path: root/common
2014-12-08Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2014-12-08Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2014-12-08fdt: Allow non-FDT kernels to boot when CONFIG_OF_LIBFDT is definedSuriyan Ramasami
The boot commands - bootz/bootm mandate a third argument which is the address to the FDT blob. In cases where this argument is not specified, boot fails with a message indicating a missing FDT. This causes non-FDT kernels to fail to boot. This patch allows both FDT and non-FDT kernels to boot by making the third parameter to the bootm/bootz optional. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update again for covering appended DTB case after last revert in this area] Signed-off-by: Tom Rini <trini@ti.com>
2014-12-08Replace <compiler.h> with <linux/compiler.h>Masahiro Yamada
Including <linux/compiler.h> is enough for general use. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08powerpc: mpc8xx: remove hermes board supportMasahiro Yamada
This board sprinkles #ifdef(CONFIG_HERMES) over various global files such as include/common.h, common/board_r.c, common/cmd_bdinfo.c. Let's zap such an ill-behaved board. It has not been converted to generic board yet and mpc8xx is old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2014-12-08cmd_fuse: return CMD_RET_FAILURE on errorHector Palacios
Fuse drivers, like the mxs_ocotp.c, may return negative error codes but the commands are only allowed to return CMD_RET_* enum values to the shell, otherwise the following error appears: "exit not allowed from main input shell." Signed-off-by: Hector Palacios <hector.palacios@digi.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
2014-12-08ARM: rpi: rename rpi_b to rpiStephen Warren
The U-Boot port runs on a variety of RPi models, not just the B. So, rename the port to something slightly more generic. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-08spl: if MMCSD_MODE_RAW fails, try MMCSD_MODE_FS, if availableGuillaume GARDET
In SPL MMC, boot modes are exclusive. So, if MMCSD_MODE_RAW fails, the board hangs. This patch allows to try MMCSD_MODE_FS then, if available. It has been tested on a pandaboard (rev. A3). Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-12-08Fix console functions for U-Boot APISimon Glass
Commit 709ea54 made a subtle change to the way the U-Boot API jump table is set up. So at present putc(), getc(), tstc() and puts() do not work correctly from functions that use the U-Boot API. Previously these were set to the stdio functions, but these now take a parameter specifying which stdio device to use. Instead, we should change them to use the global functions which do not have a parameter. This is a slight change in behaviour. The functions will now output to all selected stdio devices - for example putc() will output a character to all devices selected by stdout. However in most cases there is only one, and it isn't necessarily incorrect behaviour anyway. The API version is not changed since it is compatible with what was there before. Reported-by: Martin Dorwig <dorwig@tektronik.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-08spl: MMC U-Boot image load from raw partitionPaul Kocialkowski
Raw images of U-Boot can be stored inside MMC partitions, so it makes sense to read the partition table, looking for a partition number instead of using a fixed sector address. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Only add mmc_load_image_raw_partition() when CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION to avoid warning, add missing conversion in spl_mmc_load_image()] Signed-off-by: Tom Rini <trini@ti.com>
2014-12-08flash: do not fail even if flash_size is zeroMasahiro Yamada
CONFIG_SYS_MAX_FLASH_BANKS_DETECT allows to determine the number of flash banks at run-time, that is, there is a possibility that no flash bank is found. Even in such cases, it makes sense to continue the boot process without any flash device. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de>
2014-12-05common: spl: Add interactive DDR debugger support for SPL imageAlison Wang
To support interactive DDR debugger, cli_simple.o, cli.o, cli_readline.o, command.o, s_record.o, xyzModem.o and cmd_disk.o are all needed for drivers/ddr/fsl/interactive.c. In current common/Makefile, the above .o files are only produced when CONFIG_SPL_BUILD is disabled. For LS102xA, interactive DDR debugger is needed in SD/NAND boot too, and I enabled CONFIG_FSL_DDR_INTERACTIVE. But according to the current common/Makfile, all the above .o files are not produced in SPL part because CONFIG_SPL_BUILD is enabled in SPL part, the following error will be shown, drivers/ddr/fsl/built-in.o: In function `fsl_ddr_interactive': /home/wangh/layerscape/u-boot/drivers/ddr/fsl/interactive.c:1871: undefined reference to `cli_readline_into_buffer' /home/wangh/layerscape/u-boot/drivers/ddr/fsl/interactive.c:1873: undefined reference to `cli_simple_parse_line' make[1]: *** [spl/u-boot-spl] Error 1 make: *** [spl/u-boot-spl] Error 2 So this patch fixed this issue and the above .o files will be produced no matter CONFIG_SPL_BUILD is enabled or disabled. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-04MMC SD fs boot partition config coding style and proper descriptionPaul Kocialkowski
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR. In addition, it is not related to raw mode booting but to fs mode instead. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04Merge branch 'sandbox' of git://git.denx.de/u-boot-x86Tom Rini
2014-12-03Revert "image-fdt: boot_get_fdt() return value when no DTB exists"Tom Rini
It has been found that this change breaks the case of an appended device tree file, so for the problem in question some other solution must be found. This reverts commit c6150aaf2f2745141a7c2ceded58d7efbfeace7d. Reported-by: Bill Pringlemeir <bpringlemeir@nbsps.com> Reported-by: Pantelis Antoniou <panto@antoniou-consulting.com> Confirmed-by: Bill Pringlemeir <bpringlemeir@nbsps.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-12-01Merge git://git.denx.de/u-boot-fdtTom Rini
2014-12-01Merge git://git.denx.de/u-boot-x86Tom Rini
2014-12-01fdt: Fix regression in fdt_pack_reg()Hans de Goede
After commit 933cdbb479: "fdt: Try to use fdt_address_cells()/fdt_size_cells()" I noticed that allwinner boards would no longer boot. Switching to fdt_address_cells / fdt_size_cells changes the result from bytes to 32 bit words, so when we increment pointers into the blob, we must do so by 32 bit words now. This commit makes allwinner boards boot again. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Vince Hsu <vinceh@nvidia.com>
2014-11-26sandbox: Fix warnings due to 64-bit printf() stringsSimon Glass
Now that we have inttypes.h, use it in a few more places to avoid compiler warnings on sandbox when building on 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-26spl: Fix SPL EXT supportGuillaume GARDET
Commit 9f12cd0e062614e19734b2ab37842d387457c5e5 has broken SPL EXT support. This patch update error code check to get SPL EXT support working again. Tested on a Pandaboard (rev. A3). Reviewed-by: Suriyan Ramasami <suriyan.r@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-11-26Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2014-11-26Merge git://git.denx.de/u-boot-fdtTom Rini
2014-11-25x86: Remove unnecessary call to initr_enable_interrupts()Bin Meng
Actually initr_enable_interrupts() was never called in an x86 build due to it was wrapped by CONFIG_x86 (typo of X86). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-11-25x86: Remove cpu_init_r() for x86Bin Meng
Since cpu_init_interrupts() was moved out of cpu_init_r(), it is useless to keep cpu_init_r() for x86, thus remove it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-11-25x86: Remove board_early_init_r()Simon Glass
This function is not needed. Remove it to improve the generic init sequence slightly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-25common/lcd: Make lcd_dt_simplefb_configure_node use fdt_setup_simplefb_nodeHans de Goede
Change lcd_dt_simplefb_configure_node into a wrapper around the new generic fdt_setup_simplefb_node helper function. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-25fdt_support: Add a fdt_setup_simplefb_node helper functionHans de Goede
Add a generic helper to fill and enable simplefb nodes. The first user of this will be the sunxi display code. lcd_dt_simplefb_configure_node is also a good candidate to be converted to use this, but that requires someone to run some tests first, as lcd_dt_simplefb_configure_node does not honor #address-cells and #size-cells, but simply assumes 1 and 1 for both. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-24Revert "common/board_f: add setup of initial stack frame for MIPS"Tom Rini
Daniel discovered a better solution to the problem this was solving, so don't do what this patch was doing anymore. This reverts commit 666ba8444e81c3785a427ae6922e2feededab9a3. Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24Revert "hush: fix segfault on syntax error"Rabin Vincent
128059b92 ("hush: fix segfault on syntax error") attempted to fix a segfault on syntax errors, but it broke Ctrl-C handling, and the assumption that it made, that rcode could not be -1, is incorrect. Revert this change. Reported-by: Stephen Warren <swarren@wwwdotorg.org> Reported-by: Przemyslaw Marczak <p.marczak@samsung.com> Signed-off-by: Rabin Vincent <rabin@rab.in>
2014-11-24Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24Merge git://git.denx.de/u-boot-x86Tom Rini
Conflicts: arch/x86/cpu/Makefile Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24cmd_sata: implement sata stop commandNikita Kiryanov
Implement sata stop command. This introduces the __sata_stop() weak function, which mirrors the weak __sata_initialize() function, giving users the option of undoing the custom steps performed in overrides of sata_initialize(). Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com>
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23sandbox: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal sandbox functions to use loff_t for file offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23ext4: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal EXT4 functions to use loff_t for offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update common/spl/spl_ext.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23fat: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal FAT functions to use loff_t for offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Fix fs/fat/fat.c for min3 updates] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23sandbox: Use md5sum and fatwrite to enable testing of fs commandsSuriyan Ramasami
Enable md5sum to obtain the MD5 of the read and written files to check their contents for validity. Use map_sysmem() to map buffer in a sandbox environment. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23common/board_f: fix gcc warning on MIPS64Daniel Schwierzeck
This fixes following warning when compiled with MIPS64 common/board_f.c: In function 'display_text_info': common/board_f.c:150:2: warning: format '%X' expects argument i of type 'unsigned int', but argument 2 has type 'long unsigned int' [-Wformat=] debug("U-Boot code: %08X -> %08lX BSS: -> %08lX\n", Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23common/board_f: add setup of initial stack frame for MIPSDaniel Schwierzeck
The MIPS specific setup of the initial stack frame was not ported to generic board_f. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-11-23commands: add more command entries in KconfigMasahiro Yamada
This commit adds some of command entries (CONFIG_CMD_*) to cover include/config_cmd_default.h and a little extra. Because U-Boot supports lots of commands, they should be categorized according to their usage. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23hush: add CONFIG_HUSH_PARSER to KconfigMasahiro Yamada
The README file states that the macros beginning with "CONFIG_SYS_" depend on the hardware etc. and should not be meddled with if you do not what you're doing. We have already screwed up with this policy; we have given the prefix "CONFIG_SYS_" to many user-selectable configurations. Here, "CONFIG_SYS_HUSH_PARSER" is one of them. Users can enable it if they want to use a more powerful command line parser, or disable it if they only need a simple one. This commit attempts to rename CONFIG_SYS_HUSH_PARSER to CONFIG_HUSH_PARSER and move it to Kconfig. Every board maintainer is expected to enable CONFIG_HUSH_PARSER (= add "CONFIG_HUSH_PARSER=y" to his defconfig file) and remove "#define CONFIG_SYS_HUSH_PARSER" from his header file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23pci: Honour pci_skip_dev()Thierry Reding
When enumerating devices, honour the pci_skip_dev() function. This can be used by PCI controller drivers to restrict which devices will be probed. This is required by the NVIDIA Tegra PCIe controller driver, which will fail with a data abort exception if an access is attempted to a device number larger than 0 outside of bus 0. pci_skip_dev() is therefore implemented to prevent any such accesses. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23pci: Abort early if bus does not existThierry Reding
When listing the devices on a PCI bus, the current code will blindly try to access all devices. Internally this causes pci_bus_to_hose() to be repeatedly called and output an error message every time. Prevent this by calling pci_bus_to_hose() once and abort early if no bus was found. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-23fs: make it possible to read the filesystem UUIDChristian Gmeiner
Some filesystems have a UUID stored in its superblock. To allow using root=UUID=... for the kernel command line we need a way to read-out the filesystem UUID. changes rfc -> v1: - make the environment variable an option parameter. If not given, the UUID is printed out. If given, it is stored in the env variable. - corrected typos - return error codes changes v1 -> v2: - fix return code of do_fs_uuid(..) - document do_fs_uuid(..) - implement fs_uuid_unsuported(..) be more consistent with the way other optional functionality works changes v2 -> v3: - change ext4fs_uuid(..) to make use of #if .. #else .. #endif construct to get rid of unreachable code Hit any key to stop autoboot: 0 => fsuuid fsuuid - Look up a filesystem UUID Usage: fsuuid <interface> <dev>:<part> - print filesystem UUID fsuuid <interface> <dev>:<part> <varname> - set environment variable to filesystem UUID => fsuuid mmc 0:1 d9f9fc05-45ae-4a36-a616-fccce0e4f887 => fsuuid mmc 0:2 eb3db83c-7b28-499f-95ce-9e0bb21cda81 => fsuuid mmc 0:1 uuid1 => fsuuid mmc 0:2 uuid2 => printenv uuid1 uuid1=d9f9fc05-45ae-4a36-a616-fccce0e4f887 => printenv uuid2 uuid2=eb3db83c-7b28-499f-95ce-9e0bb21cda81 => Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-11-23spl: Change debug to printf for "Unsupported boot-device"Stefan Roese
We had the problem on an AM33xx platform, that SPL detected an unsupported boot-device. But since this message is a debug message it took a bit of time to really know, where the hangup in SPL resulted from. So let's change this debug message to a printf and also print the detected boot-device that is not supported. This makes debugging of such cases much easier. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-21dm: i2c: Move error reporting into a common functionSimon Glass
Factor out the common code to make it easier to adjust it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com> Acked-by: Heiko Schocher <hs@denx.de>
2014-11-21dm: spl: Allow driver model to be usedSimon Glass
When enabled, set up driver model for SPL. This allows SPL to use the same drivers as the main U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Tom Rini <trini@ti.com>
2014-11-21dm: spl: Make simple malloc() available when enabledSimon Glass
Set up the simple malloc() implementation when requested, in preference to the full malloc(). Signed-off-by: Simon Glass <sjg@chromium.org>
