path: root/common
2009-09-10mkimage: Add Kirkwood Boot Image support (kwbimage)Prafulla Wadaskar
This patch adds support for "kwbimage" (Kirkwood Boot Image) image types to the mkimage code. For details refer to docs/README.kwbimage This patch is tested with Sheevaplug board Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-10mkimage: Make table_entry code globalPrafulla Wadaskar
- make get_table_entry_id() global - make get_table_entry_name() global - move struct table_entry to image.h Currently this code is used by image.c only. This patch makes this API global so it can be used by other parts of code, too. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron.debian.org> Edit comments and commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10mkimage: Make genimg_print_size() globalPrafulla Wadaskar
Currently it is used by image.c only, but the the function can be used to support additional mkimage types like for example kwbimage, so make this function globally visible. Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10tools/mkimage: fix compiler warnings, use "const"Wolfgang Denk
This fixes some compiler warnings: tools/default_image.c:141: warning: initialization from incompatible pointer type tools/fit_image.c:202: warning: initialization from incompatible pointer type and changes to code to use "const" attributes in a few places where it's appropriate. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-04cmd_mtdparts.c: fix compiler warning in debug codeWolfgang Denk
Fix warning messages: cmd_mtdparts.c:1429: warning: format '%08lx' expects type 'long unsigned int', but argument 6 has type 'u32' cmd_mtdparts.c:1429: warning: format '%08lx' expects type 'long unsigned int', but argument 7 has type 'u32' Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-04Add ability for arch code to make changes before we bootKumar Gala
Added a arch_preboot_os() function that cpu specific code can implement to allow for various modifications to the state of the machine right before we boot. This can be useful to setup register state to a specific configuration. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-04Consolidate arch-specific mem_malloc_init() implementationsPeter Tyser
2009-09-04Consolidate arch-specific sbrk() implementationsPeter Tyser
2009-08-31Merge branch 'next' of ../nextWolfgang Denk
2009-08-30bugfix CONFIG_SYS_CONSOLE_INFO_QUIETDavid Brownell
The "console: unify printing current devices" patch goofed: CONFIG_SYS_CONSOLE_INFO_QUIET is supposed to *REMOVE* boot time noise, not add it. Said patch changed the #ifndefs to #ifdef; this one restores them to the proper sense. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-25Add md5sum and sha1 commands...Robin Getz
Now that we have sha1 and md5 in lib_generic, allow people to use them on the command line, for checking downloaded files. Signed-off-by: Robin Getz <rgetz@analog.com>
2009-08-09fdt: Fix fdt_pci_dma_ranges handling of 64-bit rangesKumar Gala
If the size of a region equal to 4G it can't be represnted in a 32-bit BAR so we should have marked that case as MEM64. Additionally bump the number of inbound windows up to 4 to handle the fact that Freescale PPCs that have an implicit window for CCSRBAR. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-09hush: Fix bogus free() callPeter Tyser
An off-by-one error in hush.c resulted in an unintentional free() call every time a command was executed Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-08-09env: kill off default_environment_sizeMike Frysinger
The only environment type that uses this variable is spi flash, and that is only because it is reimplementing the common set_default_env() function. So fix the spi flash code and kill off the default_environment_size in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-09export SPI functions to standalone appsMike Frysinger
While we're here, fix the broken #ifdef handling in _exports.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-04Merge branch 'next' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2009-07-28Fix ext2load return codeWolfgang Denk
Make the ext2load command return 0 on success (instead of the file length). Also fix output format (get rid of random newlines) and some coding style issues (long lines etc.). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-27Less verbose output when loading vxworks 6.x imagesNiklaus Giger
Loading vxWorks 5.x images resulted just into 3 or 4 lines of output. With vxWorks 6.x and the new GCC it emits about 30 lines, which is far too noisy in my opinion. Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
2009-07-27Fix compiler warnings after loff_t changeKyungmin Park
Now 'env_addr' type is loff_t so use correct field type. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-07-25video: move extern declarations from C to headersAlessandro Rubini
This moves some extern declaration from lcd.c to lcd.h, removing unneeded ifdef around a pair of them. Additionally, since gunzip_bmp() was declared static in cmd_bmp.c but extern in lcd.c, I removed the static. The extra "#include <lcd.h>" in cmd_bmp.c is added to ensure the header is consistent with the source. This has been compile-tested on both ARM (at91 boards) and PowerPC (HH405_config, TQM823L_LCD_config, mcc200_config), to test all use combinations. Signed-off-by: Alessandro Rubini <rubini@gnudd.it> [agust@denx.de: removed gunzip_bmp() fixes as commit c01171ea did it] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-07-23Coding Style cleanup; update CHANGELOG.Wolfgang Denk
2009-07-23Remove static declaration from gunzip_bmp()Mark Jackson
This patch removes the static declaration from gunzip_bmp() Without it, the gunzip_bmp() function is not visible to common/lcd.c and fails to compile with an error. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
2009-07-23cmd_tsi148: General cleanupPeter Tyser
- Fix command help message - Disable DEBUG by default - Fix whitespace issues - Fix lines > 80 characters Signed-off-by: Peter Tyser <ptyser@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2009-07-23Re-add support for image type 'Standalone Program'Detlev Zundel
Support for this type was lost during the bootm refactoring. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-07-23Add error checking for unsupported OS types.Detlev Zundel
2009-07-22Add DNS supportRobin Getz
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot. http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html > > DNS can be enabled by setting CFG_CMD_DNS. After performing a query, > the serverip environment var is updated. > > Probably there are some cosmetic issues with the patch. Unfortunatly I > do not have the time to correct these. So if anybody else likes DNS > support in U-Boot and has the time, feel free to patch it in the main tree. Here it is again - slightly modified & smaller: - update to 2009-06 (Pieter's patch was for U-Boot 1.2.0) - README.dns is added - syntax is changed (now takes a third option, the env var to store the result in) - add a random port() function in net.c - sort Makefile in ./net/Makefile - dns just returns unless a env var is given - run through checkpatch, and clean up style issues - remove packet from stack - cleaned up some comments - failure returns much faster (if server responds, don't wait for timeout) - use built in functions (memcpy) rather than byte copy. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22Refresh LZMA-lib to v4.65Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com>
2009-07-20ubi: help message correctionAndrzej Wolski
Fix incorrect information about size units and correct typo. Signed-off-by: Andrzej Wolski <awolski@poczta.fm> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-19common: fix 'dummy' is used uninitialized in this function warningKim Phillips
fix this gcc 4.4 warning: xyzModem.c: In function 'xyzModem_stream_open': xyzModem.c:564: warning: 'dummy' is used uninitialized in this function Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-19cmd_flash.c: fix fix compile error for boards with DataFlashWolfgang Denk
Commit 5669ed45 ("cmd_flash.c: fix warning: unused variable 'addr_first'/'addr_last'") changed the #ifdef logic areound the declaration of these variables and missed a combination of settings of HAS_DATAFLASH with SYS_NO_FLASH; this patch fixes this. Also spotted by Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-19Add support for the Tundra TSI148 VME-bridgeReinhard Arlt
From: Reinhard Arlt <reinhard.arlt@esd-electronics.com> This patch adds support for the Tundra TSI148 VME-bridge. It's used on the upcoming esd VME8349 board. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-19console: unify printing current devicesJean-Christophe PLAGNIOL-VILLARD
Create stdio_print_current_devices() for this purpose Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-19Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2009-07-18cmd_flash.c: fix warning: unused variable 'addr_first'/'addr_last'Wolfgang Denk
2009-07-18Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2009-07-18Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2009-07-18cmd_i2c: bugfix: add missing braceAlessandro Rubini
The sub-command parser missed a brace, so "return 0;" is always taken and no error message is diplayed if you say "i2c scan" instead of "i2c probe", for example. Proper brace is added. Also, a misleading and unneeded else is removed. Signed-off-by: Alessandro Rubini <rubini@gnudd.com.it>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-17Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2009-07-17sata: namespace curr_device variableMike Frysinger
The curr_device variable really should be namespaced with a "sata_" prefix since it is only used by the sata code. It also avoids random conflicts with other pieces of code (like cmd_mmc): common/libcommon.a(cmd_sata.o):(.data.curr_device+0x0): multiple definition of `curr_device' common/libcommon.a(cmd_mmc.o):(.data.curr_device+0x0): first defined here Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-17cmd_mmc: make curr_device staticMike Frysinger
The curr_device variable isn't used outside of cmd_mmc, so mark it static to avoid conflicts with other pieces of code (like sata which also exports a curr_device). Otherwise we end up with stuff like: common/libcommon.a(cmd_sata.o):(.data.curr_device+0x0): multiple definition of `curr_device' common/libcommon.a(cmd_mmc.o):(.data.curr_device+0x0): first defined here Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-17Added support for splash screen positioningMatthias Weisser
This patch adds support splash image positioning by adding an additional variable "splashpos" to the environment. Please see README for details. Signed-off-by: Matthias Weisser <matthias.weisser@graf-syteco.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-07-16Remove legacy NAND and disk on chip code.Scott Wood
Legacy NAND had been scheduled for removal. Any boards that use this were already not building in the previous release due to an #error. The disk on chip code in common/cmd_doc.c relies on legacy NAND, and it has also been removed. There is newer disk on chip code in drivers/mtd/nand; someone with access to hardware and sufficient time and motivation can try to get that working, but for now disk on chip is not supported. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-16MTD: OneNAND: Increase the environment size to 4KiBKyungmin Park
Also use mtd operation instead of onenand functions Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-16Add simple hwconfig infrastructureAnton Vorontsov
This patch implements simple hwconfig infrastructure: an interface for software knobs to control a hardware. This is very simple implementation, i.e. it is implemented via `hwconfig' environment variable. Later we could write some "hwconfig <enable|disable|list>" commands, ncurses interface for Award BIOS-like interface, and frame-buffer interface for AMI GUI[1] BIOS-like interface with mouse support[2]. Current implementation details/limitations: 1. Doesn't support options dependencies and mutual exclusion. We can implement this by integrating apt-get[3] into the u-boot. But I didn't bother yet. 2. Since we don't implement hwconfig command, i.e. we're working with the environement directly, there is no way to tell that toggling a particular option will need a reboot to take an effect. So, for now it's advised to always reboot the target after modifying hwconfig variable. 3. We support hwconfig options with arguments. For example, set hwconfig dr_usb:mode=peripheral,phy_type=ulpi That means: - dr_usb - enable Dual-Role USB controller; - dr_usb:mode=peripheral - USB in Function mode; - dr_usb:phy_type=ulpi - USB should work with ULPI PHYs; The purpose of this simple implementation is to define some internal API and then we can continue improving user experience by adding more mature interface, like hwconfig command with bells and whistles. Or not adding, if we feel that current interface fits its needs. [1] http://en.wikipedia.org/wiki/American_Megatrends [2] Regarding ncurses and GUI with mouse support -- I'm just kidding. [3] The comment regarding apt-get is also a joke, meaning that dependency tracking could be non-trivial. For example, for enabling HW feature X we may need to disable Y, and turn Z into reduced mode (like RMII-only interface for ethernet, no MII). It's quite trivial to implement simple cases though. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-14Command for accessing serial flash updateTsiChung Liew
Change strtoul number base of argv 3 from 0 to 16 Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-07-09Command improvements for ubifsSimon Kagstrom
Check that an argument is passed to ubifsmount and that addresses and sizes are actually numbers for ubifsload. Also improve the instructions a bit. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-09Handle VID header offset in ubi part commandSimon Kagstrom
The VID header offset is sometimes needed to initialize the UBI partition. This patch adds it (optionally) to the command line for the ubi part command. (Lines have been properly wrapped since last version) Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-07env_onenand: change env_address type from unsigned long to loff_tHeungJun Kim
If use the onenand boot, the env_relocate_spec() calls mtd->read(), and the type of the argument #2 of mtd->read() was changed to loff_t. But, the "env_addr" type is still unsigned long, thus this patch change the type from unsigned long to loff_t. Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
