The CFG_ENV_SIZE is not suitable used for SPI flash erase
sector size if CFG_ENV_SIZE is less than CFG_ENV_SECT_SIZE.
Add condition check if CFG_ENV_SIZE is larger than
CFG_ENV_SECT_SIZE, calculate the right number of sectors for
erasing.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Since page size field is changed from oobblock to writesize. But OneNAND is not updated.
- fix bufferram management at erase operation
This patch includes the NAND/OneNAND state filed too.
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY
onenand_print_device_info():
- Now returns a string to be placed in mtd->name,
rather than calling printf.
- Remove verbose parameter as it becomes useless.
Signed-off-by: Fathi Boudra <fabo@debian.org>
Environment can be smaller than NAND block size, do not need to read a whole
block and minimum for writing is one page. Also remove an unused variable.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Implement block-skipping read/write, based on a patch from
Morten Ebbell Hestens <morten.hestnes@tandberg.com>.
Signed-off-by: Morten Ebbell Hestnes <morten.hestnes@tandberg.com>
Use of the non-skipping versions was almost always (if not always)
an error, and no valid use case has been identified.
Signed-off-by: William Juul <william.juul@tandberg.com>
To use YAFFS2 define CONFIG_YAFFS2
Changes requested by maintainer Stefan Roese after
posting patch to U-boot mailing list.
- Fixing leading white spaces
- Fixing indentation where 4 spaces are used instead of tab
- Removing C++ comments (//), wherever I introduced them
A lot changed in the Linux MTD code, since it was last ported from
Linux to U-Boot. This patch takes U-Boot NAND support to the level
of Linux 2.6.22.1 and will enable support for very large NAND devices
(4KB pages) and ease the compatibility between U-Boot and Linux
filesystems.
This patch is tested on two custom boards with PPC and ARM
processors running YAFFS in U-Boot and Linux using gcc-4.1.2
cross compilers.
MAKEALL ppc/arm has some issues:
* DOC/OneNand/nand_spl is not building (I have not tried porting
these parts, and since I do not have any HW and I am not familiar
with this code/HW I think its best left to someone else.)
Except for the issues mentioned above, I have ported all drivers
necessary to run MAKEALL ppc/arm without errors and warnings. Many
drivers were trivial to port, but some were not so trivial. The
following drivers must be examined carefully and maybe rewritten to
some degree:
cpu/ppc4xx/ndfc.c
cpu/arm926ejs/davinci/nand.c
board/delta/nand.c
board/zylonite/nand.c
Signed-off-by: Stig Olsen <stig.olsen@tandberg.com>
Use CONFIG_NUM_CPUS to match existing define used by 86xx.
Acked-by: Jon Loeliger <jdl@freescale.com>
The autostart revert caused a bit of duplicated code as well as
code that was using images->autostart that needs to get removed so
we can build again.
- os_data_header Variable is a carry over feature
& unused. So removed all instance of this variable
- Minor Code Style Update
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
While locally preparing some U-Boot patches for ARM based OMAP3 boards, some
using OneNAND and some using NAND, we found some differences in OneNAND and
NAND command address handling.
As this might confuse users (it already confused us), we like to align OneNAND
and NAND address handling.
The issue is that cmd_onenand.c subtracts the onenand base address from the
addresses you type into the u-boot command line so, unlike nand, you can't
use addresses relative to the start of the onenand part e.g. this won't work:
onenand read 82000000 280000 400000
you have to use:
onenand read 82000000 20280000 400000
Looking at recent git, the only board currently using OneNAND is Apollon, and
for this the OneNAND base address is 0 (apollon.h)
#define CFG_ONENAND_BASE 0x00000000
so patch below won't break any existing boards and will align OneNAND and NAND
handling on boards where OneNAND base address is != 0.
Signed-off-by: Steve Sakoman <sakoman@gmail.com>
Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
This reverts commit f5614e7926863bf0225ec860d9b319741a9c4004.
The commit was based on a misunderstanding of the (documented)
meaning of the 'autostart' environment variable. It might cause
boards to hang if 'autostart' was used, with the potential to brick
them. Go back to the documented behaviour.
common/cmd_bootm.c
common/image.c
include/image.h
boot_get_ramdisk() should not treat the case when a FIT image does
not contain a ramdisk as an error.
Acked-by: Michal Simek <monstr@monstr.eu>
The current lcd_display_bitmap() function does not work properly
for the Atmel LCD controller.
2 fixes need to be done:-
(a) when setting the colour map, use the lcd_setcolreg() function
as provided by the Atmel driver
(b) the data is never actually written to the lcd framebuffer !!
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
The README file states that CONFIG_VIDEO_BMP_GZIP behaves as follows:
If this option is set, additionally to standard BMP
images, gzipped BMP images can be displayed via the
splashscreen support or the bmp command.
However, the splashscreen function *only* supports standard BMP images.
This patch adds the documented gzip support.
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
U-Boot allows for configurable prompt strings using the
CONFIG_AUTOBOOT_PROMPT resp. CONFIG_MENUPROMPT definitions. So far,
the assumption was that any such user defined problts would contain
exactly one "%d" format specifier. But some boards did not.
To allow for flexible boot prompts without adding too complex code we
now allow to specify the whole list of printf() arguments in the user
definition. This is powerful, but requires a responsible user who
really understands what he is doing, as he needs to know for exanple
which variables are available in the respective context.
The origional code was using on odd reference to get to the first
real element in av_[]. The first two elements of the array are
not used for actual bins, but for house keeping. If we are more
explicit about how use the first few elements we can get rid of the
warnings:
dlmalloc.c: In function 'malloc_extend_top':
dlmalloc.c:1971: warning: dereferencing type-punned pointer will break strict-aliasing rules
dlmalloc.c:1999: warning: dereferencing type-punned pointer will break strict-aliasing rules
dlmalloc.c:2029: warning: dereferencing type-punned pointer will break strict-aliasing rules
The logic of how this code came to be is:
bin_at(0) = (char*)&(av_[2]) - 2*SIZE_SZ
SIZE_SZ is the size of pointer, and av_ is arry of pointers so:
bin_at(0) = &(av_[0])
Going from there to bin_at(0)->fd or bin_at(0)->size should be straight forward.
A recent patch used '#if (CONFIG_CMD_USB)' instead of
'#if defined(CONFIG_CMD_USB)'. This patch fixes this problem and makes
common/bootm.c compile again.
Acked-by: Markus Klotzbuecher <mk@denx.de>
cmd_ide.c:827: Warnung: weak declaration of `ide_outb' after first use results in unspecified behavior
cmd_ide.c:839: Warnung: weak declaration of `ide_inb' after first use results in unspecified behavior
This is needed for boards that define CFG_64BIT_STRTOUL but don't define
CFG_64BIT_LBA.
Delete the crypto node if not on an E-processor. If on 8360 or 834x family,
check rev and up-rev crypto node (to SEC rev. 2.4 property values)
if on an 'EA' processor, e.g. MPC8349EA.
