The simple malloc() implementation is used when memory is tight. It provides
a simple buffer with an incrementing pointer.
At present the implementation is inside dlmalloc. Move it into its own file
so that it is easier to find.
Rather than using relocation as a signal that the full malloc() is
available, add a special GD_FLG_FULL_MALLOC_INIT flag. This signals that the
simple malloc() should no longer be used.
In some cases, such as SPL, even the code space used by the full malloc() is
wasteful. Add a CONFIG_SYS_MALLOC_SIMPLE option to provide only the simple
malloc. In this case the full malloc is not available at all. It saves about
1KB of code space and about 0.5KB of data on Thumb 2.
Acked-by: Tom Rini <trini@ti.com>
Addressing was completely broken for cmd_fpgad.
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
enable to boot only a raw u-boot.bin image from nand with the
CONFIG_SPL_NAND_RAW_ONLY define. This option saves space on
boards where spl space is low.
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Reviewed-by: Bo Shen <voice.shen@atmel.com>
mcc200 and prs200 are old and have no maintainer. Remove the boards.
This also removes the mcc200 specific 1bpp BMP support from
common/lcd.c
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: York Sun <yorksun@freescale.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
When DEBUG is set, output memory region used for malloc().
Signed-off-by: Thierry Reding <treding@nvidia.com>
Skip enclosure service devices when probing for usb storage devices.
This avoids long timeouts when probing for external usb harddisks
which provide "Enclosure Services".
Signed-off-by: Soeren Moch <smoch@web.de>
This is a new version of the patch
"usb_storage: skip all unknown devices when probing"
http://http://lists.denx.de/pipermail/u-boot/2014-November/194622.html
Cc: Tom Rini <trini@ti.com>
This file got corrupted by the automatic editin of commit 1a45966 "Add
GPL-2.0+ SPDX-License-Identifier to source files"; restore the
opiginal content and manually insert the SPDX ID.
The bug was detected by running cppcheck, which reported:
[common/cmd_fitupd.c:8]: (error) Invalid number of character ({) when
these macros are defined: 'CONFIG_UPDATE_TFTP'.
run_command() returns success even if the command had a syntax error;
correct this behaviour.
Signed-off-by: Rabin Vincent <rabin@rab.in>
Acked-by: Simon Glass <sjg@chromium.org)
Hush segfaults if it sees a syntax error while attempting to parse a
command:
$ ./u-boot -c "'"
syntax error
Segmentation fault (core dumped)
This is due to a NULL pointer dereference of in_str->p in static_peek().
The problem is that the exit condition for the loop in
parse_stream_outer() checks for rcode not being -1, but rcode is only
ever 0 or 1.
Tested-by: Simon Glass <sjg@chromium.org)
Attempting to run:
- an empty string
- a string with just spaces
returns different error codes, 1 for the empty string and 0
for the string with just spaces. Make both of them return
0 for consistency.
Attempting to run the sandbox leads to a segfault, because some dynamic
libraries (outside of u-boot) attempt to use malloc() to allocate memory
before u-boot's gd variable is initialized.
Check for gd not being NULL in the SYS_MALLOC_F_LEN handling, so that
malloc() doesn't crash when called at this point.
$ gdb -q --args ./u-boot
(gdb) r
Program received signal SIGSEGV, Segmentation fault.
0x0000000000412b9b in malloc (bytes=bytes@entry=37) at common/dlmalloc.c:2184
2184 if (!(gd->flags & GD_FLG_RELOC)) {
(gdb) p gd
$1 = (gd_t *) 0x0
(gdb) bt
#0 0x0000000000412b9b in malloc (bytes=bytes@entry=37) at common/dlmalloc.c:2184
#1 0x00007ffff75bf8e1 in set_binding_values (domainname=0x7ffff11f4f12 "libgpg-error", dirnamep=0x7fffffffe168, codesetp=0x0)
at bindtextdom.c:228
#2 0x00007ffff75bfb4c in set_binding_values (codesetp=0x0, dirnamep=0x7fffffffe168, domainname=<optimized out>) at bindtextdom.c:350
#3 __bindtextdomain (domainname=<optimized out>, dirname=0x7ffff11f4f00 "/usr/share/locale") at bindtextdom.c:348
#4 0x00007ffff11eca17 in ?? () from /lib/x86_64-linux-gnu/libgpg-error.so.0
#5 0x00007ffff7dea9fa in call_init (l=<optimized out>, argc=argc@entry=1, argv=argv@entry=0x7fffffffe208,
env=env@entry=0x7fffffffe218) at dl-init.c:78
#6 0x00007ffff7deaae3 in call_init (env=0x7fffffffe218, argv=0x7fffffffe208, argc=1, l=<optimized out>) at dl-init.c:36
#7 _dl_init (main_map=0x7ffff7ffe1a8, argc=1, argv=0x7fffffffe208, env=0x7fffffffe218) at dl-init.c:126
#8 0x00007ffff7ddd1ca in _dl_start_user () from /lib64/ld-linux-x86-64.so.2
I believe that when no DTB is around we should return 1.
This why I fixed such scenarious to not return zero anymore.
Else kernel might get NULL pointer to DTB which doesn't exists.
Signed-off-by: Noam Camus <noamc@ezchip.com>
Waiting an interrupt packet to complete in usb_kbd_poll_for_event, causes
a 40 ms latency for each call to usb_kbd_testc, which is undesirable.
Using control messages leads to lower (but still not 0) latency, but some
devices do not work well with control messages (e.g. my kvm behaves funny
with them).
This commit adds support for using the int_queue mechanism which at least
the ehci-hcd driver supports. This allows polling with 0 latency, while
using interrupt packets.
Instead of looking them up every time we need them.
stdio_register makes a malloc-ed copy of struct stdio_dev through stdio_clone,
free the malloc-ed memory on stdio_deregister.
Free the keyboard hid-report buffer and private data on deregister.
This is not used anywhere, so lets remove it.
Do as the Linux kernel does and power on any ports which are not yet one,
this is enough.
If the device has a parent, it is instantiated from usb_hub_port_connect_change
and the portnr is right there in dev->portnr, so there is no need for this
whole dance to look it up.
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This is a bit odd in that we are permitted to boot images for either, even
though they are separate architectures.
Commit ae83d882f5fdf7aa7c5aec09cfafb593153c25d6 moved the fixed size mentioned
in the comment but missed the comment.
This patch makes the following changes:
- Set kernel entry point correctly
- Append bootargs from image to global bootargs instead
of replacing them
- Return end address instead of size from android_image_get_end()
- Give correct parameter to genimg_get_format() in boot_get_ramdisk()
- Move ramdisk message printing from android_image_get_kernel() to
android_image_get_ramdisk()
Signed-off-by: Ahmad Draidi <ar2000jp@gmail.com>
Actually, unmap_sysmem() does nothing. Just in case.
- Do not insert a whitespace between a function name and
an open paranthesis
- Fix comment style
- Do not split an error message into multiple lines
even if it exceeds 80 columns
- Do not split "for" statement where it fits in 80 columns
- Do not use assignment in if condition
CHUNK_TYPE_DONT_CARE should skip over the specified number of blocks, but
currently fails to increment the device block address. This results in
filesystem images getting written incorrectly. Add the missing block
address incrementing.
Cc: Steve Rae <srae@broadcom.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Steve Rae <srae@broadcom.com>
allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT.
Do not hang in spl_register_fat_device but return an error value.
It allows to use both CONFIG_SPL_FAT_SUPPORT and CONFIG_SPL_EXT_SUPPORT.
If FAT load fails, then EXT load is tried.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Add EXT filesystem support to SPL.
[trini: Fix a warning and checkpatch problems]
Rename some defines containing FAT in their name to be filesystem generic:
MMCSD_MODE_FAT => MMCSD_MODE_FS
CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME
CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME
CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION
Use the inttypes header file to provide this.
Since i2c_init_all always sets the bus back to CONFIG_SYS_SPD_BUS_NUM
for compatibility reasons, it means that any eeprom not located on this
CONFIG_SYS_SPD_BUS_NUM is not accessible with the eeprom commands, even
if you change the bus number with an i2c dev command before.
Furthermore i2c_init_all should disappear and is currently only called
from the early board initialisation sequences, it is not suited for
other usage.
This reverts commit 01a0c64762e902971b34587a8a61b59e9ea51374.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
The run command treats each argument an an environment variable. It gets the
value of each variable and executes it as a command. If an environment
variable contains a newline and the hush cli is used, it is supposed to
execute each line one after the other.
Normally a newline signals to hush to exit - this is used in normal command
line entry - after a command is entered we want to return to allow the user
to enter the next one. But environment variables obviously need to execute
to completion.
Add a special case for the execution of environment variables which
continues when a newline is seen, and add a few tests to check this
behaviour.
Note: it's not impossible that this may cause regressions in other areas.
I can't think of a case but with any change of behaviour with limited test
coverage there is always a risk. From what I can tell this behaviour has
been around since at least U-Boot 2011.03, although this pre-dates sandbox
and I have not tested it on real hardware.
Reported-by: Wolfgang Denk <wd@denx.de>
Fix a trivial conflict over adding <dm.h>
arch/arm/cpu/armv7/omap3/board.c
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
[trini: bootm.h must come after common.h]
search_device is declared in iomux, but console only
had the definition. This prevents a warning.
do_bootelf_exec was a weak function without a prototype nor
and strong version. Just make it static.
