path: root/common
2017-12-18common: image.c: Fix CACHE: Misaligned operation outputHeiko Schocher
When booting a itb file with a Ramdisk on a imx6 based board, U-Boot drops the warning: Loading Kernel Image ... OK Loading Ramdisk to 4ecf1000, end 4ef8b11f ... \ CACHE: Misaligned operation at range [4ecf1000, 4ef8b11f] Fix it! Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Ayoub Zaki <hs@denx.de>
2017-12-18Merge tag 'xilinx-for-v2018.01-rc2-v2' of ↵Tom Rini
git://www.denx.de/git/u-boot-microblaze Xilinx changes for v2018.01-rc2-v2 fpga: - Enable loading bitstream via fit image for !xilinx platforms zynq: - Fix SPL SD boot mode zynqmp: - Not not reset in panic - Do not use simple allocator because of fat changes - Various dt chagnes - modeboot variable setup - Fix fpga loading on automotive devices - Fix coverity issues test: - Fix env test for !hush case - Stephen's patch
2017-12-14Merge git://git.denx.de/u-boot-dmTom Rini
2017-12-14fpga: allow programming fpga from FIT image for all FPGA driversGoldschmidt Simon
This drops the limit that fpga is only loaded from FIT images for Xilinx. This is done by moving the 'partial' check from 'common/image.c' to 'drivers/fpga/xilinx.c' (the only driver supporting partial images yet) and supplies a weak default implementation in 'drivers/fpga/fpga.c'. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com> Tested-by: Michal Simek <michal.simek@xilinx.com> (On zcu102) Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-12-12binman: Add binman support to spl_ram.cSimon Glass
SPL supports reading U-Boot from a RAM location. At present this is hard-coded to the U-Boot text base address. Use binman to allow this to come from the image file, if binman is used. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12binman: Add binman symbol support to SPLSimon Glass
Allow SPL to access binman symbols and use this to get the address of U-Boot. This falls back to CONFIG_SYS_TEXT_BASE if the binman symbol is not available. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-12SPL: Add FIT data-position property supportPeng Fan
For external data, FIT has a optional property "data-position" which can set the external data to a fixed offset to FIT beginning. Add the support for this property in SPL FIT. Signed-off-by: Ye Li <ye.li@nxp.com> Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tomas Melin <tomas.melin@vaisala.com> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: "tomas.melin@vaisala.com" <tomas.melin@vaisala.com> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: York Sun <york.sun@nxp.com> Cc: Lokesh Vutla <lokeshvutla@ti.com> Cc: "Cooper Jr., Franklin" <fcooper@ti.com> Cc: George McCollister <george.mccollister@gmail.com> Cc: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Cc: Jean-Jacques Hiblot <jjhiblot@ti.com> Cc: Rick Altherr <raltherr@google.com> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-12-07log: Plumb logging into the init sequenceSimon Glass
Set up logging both before and after relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-07log: Add a test commandSimon Glass
Add a command which exercises the logging system. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-07log: Add a console driverSimon Glass
It is useful to display log messages on the console. Add a simple driver to handle this. Note that this driver outputs to the console, which may be serial or video. It does not specifically select serial output. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-07log: Add an implementation of loggingSimon Glass
Add the logging header file and implementation with some configuration options to control it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-07Drop the log bufferSimon Glass
This does not appear to be used by any boards. Before introducing a new log system, remove this old one. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-07usb: Correct use of debug()Simon Glass
With clang this gives a warning because hubsts appears to be used before it is set, even if ultimately it is not used. Simplify the code to avoid this problem. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-07Revert "sandbox: Drop special case console code for sandbox"Simon Glass
While sandbox works OK without the special-case code, it does result in console output being stored in the pre-console buffer while sandbox starts up. If there is a crash or a problem then there is no indication of what is going on. For ease of debugging it seems better to revert this change also. This reverts commit d8c6fb8cedbc35eee27730a7fa544e499b3c81cc. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-11-29common: command: tempory buffer should have size of command line bufHeinrich Schuchardt
When copying the command line buffer the target array should at least have the same size. Cf. definition of console_buffer in common/cli_readline.c. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-11-28Merge git://git.denx.de/u-boot-usbTom Rini
2017-11-27spl: TI: Do not default to SPL_FIT_IMAGE_TINY being enabledTom Rini
This option prevents booting on am335x_evm at least along with most likely other platforms. Fixes: 337bbb629777 ("spl: fit: add SPL_FIT_IMAGE_TINY config to reduce code-size") Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-26usb: hub: identify the hub-device to usb_hub_reset_devicesPhilipp Tomsich
When usb_hub_reset_devices is called, it should be passed both an indicator which hub it should operate on and what port number (local to that hub) should be reset. Previously, the usb_hub.c code did not include such context and always started resets from port number 1, performing multiple reset-requests for the same devices: /* * Reset any devices that may be in a bad state when applying * the power. This is a __weak function. Resetting of the devices * should occur in the board file of the device. */ for (i = 0; i < dev->maxchild; i++) usb_hub_reset_devices(i + 1); This adds an additional 'hub' parameter to usb_hub_reset_devices that provides the context to fully qualify the port-number in. Existing implementations are changed to accept and ignore the new parameter. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Tested-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com>
2017-11-26spl: fit: add SPL_FIT_IMAGE_TINY config to reduce code-sizePhilipp Tomsich
A minor code-size increase from the changes for tracking the os-type of FIT images and from infrastructure for recording the loadables into the the loaded FDT, broke the builds for sun50i and some OMAP2+ devices. This change adds a new config option (enabled by default for MACH_SUN50I, MACH_SUN50I_H5 and ARCH_OMAP2PLUS) that does skips these processing steps (bringing code size down to below the limit again). The os-type is not evaluated, but assumed to be IH_OS_UBOOT (i.e. taking the code-paths intended for backward-compatibility). Note that enabling this config option precludes any useful downstream processing, such as utilising a special calling convention for ATF or OPTEE, based on the os-type of the loadables. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-26spl: atf: drop the SPL_ATF_TEXT_BASE configuration itemPhilipp Tomsich
The SPL_ATF_TEXT_BASE configuration item has become obsolete. Remove it from Kconfig. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-26spl: rename config item SPL_ATF_SUPPORT to SPL_ATFPhilipp Tomsich
Having CONFIG_SPL_ATF seems more natural. Rename it, while it it is easy and there's few boards that use it (only RK3399 and RK3368 boards). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-26spl: atf: introduce spl_invoke_atf and make bl31_entry privatePhilipp Tomsich
This adds a new interface spl_invoke_atf() that takes a spl_image_info argument and then derives the necessary parameters for the ATF entry. Based on the additional information recorded (into /fit-images) from the FIT loadables, we can now easily locate the next boot stage. We now pass a pointer to a FDT as the platform-specific parameter pointer to ATF (so we don't run into the future headache of every board/platform defining their own proprietary tag-structure), as FDT access is already available in ATF. With the necessary infrastructure in place, we can now update the support for the ARM Trusted Firmware to dispatch into the spl_invoke_atf function only if a IH_OS_ARM_TRUSTED_FIRMWARE image is loaded. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-26spl: fit: implement recording of loadables into /fit-imagesPhilipp Tomsich
If a FDT was loaded (e.g. to append it to U-Boot image), we store it's address and record information for all loadables into this FDT. This allows us to easily keep track of images for multiple privilege levels (e.g. with ATF) or of firmware images preloaded into temporary locations (e.g. PMU firmware that may overlap the SPL stage). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-26spl: fit: implement fdt_record_loadablePhilipp Tomsich
During the loading of more complex FIT images (e.g. when the invoked next stage needs to find additional firmware for a power-management core... or if there are multiple images for different privilege levels started in parallel), it is helpful to create a record of what images are loaded where: if a FDT is loaded for one of the next stages, it can be used to convey the status and location of loadables. This adds a fdt_record_loadable() function that can be invoked to record the status of each loadable below the /fit-images path. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-26spl: fit: simplify logic for FDT loading for non-OS bootsPhilipp Tomsich
To better support bootin through an ATF or OPTEE, we need to streamline some of the logic for when the FDT is appended to an image: depending on the image type, we'd like to append the FDT not at all (the case for the OS boot), to the 'firmware' image (if it is a U-Boot) or to one of the loadables (if the 'firmware' is an ATF, an OPTEE, or some other image-type and U-Boot is listed in the loadabled). To achieve this goal, we drop the os_boot flag and track the type of image loaded. If it is of type IH_OS_U_BOOT, we append the FDT. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-26image: add IH_OS_ARM_TRUSTED_FIRMWARE for ARM Trusted FirmwarePhilipp Tomsich
To boot on ARMv8 systems with ARM Trusted Firmware, we need to assemble an ATF-specific parameter structure and also provide the address of the images started by ATF (e.g. BL3-3, which may be the full U-Boot). To allow us to identify an ARM Trusted Firmware contained in a FIT image, this adds the necessary definitions. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-21thermal: ti-bandgap: Add support for temperature sensorFaiz Abbas
The dra7xx series of SOCs contain a temperature sensor and an associated analog-to-digital converter (ADC) which produces an output which is proportional to the SOC temperature. Add support for this temperature sensor. Signed-off-by: Faiz Abbas <faiz_abbas@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-20malloc: don't compare pointers to 0Heinrich Schuchardt
0 is not a pointer. So do not compare pointers to 0. Do not return 0 from functions with a pointer return type. Problem identified with Coccinelle. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-11-19Merge git://git.denx.de/u-boot-dmTom Rini
2017-11-17Kconfig: Introduce USE_BOOTCOMMAND and migrate BOOTCOMMANDTom Rini
We first introduce CONFIG_USE_BOOTCOMMAND, similar to CONFIG_USE_BOOTARGS. We then migrate CONFIG_BOOTCOMMAND for most CONFIG_DISTRO_DEFAULT users. In some cases platforms have a complex scheme around this usage, and these have been defered for the moment so that platform maintainers can work on a migration plan. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2017-11-16SPL: fix printing of image nameAndré Draszik
The maximum length of the name of the image is obviously not sizeof(), which is just the length of a pointer, but IH_NMLEN. fixes: 62cf11c0921a90c6bd62344f4bc069668e6c698c ("SPL: Limit image name print length") Signed-off-by: André Draszik <adraszik@tycoint.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-11-12Revert "console: simplify puts()"Soeren Moch
This reverts commit c61d0009feb966e0e93254a8c435a1889085e6b8. A tbs2910 board user reported a very slow console frambuffer as regression in current u-boot. I could bisect this down to the above mentioned commit. This revert brings back the fast framebuffer console (one cache flush per string in puts(), not after each char). Reported-by: Uwe Scheffler <scheffler.u@web.de> Signed-off-by: Soeren Moch <smoch@web.de> Tested-by: Uwe Scheffler <scheffler.u@web.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-07spl: set SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to 0x4000 for rockchipKever Yang
Rockchip use a 'loader2' partition for U-Boot, so u-boot.bin or u-boot.itb load by SPL need to locate at0x4000. Detail here: http://opensource.rock-chips.com/wiki_Boot_option Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-06image-sig: use designated initializers for algorithmMasahiro Yamada
Designated initializers are more readable because we do not have to check the order in the struct definitions. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-06stm32: fix STMicroelectronics copyrightPatrice Chotard
Uniformize STMicroelectronics copyrights headers for STM32 related code. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2017-10-16common: Remove genimg_get_image()Tuomas Tynkkynen
Removal of the legacy DataFlash code turned genimg_get_image() into a no-op. Drop all calls to it and the function itself. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-16Drop CONFIG_HAS_DATAFLASHTuomas Tynkkynen
Last user of this option went away in commit: fdc7718999 ("board: usb_a9263: Update to support DT and DM") Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-10-12Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-10-09spl: fix assignment of board info to global dataYork Sun
Commit 15eb1d43bf47 ("spl: reorder the assignment of board info to global data") intended to move assignment of board info earlier, into board_init_r(). However, function preload_console_init() is called either from spl_board_init() or from board_init_f(). For the latter case, the board info assignment is much earlier than proposed board_init_r(). Create a new function to fill gd->bd and call this function when needed. Signed-off-by: York Sun <york.sun@nxp.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Ravi Babu <ravibabu@ti.com> CC: Lukasz Majewski <lukma@denx.de> CC: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-05fit: If no matching config is found in fit_find_config_node(), use the ↵Jean-Jacques Hiblot
default one If board_fit_config_name_match() doesn't match any configuration node, then use the default one (if provided). Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-05fit: fixed bug in locate_dtb_in_fit()Jean-Jacques Hiblot
If the dtb is the first data of the FIT, the its offset is 0x0. Change the test to '<' instead of '<=' Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-05fit: use 'const' for the input of fdt_offset() and locate_dtb_in_fit()Jean-Jacques Hiblot
Those 2 functions don't modify their input, we can mark it const. This prevents compilation warnings when they are provided const input. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-05dts: renamed FIT_EMBED to MULTI_DTB_FIT and moved it to the dts KconfigJean-Jacques Hiblot
CONFIG_FIT_EMBED might be confused with CONFIG_OF_EMBED, rename it MULTI_DTB_FIT as it is able to get a DTB from a FIT image containing multiple DTBs. Also move the option to the Kconfig dedicated to the DTS options and create a README for this feature. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-05common: Drop LOGLEVEL to 4Tom Rini
While this came in with a default value of 6 I am lowering this to 4. The MTD/UBI code has a large number of error messages that we include now. In addition, "normally" warning messages are not included so this feels like a more natural level to have. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-04printk: collect printk stuff into <linux/printk.h> with loglevel supportMasahiro Yamada
When we import code from Linux, with regular re-sync planned, we want to use printk() and pr_*(). U-Boot does not support them in a clean way. So, people end up with local macros, or compat headers here and there, then we occasionally see build errors of definition conflicts. We have include/linux/compat.h, but putting all sorts of unrelated things into a single header is just a temporal workaround. Hence this patch, to find the best home for all printk variants. If you want to use printk() and friends, please include <linux/printk.h>. This header is self-contained, and pulls in only a few headers. When I was testing this clean-up, I noticed the image size exceeded its platform limit on some boards. This is because all pr_*() that were previously defined as no-op in include/linux/mtd/mtd.h (unless CONFIG_MTD_DEBUG is set), are now enabled. To make such boards happy, this commit also implements CONFIG_LOGLEVEL. The concept is similar to the kernel parameter "loglevel". (Actually, the Kconfig help message was taken from kernel-paremeter.txt of Linux) Messages with a loglevel smaller than console loglevel will be printed. The difference is the loglevel is build-time determined. To save the image size, lower priority pr_*() are compiled out. I set the default of CONFIG_LOGLEVEL to 6, i.e. pr_notice and higher priority messages are compiled in. I adjusted CONFIG_LOGLEVEL to avoid build error for some boards. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> [trini: Add in SPL_LOGLEVEL that is the same as LOGLEVEL] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-01Merge git://git.denx.de/u-boot-usbTom Rini
2017-10-01usb: storage: Fix overwritten in usb_stor_set_max_xfer_blk()Bin Meng
The stored 'blk' value is overwritten to 'size / 512' before it can be used in usb_stor_set_max_xfer_blk(). This is not what we want. In fact, when 'size' exceeds the upper limit (USHRT_MAX * 512), we should simply assign 'size' to the upper limit. Reported-by: Coverity (CID: 167250) Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: hub: Clear BH reset status change for a 3.0 hubBin Meng
USB 3.0 hubs report bit[5] in the port status change response as BH reset. The hub shall set the C_BH_PORT_RESET field for this port. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-01usb: hub: Clear port reset before usb_hub_port_connect_change()Bin Meng
During usb_hub_port_connect_change(), a port reset set feature request is issued to the port, and later a port reset clear feature is done to the same port before the function returns. However at the end of usb_scan_port(), we attempt to clear port reset again on a cached port status change variable, which should not be done. Adjust the call to clear port reset to right before the call to usb_hub_port_connect_change(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
