IP address. 'pxe boot' interprets the contents of PXELINUX config like file to boot using a specific initrd, kernel and kernel command line. This patch also adds a README.pxe file - see it for more details on the pxe command. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-17Replace space and tab checks with isblankJason Hobbs
These are various places I found that checked for conditions equivalent to isblank. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-17cosmetic: remove unneeded curly bracesJason Hobbs
This prevents a checkpatch warning in the patch to use isblank Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-17common: add run_command2 for running simple or hush commandsJason Hobbs
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17common, menu: use abortboot for menu timeoutJason Hobbs
2011-10-17Add generic, reusable menu codeJason Hobbs
This will be used first by the pxe code, but is intended to be generic and reusable for other jobs in U-boot. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
2011-10-15common: fix missing function pointer relocation in fixup_cmdtable()Daniel Schwierzeck
The command auto-completion does not work on architectures relying on CONFIG_NEEDS_MANUAL_RELOC like MIPS. Cause is the missing function pointer fixup for cmd_tbl_t::complete function in fixup_cmdtable(). This patch adds the missing pointer fixup in case of CONFIG_AUTO_COMPLETE is defined. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-10-15fdt: update fdt_alloc_phandle to use fdt_get_phandleTimur Tabi
The device tree compiler, dtc, can use "phandle" and/or "linux,phandle" properties to specify the phandle for any node. By default, it uses both, but "linux,phandle" is deprecated. One day, we'd like to stop using "linux,phandle", but U-boot needs to support both properties equally first. fdt_alloc_phandle() generates a unique phandle, but it was only checking the "linux,phandle" properties. Instead, we use fdt_get_phandle(), which checks both properties automatically. This ensures that we support dtbs that only use "phandle". The side-effect is that fdt_alloc_phandle() now takes twice as long, since it has to check for two properties instead of one in each node that it searches. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-10-15fdt: check for fdt errors in fdt_create_phandleTimur Tabi
fdt_create_phandle() was ignoring errors from fdt_set_phandle(). If an error occurs, print an error message and return 0, which is an invalid phandle. We also need to change the return type for fdt_create_phandle() to indicate that it cannot return an error code. Signed-off-by: Timur Tabi <timur@freescale.com>
2011-10-09common/usb.c: fix warning: variable ... set but not usedWolfgang Denk
Fix: usb.c: In function 'usb_parse_config': usb.c:331:17: warning: variable 'ch' set but not used [-Wunused-but-set-variable] usb.c: In function 'usb_hub_port_connect_change': usb.c:1123:29: warning: variable 'portchange' set but not used [-Wunused-but-set-variable] usb.c: In function 'usb_hub_configure': usb.c:1183:25: warning: variable 'hubsts' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Acked-by: Remy Bohmer <linux@bohmer.net>
2011-10-09common/cmd_usb.c: fix warning: variable ... set but not usedWolfgang Denk
Fix: cmd_usb.c: In function 'usb_show_tree_graph': cmd_usb.c:284:29: warning: variable 'port' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Acked-by: Remy Bohmer <linux@bohmer.net>
2011-10-09CFI: fix warning: variable ... set but not usedWolfgang Denk
Fix: cfi_mtd.c: In function 'cfi_mtd_init': cfi_mtd.c:226:19: warning: variable 'mtd_list' set but not used [-Wunused-but-set-variable] cfi_mtd.c: In function 'cfi_mtd_init': cfi_mtd.c:225:6: warning: unused variable 'devices_found' cfi_mtd.c: In function 'cfi_mtd_init': cfi_mtd.c:226:19: warning: variable 'mtd_list' set but not used [-Wunused-but-set-variable] [-Wunused-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2011-10-09cmd_time: add time commandChe-liang Chiou
The 'time' command runs and reports execution time of commands. Sample usage: -------------------- u-boot# time crc 0x1000 1000 CRC32 for 00001000 ... 00001fff ==> ae94dc4b time: 0.004 seconds, 4 ticks -------------------- Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-09common/image.c: remove duplicated IH_TYPE entries.Wolfgang Denk
Also rearrange IH_TYPE table slightly. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-09serial: uartlite: Support for SERIAL_MULTIMichal Simek
Add support for SERIAL MULTI for uartlite. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-10-05cmd_sf: Fix compiler warningKumar Gala
cmd_sf.c: In function 'do_spi_flash': cmd_sf.c:164:9: warning: 'skipped' may be used uninitialized in this function Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Simon Glass <sjg@chromium.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
* 'master' of git://git.denx.de/u-boot-nand-flash: PPC: Fix socrates NAND problem PPC: Fix fsl_upm.c by renaming nand handling functions NAND: Make page, erase, oob size available via cmd_nand mtd: eLBC NAND: remove elbc_fcm_ctrl->oob_poi NAND: Add -y option to nand scrub command NAND: Add nand read.raw and write.raw commands NAND: Really ignore bad blocks when scrubbing spl, nand: add 4bit HW ecc oob first nand_read_page function mxc_nand: fix a problem writing more than 32MB mxc_nand: fixed some typos (cosmetic) nand: increase chip_delay in mv kirkwood nand driver
2011-10-04Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/p3060: Add SoC related support for P3060 platform powerpc/85xx: Add support for setting up RAID engine liodns on P5020 powerpc/85xx: Refactor some defines out of corenet_ds.h fm-eth: Add ability for board code to disable a port powerpc/mpc8548: Add workaround for erratum NMG_LBC103 powerpc/mpc8548: Add workaround for erratum NMG_DDR120 powerpc/mpc85xxcds: Fix PCI speed powerpc/mpc8548cds: Fix booting message powerpc/p4080: Add support for secure boot flow powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASH powerpc/85xx: Add PBL & SECUREBOOT support on P3041/P5020DS boards powerpc/p2041rdb: remove watch dog related codes powerpc/p2041rdb: updated description of cpld command powerpc/p2041rdb: add more ddr frequencies support powerpc/p2041rdb: set sysclk according to status of physical switch SW1 powerpc/p2041rdb: update cpld reset command according to CPLD 2.0 powerpc/mpc8349emds: Migrate from spd_sdram to unified DDR driver powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driver powerpc/mpc8xxx: Add DDR2 to unified DDR driver powerpc/mpc8xxx: Fix picos_to_mclk() and get_memory_clk_period_ps() powerpc/mpc8xxx: Add SPD EEPROM address for single controller 2 slots powerpc/mpc8xxx: Fix DDR code for empty first DIMM slot and enable DQS_en powerpc/85xx: Refactor P2041RDB to use common p_corenet files powerpc/85xx: refactor common P-Series CoreNet files for FSL boards powerpc/85xx: Enable CMD_REGINFO on corenet boards powerpc/85xx: p2041rdb - Remove unused 'execute' perm in TLB entries powerpc/85xx: Fix USB protocol definitions for P1020RDB powerpc/corenet_ds: Use separated speed tables for UDIMM and RDIMM powerpc/mpc8xxx: Move DDR RCW overriding to common code powerpc/mpc8xxx: Extend CWL table powerpc/85xx: Cleanup how SVR_MAJ() is defined on MPC8536 powerpc/85xx: Cleanup extern in corenet_ds board code powerpc/p2041rdb: Add ethernet support on P2041RDB board powerpc/85xx: Add networking support to P1023RDS powerpc/hydra: Add ethernet support on P5020/P3041 DS boards powerpc/85xx: Add FMan ethernet support to P4080DS powerpc/85xx: Add support for FMan ethernet in Independent mode powerpc/mpc8548cds: Cleanup mpc8548cds.c powerpc/mp: add support for discontiguous cores powerpc/85xx: corenet_ds - Remove unused 'execute' perm in TLB entries fdt: Add new fdt_create_phandle helper fdt: Rename fdt_create_phandle to fdt_set_phandle powerpc/85xx: Fix compile warnings/errors if CONFIG_SYS_DPAA_FMAN isn't set fsl_ifc: Add the workaround for erratum IFC A-003399(enabled on P1010) powerpc/P1010: Add workaround for erratum P1010-A003549 (related to IFC) fsl_ifc: Add the workaround for erratum IFC-A002769 (enable on P1010) powerpc/85xx: Expanding the window of CCSRBAR in AS=1 from 4k to 1M powerpc/85xx: Add NAND/NAND_SPL support to P1010RDB nand: Freescale Integrated Flash Controller NAND support powerpc/85xx: Add basic support for P1010RDB powerpc/85xx: Add support for new P102x/P2020 RDB style boards powerpc/85xx: relocate CCSR before creating the initial RAM area powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macros powerpc/85xx: Enable internal USB UTMI PHY on p204x/p3041/p50x0 powerpc/85xx: Add ULPI and UTMI USB Phy support for P1010/P1014
2011-10-04Revert "GCC4.6: Convert various empty macros to inline functions"Wolfgang Denk
This reverts commit 60ce53cf9f408d9ad721f8e7a87d6a564e6d5bac. The commit causes build breakage for a number of boards. This results from the fact that now the arguments of debug() actually get referenced (even if there is hope that the compiler will optimize away the debug() call). The obvious fix to that probem (change the code to always declare the referenced variables and data structures) increases the code size, and was this rejected. So it was decided to revert this commit until a better solution is found.
2011-10-03NAND: Make page, erase, oob size available via cmd_nandMarek Vasut
The "nand info" and "nand device" now set shell/environment variables: nand_writesize ... nand page size nand_oobsize ..... nand oob area size nand_erasesize ... nand erase block size Also, the "nand info" command now displays this info. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: removed unnecessary memsets] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Add -y option to nand scrub commandMarek Vasut
This allows the scrub command to scrub without asking the user if he really wants to scrub the area. Useful in scripts. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-03NAND: Add nand read.raw and write.raw commandsMarek Vasut
These commands should work around various "hardware" ECC and BCH methods. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> [scottwood@freescale.com: s/write the page/access the page/] Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-10-01GCC4.6: Squash warning in cmd_ubi.c:Marek Vasut
cmd_ubi.c: In function ‘ubi_volume_read’: cmd_ubi.c:319:9: warning: variable ‘count_save’ set but not used [-Wunused-but-set-variable] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-01GCC4,6: Squash warning in cmd_nand.cMarek Vasut
cmd_nand.c: In function ‘do_nand’: cmd_nand.c:490:7: warning: variable ‘chip’ set but not used [-Wunused-but-set-variable] cmd_nand.c:489:7: warning: variable ‘part’ set but not used [-Wunused-but-set-variable] Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Scott Wood <scottwood@freescale.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
