This patch adds the following common routines:
1) Dedicated mkimage print_header() is replaced with common
image_print_contents()
image_print_contents_noindent()
2) Common os/arch/type/comp fields name <--> id translation routines
genimg_get_os_name()
genimg_get_arch_name()
genimg_get_type_name()
genimg_get_comp_name()
genimg_get_os_id()
genimg_get_arch_id()
genimg_get_type_id()
genimg_get_comp_id()
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
Allow the user to set 'bootm_low' and 'bootm_size' env vars as a way
to restrict what memory range is used for bootm.
Acked-by: Marian Balakowicz <m8@semihalf.com>
Convert generic ramdisk_high(), get_boot_cmdline(), get_boot_kbd()
functions over to using lmb for allocation of the ramdisk, command line
and kernel bd info.
Convert PPC specific fdt_relocate() to use lmb for allocation of the device
tree.
Provided a weak function that board code can call to do additional
lmb reserves if needed.
Also introduce the concept of bootmap_base to specify the offset in
physical memory that the bootmap is located at. This is used for
allocations of the cmdline, kernel bd, and device tree as they should
be contained within bootmap_base and bootmap_base + CFG_BOOTMAPSZ.
The autostart env variable was dropped as part of the initial new uImage
cleanup. Add it back here so the arch specific code can decide if it
wants to really boot or not.
Introduce the LMB lib used on PPC in the kernel as a clean way to manage
the memory spaces used by various boot images and structures. This code
will allow us to simplify the code in bootm and its support functions.
Changed image_get_ramdisk() to just return NULL on error and have
get_ramdisk() propogate that error to the caller. It's left to the
caller to call do_reset() if it wants to.
Also moved calling do_reset() in get_fdt() and fdt_relocate() on ppc
to a common location. In the future we will change get_fdt() and
fdt_relocate() to return success/failure and not call do_reset() at all.
We don't actually need the kdb param as we are just using it to get
bd->bi_memsize which we can get from gd->bd->bi_memsize. Also, if we
boot via OF we might not actually fill out a kdb.
Dual format image code must properly handle all three FDT passing methods:
- raw FDT blob passed
- FDT blob embedded in the legacy uImage
- FDT blob embedded in the new uImage
This patch enables proper raw FDT handling when no FIT imaeg support
is compiled in. This is a bit tricky as we must dected FIT format even
when FIT uImage handling is not enabled as both FIT uImages and raw FDT
blobs use tha same low level format (libfdt).
Legacy image specific verification is factored out to a separate helper
routine to keep get_kernel() generic and simple.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Do not pass image verification flag directly to related routines.
Simplify argument passing and move it to the bootm_header structure which
contains curently processed image specific data and is already being passed
on the argument list.
When CONFIG_HAS_DATAFLASH is not defined gen_get_image() routine has nothing
to do, update its control flow to better reflect that simple case.
This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
Introducing routines for parsing new uImage format bootm arguments:
[<addr>]#<conf> - configuration specification
[<addr>]:<subimg> - subimage specification
New format images can contain multiple subimages of the same type. For example
a single new format image file can contain three kernels, two ramdisks and a
couple of FDT blobs. Subimage and configuration specifications are extensions
to bootm (and other image-related commands) arguments' syntax that allow to
specify which particular subimage should be operated on.
Subimage specification is used to denote a particular subimage. Configurations
are a bit more complex -- they are used to define a particualr booting setup,
for example a (kernel, fdt blob) pair, or a (kernel, ramdisk, fdt blob) tuple,
etc.
This routine assures that image (whether legacy or FIT) is not
in a special dataflash storage.
If image address is a dataflash address image is moved to system RAM.
If the length of the memory address range passed to the "mtest" command is
not of the form 2^x - 1, not all address lines are tested. This bug is
inherited from the original software at
http://www.netrino.com/Embedded-Systems/How-To/Memory-Test-Suite-C. Fix
this.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
common/cmd_reginfo.c
Makefile
doc/README.standalone
Fix a missing return statement from a non-void function.
Current MII_DEBUG is confusing in two ways. One is useless define-then-
undef at the top of the file. The other is there is only one debug() in
this file, and that doesn't seem worthwhile to bother having MII_DEBUG.
While there are many useful printf()/puts() debug codes, but they are for
DEBUG, not for MII_DEBUG.
This patch tries to put them all together into MII_DEBUG and debug().
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
read_dataflash() takes a signed char pointer as a parameter. Silence a
few warnings dues to incorrect parameter types in env_dataflash.c.
Signed-off-by: Stelian Pop <stelian@popies.net>
Move the flat device tree setup for QE related devices into
a common file shared between 83xx & 85xx platforms that have QE's.
Verification of the kernel image (in old format) and finding kernel
data is moved to a dedicated routine. The routine will also hold
support for, to be added, new image format.
This patch moves common pre-boot allocation steps shared between PPC
and M68K to a helper routines:
common:
- get_boot_sp_limit()
- get_boot_cmline()
- get_boot_kbd()
platform:
- set_clocks_in_mhz()
Ramdisk loading code, including initrd_high variable handling,
was duplicated for PPC and M68K platforms. This patch creates
common helper routine that is being called from both platform
do_bootm_linux() routines.
Architecture specific do_bootm_linux() routines share common
ramdisk image processing code. Move this code to a common
helper routine.
Move numeric-id to name translation for image os/arch/type/comp header
fields to a helper routines: image_get_os_name(), image_get_arch_name(),
image_get_type_name(), image_get_comp_name().
Standalone applications are supposed to be run using the "go" command.
This patch removes standalone images handling from the do_bootm().
Support for OF_FLAT_TREE is to be obsoleted in the near future,
remove related code from the bootm routines.
Check for overwrites during image move/uncompress, return with error
when the original image gets corrupted. Report clear message to the user
and prevent further troubles when pointer to the corrupted images is passed
to do_bootm_linux routine.
- use single image header pointer instead of a set of auxilliary variables.
- add multi component image helper routines: get component size/data address
- sort and cleanup headers, declarations, etc.
- group related routines
- cleanup indentation, white spaces
Move common, watchdog sensible memmove code to a helper memmmove_wd() routine.
I386 targets are not using a uImage format, instead fake header
is added to ram image before it is further processed by bootm.
Remove this fixup and force proper uImage use for I386.
CHUNKSZ defined for PPC and M68K is set to the same value of 64K,
move this definition to a common header.
Move gunzip(), zalloc() and zfree() to a separate file.
Share zalloc() and zfree() with cramfs uncompress routine.
Make CONFIG_OF_LIBFDT and CONFIG_OF_FLAT_TREE use more
readable in PPC variant of do_bootm_linux() routine.
PPC implementation of do_bootm_linux() routine is moved to
a dedicated file lib_ppc/ppc_linux.c
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
