path: root/common
2013-10-16common: fsl: Fix broken SPDX-License-Identifier changeMichal Simek
This bug was introduced by: "Add GPL-2.0+ SPDX-License-Identifier to source files" (sha1: 1a4596601fd395f3afb8f82f3f840c5e00bdd57a) Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-10-15mtd: fix warnings due to 64-bit partition supportScott Wood
commit 39ac34473f3c96e77cbe03a49141771ed1639486 ("cmd_mtdparts: use 64 bits for flash size, partition size & offset") introduced warnings in a couple places due to printf formats or pointer casting. This patch fixes the warnings pointed out here: http://lists.denx.de/pipermail/u-boot/2013-October/164981.html Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Tom Rini <trini@ti.com>
2013-10-16sf: Add GPL-2.0+ SPDX-License-Identifier for missing onesJagannadha Sutradharudu Teki
Added GPL-2.0+ SPDX-License-Identifier for missed sf source files. Signed-off-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-10-14cmd_sandbox.c: Update for do_(load|save) not taking a number baseTom Rini
2013-10-14Prevent null pointer dereference originating in cmd_pxe.cSteven Falco
Pass a valid cmdtp into do_tftpb(), do_ext2load(), and do_get_fat(), to avoid possible crashes due to null pointer dereferencing. Commit d7884e047d08447dfd1374e9fa2fdf7ab36e56f5 does not go far enough. There is still at least one call chain that can result in a crash. The do_tftpb(), do_ext2load(), and do_get_fat() functions expect a valid cmdtp. Passing in NULL is particularly bad in the do_tftpb() case, because eventually boot_get_kernel() will be called with a NULL cmdtp: do_tftpb() -> netboot_common() -> bootm_maybe_autostart() -> do_bootm() -> do_bootm_states() -> bootm_find_os() -> boot_get_kernel() Around line 991 in cmd_bootm.c, boot_get_kernel() will dereference the null pointer, and the board will crash. Signed-off-by: Steven A. Falco <stevenfalco@gmail.com>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-10-14env_mmc: fix buffer allocation for armv7Markus Niebel
commit d196bd880347373237d73e0d115b4d51c68cf2ad adds redundand environment to mmc. The usage of malloc in env_relocate_spec triggers cache errors on armv7. Tested on a not mainlined i.MX53 board: Board: TQMa53 I2C: ready DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 ERROR: v7_dcache_inval_range - start address is not aligned - 0x8f57c2d8 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x8f57e2d8 ERROR: v7_dcache_inval_range - start address is not aligned - 0x8f57e2e0 ERROR: v7_dcache_inval_range - stop address is not aligned - 0x8f5802e0 Using default environment Signed-off-by: Markus Niebel <Markus.Niebel@tqs.de>
2013-10-14env: dataflash: fix env_init issueBo Shen
As the SPI controller is not initialized before env_init(), it causes reading env in dataflash failed. So, although saveenv() successfully, it shows warning information when reboot the system as following: *** Warning - bad CRC, using default environment Let the env_relocate() to check env CRC and import it. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2013-10-09cmd_ubi: add write.part command, to write a volume in multiple partsPaul Burton
This allows you to write data to an UBI volume when the amount of memory available to write that data from is less than the total size of the data. For example, you may split a root filesystem UBIFS image into parts, provide the total size of the image to the first write.part command and then use multiple write.part commands to write the subsequent parts of the volume. This results in a sequence of commands akin to: ext4load mmc 0:1 0x80000000 rootfs.ubifs.0 ubi write.part 0x80000000 root 0x08000000 0x18000000 ext4load mmc 0:1 0x80000000 rootfs.ubifs.1 ubi write.part 0x80000000 root 0x08000000 ext4load mmc 0:1 0x80000000 rootfs.ubifs.2 ubi write.part 0x80000000 root 0x08000000 This would write 384MiB of data to the UBI volume 'root' whilst only requiring 128MiB of said data to be held in memory at a time. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Stefan Roese <sr@denx.de>
2013-10-09cmd_ubi: use int64_t volume size for 'ubi create'Paul Burton
int64_t matches the bytes field in struct ubi_mkvol_req to which the size is assigned. With the prior signed 32 bit integer, volumes were restricted to being less than 2GiB in size. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Stefan Roese <sr@denx.de>
2013-10-09cmd_mtdparts: use 64 bits for flash size, partition size & offsetPaul Burton
This matches the 64 bit size in struct mtd_info and allows the mtdparts command to function correctly with a flash >= 4GiB. Format specifiers for size & offset are given the ll length, matching its use in drivers/mtd in absence of something like inttypes.h/PRIx64. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Acked-by: Stefan Roese <sr@denx.de>
2013-10-07Fix number base handling of "load" commandWolfgang Denk
As documented, almost all U-Boot commands expect numbers to be entered in hexadecimal input format. (Exception: for historical reasons, the "sleep" command takes its argument in decimal input format.) This rule was broken for the "load" command; for details please see especially commits 045fa1e "fs: add filesystem switch libary, implement ls and fsload commands" and 3f83c87 "fs: fix number base behaviour change in fatload/ext*load". In the result, the load command would always require an explicit "0x" prefix for regular (i. e. base 16 formatted) input. Change this to use the standard notation of base 16 input format. While strictly speaking this is a change of the user interface, we hope that it will not cause trouble. Stephen Warren comments (see [1]): I suppose you can change the behaviour if you want; anyone writing "0x..." for their values presumably won't be affected, and if people really do assume all values in U-Boot are in hex, presumably nobody currently relies upon using non-prefixed values with the generic load command, since it doesn't work like that right now. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/171172 Acked-by: Tom Rini <trini@ti.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-10-07mtd: Fix function description in part_validate commentOtavio Salvador
The part_validate comment had a wrong description of the actions it does and referenced to non-existent functions while in fact it calls 'part_validate_eraseblock()'. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2013-09-24usb:gadget:Remove redundant #includes for USB composite gadget and its functionsLukasz Majewski
Only the <linux/usb/gadget.h> requires error.h include. Hence, several includes of error.h at USB gadget functions are not needed. Moreover unnecessary malloc.h includes were also removed. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-09-24dfu: Extract common DFU code to handle "dfu_alt_info" environment variableLukasz Majewski
New dfu_init_env_entities() function has been extracted from cmd_dfu.c and stored at dfu core. This is a dfu centric code, so it shall be processed in the core. Change-Id: I756c5de922fa31399d8804eaadc004ee98844ec2 Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Heiko Schocher <hs@denx.de>
2013-09-24cmd_pxe.c: Pass along 'cmdtp' to do_bootm()/do_bootz()Tom Rini
When we call do_bootm() with a vmlinuz, this would lead to a NULL pointer dereference, and after talking with Wolfgang the right thing to do here for now is to make sure that we pass cmdtp to these functions rather than NULL. Reported-by: Steven A. Falco <stevenfalco@gmail.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-09-23cmd_bootm.c: Only pass BOOTM_STATE_OS_CMDLINE on PowerPC/MIPSTom Rini
In 5c427e4 we pass BOOTM_STATE_OS_CMDLINE as part of the bootm states to run, on all arches. However, this is only valid / useful on PowerPC and MIPS, and causes a problem on ARM where we specifically do not use it. Rather than make this state fake pass like we do for GO on some arches (which need updating to use the GO state), we should just not pass CMDLINE except when it may be used, like before. Tested-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-09-20Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2013-09-20FIT: delete unnecessary castsMasahiro Yamada
Becuase fdt_check_header function takes (const void *) type argument, the argument should be passed to it without being casted to (char *). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-09-20cosmetic: FIT: fix typos in commentsMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-20Fix loading freeze when netconsole is activeFrederic Leroy
Netconsole calls eth_halt() before giving control to another operating system. But the state machine of netconsole don't take it into account. Thus, netconsole calls network functions of an halted network device, making the whole system freeze. Rather than modifying the state machine of netconsole, we just unregister the current network device before booting. It does work because nc_send_packet() verifies that the current network device is not null. Signed-off-by: Frédéric Leroy <fredo@starox.org>
2013-09-20Fix some obvious typos across multiple subsystems.Robert P. J. Day
Typoes fixed: "partion" -> "partition" "retrive", "retreive" -> "retrieve" "th" -> "to" Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-20bootm: use BOOTM_STATE_OS_CMDLINE flag for plain bootmPaul Burton
A plain bootm used to call the architecture specific boot function with no flags, but was modified by commit 35fc84fa "Refactor the bootm command to reduce code duplication" to call the architecture specific boot function multiple times with various flags in sequence. The BOOTM_STATE_OS_CMDLINE flag was not used, indeed it seems that at least ARM prepares the command line on BOOTM_STATE_OS_PREP. However on MIPS since commit 59e8cbdb "MIPS: bootm: refactor initialisation of kernel cmdline" the command line is not prepared in response to a BOOTM_STATE_OS_PREP flag, only on BOOTM_STATE_OS_CMDLINE or a call with no flags. The end result is that a combination of those 2 commits leads to MIPS boards booting kernels with no command line arguments. An extra invocation of the architecture specific boot function with BOOTM_STATE_OS_CMDLINE fixes this. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-09-17spl_mmc: only call printf or puts with CONFIG_SPL_LIBCOMMON_SUPPORTPaul Burton
If we don't have CONFIG_SPL_LIBCOMMON_SUPPORT defined then stdio functions are unavailable & calling them will cause a link failure. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-09-17spl: remove unnecessary (& ARM specific) include of asm/utils.hPaul Burton
ARM is the only architecture which includes this header and nothing in spl_mmc.c makes use of it. Remove the include. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-09-16Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2013-09-06Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-05Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/serial/serial.c The conflict above was a trivial case of adding one init function in each branch, and manually resolved in merge.
2013-09-03bootm: allow correct bounds-check of destinationKees Cook
While nothing presently examines the destination size, it should at least be correct so that future users of sys_mapmem() will not be surprised. Without this, it might be possible to overflow memory. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-09-03sandbox: Correct compiler warnings in cmd_bootm/cmd_ximgSimon Glass
Correct the following warnings found with sandbox when compression is enabled. cmd_bootm.c: In function 'bootm_load_os': cmd_bootm.c:443:11: warning: passing argument 4 of 'lzop_decompress' from incompatible pointer type [enabled by default] /usr/local/google/c/cosarm/src/third_party/u-boot/files/include/linux/lzo.h:31:5: note: expected 'size_t *' but argument is of type 'uint *' cmd_ximg.c: In function 'do_imgextract': cmd_ximg.c:225:6: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] cmd_ximg.c:225:14: warning: 'hdr' may be used uninitialized in this function [-Wuninitialized] Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Kees Cook <keescook@chromium.org>
2013-08-31ARM: mxs: tools: Add mkimage support for MXS bootstreamMarek Vasut
Add mkimage support for generating and verifying MXS bootstream. The implementation here is mostly a glue code between MXSSB v0.4 and mkimage, but the long-term goal is to rectify this and merge MXSSB with mkimage more tightly. Once this code is properly in U-Boot, MXSSB shall be deprecated in favor of mkimage-mxsimage support. Note that the mxsimage generator needs libcrypto from OpenSSL, I therefore enabled the libcrypto/libssl unconditionally. MXSSB: http://git.denx.de/?p=mxssb.git;a=summary The code is based on research presented at: http://www.rockbox.org/wiki/SbFileFormat Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br>
2013-08-27cmd_sf: let "sf update" preserve the final part of the last sectorGerlando Falauto
Since "sf update" erases the last block as a whole, but only rewrites the meaningful initial part of it, the rest would be left erased, potentially erasing meaningful information. So, as a safety measure, have it rewrite the original content. Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Holger Brunck <holger.brunck@keymile.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2013-08-27Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2013-08-27i2c: fix i2c dev command for not using new frameworkHeiko Schocher
i2c dev command does not work anymore for legacy drivers because a check is executed that is valid only in the new framework. Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Stefano Babic <sbabic@denx.de>
2013-08-26console: usb: kbd: To fix slow TFTP bootingJim Lin
TFTP booting is slow when a USB keyboard is installed and stdin has usbkbd added. This fix is to change Ctrl-C polling for USB keyboard to every second when NET transfer is running. My previous patch is expected to be put into usb_kbd_testc(). But it went into usb_kbd_getc() after applied. This patch is to put change in correct place. Signed-off-by: Jim Lin <jilin@nvidia.com>
2013-08-26console: usb: kbd: To improve TFTP booting performanceJim Lin
TFTP booting is slow when a USB keyboard is installed and stdin has usbkbd added. This fix is to change Ctrl-C polling for USB keyboard to every second when NET transfer is running. Signed-off-by: Jim Lin <jilin@nvidia.com>
2013-08-26usb: Use well-known descriptor sizes when parsing configurationJulius Werner
The existing USB configuration parsing code relies on the descriptors' own length values when reading through the configuration blob. Since the size of those descriptors is always well-defined, we should rather use the known sizes instead of trusting device-provided values to be correct. Also adds some safety to potential out-of-order descriptors. Change-Id: I16f69dfdd6793aa0fe930b5148d4521f3e5c3090 Signed-off-by: Julius Werner <jwerner@chromium.org>
2013-08-26USB: usb-hub: Add a weak function for resetting devicesDan Murphy
Add a __weak function that can be overridden to reset devices attached to an ehci devices after the FEAT_POWER has been submitted Signed-off-by: Dan Murphy <dmurphy@ti.com>
2013-08-22env_nand.c: support falling back to redundant env when writingPhil Sutter
Without this patch, when the currently chosen environment to be written has bad blocks, saveenv fails completely. Instead, when there is redundant environment fall back to the other copy. Environment reading needs no adjustment, as the fallback logic for incomplete writes applies to this case as well. Signed-off-by: Phil Sutter <phil.sutter@viprinet.com>
2013-08-22cmd_nand: Do not show usage when scrub is abortedMasahiro Yamada
When executing nand scrub, the user gets the prompt: Really scrub this NAND flash? <y/N> We do not want the annoying usage displayed when saying N here. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-08-22cmd_nand: slight optimization of nand_dump functionMasahiro Yamada
If a non-zero value is given to only_oob argument, printing the main area is skipped. With a little modification, we can skip the whole while loop. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-08-22cmd_nand: fix a memory leak in nand_dump functionMasahiro Yamada
If datbuf = memalign(ARCH_DMA_MINALIGN, nand->writesize); succeeds and oobbuf = memalign(ARCH_DMA_MINALIGN, nand->oobsize); fails, nand_dump function should free databuf. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-08-21Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-08-20spl: env_common.c: make CONFIG_SPL_BUILD contain function env_importYing Zhang
The functionality env_import will be used in the SPL. They had been excluded by ifndef CONFIG_SPL_BUILD. Now, put it into the SPL. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20ppc4xx: Remove support for PPC405CR CPUsMatthias Fuchs
This patch removes support for the APM 405CR CPU. This CPU is EOL and no board uses this chip. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2013-08-19SPDX-License-Identifier: convert BSD-3-Clause filesWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini Don't remove some copyrights by accident] Signed-off-by: Tom Rini <trini@ti.com>
2013-08-18Merge branch 'master' of git://88.191.163.10/u-boot-armTom Rini
Fixup an easy conflict over adding the clk_get prototype and USB_OTG defines for am33xx having moved. Conflicts: arch/arm/include/asm/arch-am33xx/hardware.h Signed-off-by: Tom Rini <trini@ti.com>
2013-08-16image: Display FIT timestamp when bootingSimon Glass
The timestamp is shown in fit_print_contents() but for some reason not in fit_image_print(). This seems to be an oversight, since it is the latter which is used by bootm. Add timestamp printing in this case. (There is code duplication in these two function, for looking at in a future patch). Signed-off-by: Simon Glass <sjg@chromium.org>
